  • 2876阅读
  • 2回复
QRZ.中国怎么打不开了 [复制链接]
离线ba2ba
只看楼主 倒序阅读 0楼 发表于: 2013-08-16
刚才上QRZ.中国网页打不开了,是网站的问题吗?,有能打开的吗?
姓名:陈铁石/BA2BA
邮编:153021
电话:18804585572
QQ:464826156
离线bg7nfm
只看该作者 1楼 发表于: 2013-08-16
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
Error Executing Database Query.
Cannot connect to MySQL server on 127.0.0.1:3306. Is there a MySQL server running on the machine/port you are trying to connect to? (java.net.ConnectException)
Resources:
  • Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debugging Settings, and select the Robust Exception Information option.
  • Check the ColdFusion documentation to verify that you are using the correct syntax.
  • Search the Knowledge Base to find a solution to your problem.
Browser  Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/28.0.1500.95 Safari/537.36
Remote Address  124.248.237.154
Referrer
Date/Time  16-Aug-13 08:42 PM
BD4UJ
Email:hfcaojian@gmail.com
只看该作者 2楼 发表于: 2013-08-17
现在正常的~
900兆:要奇奇陆吧三铃摇摇就散
