  • 3842阅读
  • 10回复
新品 SPE Expert-1.5KwPEP带ATU 非常小巧才7Kg 宽电源100-255vAC还能犹豫什么呢QRP [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2013-06-16
• Powerful: up to 1.5 KW (1.3 KW typ.).
• Very Light: 7.5 Kg. (16.5 Ibs) typ.
• Very Small: h 12, w 28, d 36 cm (4.72”x11.02”x14.17”) connectors included.
• Wide Frequency Coverage: 1.8 MHz to 50 MHz, including WARC
• Internal Switching Power Supply with Power Factor Correction.
• No jumper changes necessary to work from 100VAC to 255VAC
• Manages 4 antennas automatically.
• Automatically switches between 2 transceivers.
• SO2R operation.
• Can manage an external set of Band Pass Filters.
• ATU Built-In: bypassable per antenna and band.
• Up to 3 antennas can be selected for every band.
• Additional receiving antenna can be selected.
• Drives directly up to 4 dynamic antennas (SteppIR, Ultrabeam) for an easiest layout.
• No relay contacts are switched when current is flowing due to special software.
• QSK.
• Fully remotable.
• Remote control and all software upgrades fully available on SPE website.
• USB and RS 232 ports.
• 3 Selectable Power Output: MAX, MID (800 W), LOW (500W).
• Very clean and low distortion signal.
• Both inputs always perfectly matched.
• Quiet Operation: four fans linearly controlled by power supply and power amplifier temperatures.
• Fully protected.
• Fully Solid State: uses only one new very rugged device.
• Over 30000 lines of software for performances that cannot be found together in any other amplifier.
• Two very fast CPUs.
• CAT and band data compatible with all rigs on the market allowing automatic control of antennas,
bands, ATU matchings.
• Available also without ATU allowing significant savings.
• Complete with heavy duty carrying bag allowing carry-on to airplanes.
• Certifications: CE, FCC pending.h 12cm, w 28cm, d 36 cm
非常小巧的尺寸  值得拥有
[ 此帖被BG4DRL在2013-06-16 12:48重新编辑 ]
只看该作者 1楼 发表于: 2013-06-16
Re:新品 SPE Expert-1.5KwPEP带ATU 小巧7Kg 电源100-255v还能犹豫什么呢
这样的Spec才是你需要的
比你的电台才小圈而已
省略了你的L-Tuner 扔了你的线性电源吧
小巧精致才是王
只看该作者 2楼 发表于: 2013-06-16
只看该作者 3楼 发表于: 2013-06-16
回 BD8SZ 的帖子
BD8SZ:价格决定市场 (2013-06-16 13:35)
对 日本最便宜
销路大
But但还是偏高
日本机器是终身免费更换 不修机
这个配你的990 就扔掉线性电源了 干干净净 只一键盘来
只看该作者 4楼 发表于: 2013-06-16
回 BD8SZ 的帖子
22kg的老机
1kw的降价幅度特别厉害  就看新机定位了
JUMA1k也快出了
离线BA7KW
只看该作者 5楼 发表于: 2013-06-16
好啊,如果是500USD一台马上买,自己做太累,特别是ATU.
BA7KW  张建华
BA7KW"at"163.com
离线bd8uk
只看该作者 6楼 发表于: 2013-06-17
1000USD立马贷款买一台回来当家具摆设!
离线关则勇
只看该作者 7楼 发表于: 2013-06-17
如果是3000usd马上借钱买一台回来。
离线BH7ohz
只看该作者 8楼 发表于: 2013-06-17
钱不是问题,问题是没钱
呼  号:鸡蜜
姓  名:鸡蜜
通讯地址:鸡蜜
邮政编码:鸡蜜
手机:鸡蜜
QQ:鸡蜜
E-mail:KAO,这么多鸡蜜... ...
离线BG0APD
只看该作者 9楼 发表于: 2013-06-17
仰望一下。
邮箱:BG0APD@163.com
电话:15309910960
只看该作者 10楼 发表于: 2013-06-17
回 关则勇 的帖子
关则勇:如果是3000usd马上借钱买一台回来。 (2013-06-17 09:33)
关老大
帮你搞来借用1个月 再加2000USD   冬天交货
