  • 6077阅读
  • 2回复
Receive Performance Comparisons [复制链接]
离线BA2Bi
只看楼主 倒序阅读 0楼 发表于: 2013-04-07
摘选 http://www.elecraft.com/K2_perf.htm#Main%20RX%20Table
Lab Receiver Test Data Comparisons
(ARRL QST Review Data, plus some data from Sherwood Engineering)
XX/YY =  (preamp-off) / (preamp-on); 14Mhz operation, 500 Hz CW filter, AGC off, High Ip mode.
All measurements in dB. Lab tests and rigs can vary by several dB, so results within 2-3 dB are roughly equivalent.
Numbers in RED indicate data that is 10 dB or more worse than for the K3. (A factor of ten signal power difference.)
RIG
MDS (dBm)
Sensitivitypre off / on
BDR'Desense' 5 kHz spacing
pre-amp  off
BDR 'Desense' 20 kHz spacing
pre off / on
IMD DR3
'Intermod'5 kHz spacing
pre-amp off
IMD DR3
'Intermod'
20 kHz spacingpre off / on
Ip3 (dBm)
20 kHz spacing
5 kHz spacing
pre off / on
Ip2 (dBm)
Out of band Signal Rejection  pre off / on
Phase Noise (dBc at +4 kHz) Receive Current
[url=http://www.elecraft.com/K2_perf.htm#voltage chart](Also see below)[/url]
K3 (ARRL)
K3  (Sherwood Eng.)
-130/-137
-130/-138
139 (2 kHz)
139/134
140 (100 kHz)
102 (2 kHz)
101 (2 kHz)
103/99
104
+26/+14+26 (2 kHz)
+79/+79
-133 (4 kHz)
-139 (10 kHz)
800 mA
K2
-130/-136
135
134 / 126
91
97 / 95
+21/+8  (20kHz)
+21/+8 (5kHz)
+80 / +79
-124 150-200 mA
Ten-Tec Orion II -127/-137 136 136/134 96 92/90
+20/+6 (20kHz)+20 (5 kHz pre off)
+82/+80 -138 3.6A
FTdx9000D -122/-134 127 138/137 95 99/99 +27/+15 (20kHz)
+20/+10 (5 kHz)
+64/+66 -120 110 V Supply
IC-7800 See Note 2
-127/-138/-142 115 137/138/135 89 104/103/102 +37/+21/+11  (20kHz)
+22/+7.7/+0.5 (5 kHz)
+98/+87/+84 -120
110 V Supply
Ten-Tec Omni6+ See Note 1
-133
119
123 (nl)
86
97
+12  (20kHz)
+58
-117 2A
Ten-Tec OMNI VII -130/-140 135 137/134 84 91/91
+11/-0.5+6.5 (5 kHz)
+73/+75 -110 2.2A
FT-1000MP
-128  /-135
119
142 / 137
83
97 / 94
+15 / +5  (20kHz)
+86/+88
-118 2.8A
SDR-5000   (Sherwood Eng.)
-123/-135
123
96 (2 kHz)
96
-123 (10 kHz)
SDR-3000 -121/-135 113 113 98 99/99 +26/+14
+22 (2 kHz)
+69/+45 -120 2.8A
IC-7600 -131/-139 113 122 94 (5 kHz)
88 (2 kHz)
106/102 +28/+12
+10 (5 kHz pre-off)
+63/+59 -118 2.4A
IC-756PRO III
See Note 2
-131/-139/-141 101 121/119/113 77 103/100/99 +25/+14/+5  (20kHz)
-17/-29/-35 (5 kHz)
+73/+71/+68 -126 3.4A
IC-756PRO II
See Note 2
-131/-139/-141 100 118/116/107 76 97/95/91 +20.2/+10.2/-4.1  (20kHz) +75/+71/+59 -130 3.5A
IC-756PRO
See Note 2
-128 / -136 / -140
104
127 / 125 / 120
80
95 / 92 / 88
+15.4 / +4.3 / -6.9
+64 / +63 / +43
-130 3A
IC-746PRO
See Note 2
-132/-140/-142 100 125/123/118 75 97/96/92 +13.5/+3.7/-4 +72/70/+54 -123 1.9A
TS-870
-129 / -139
not tested
127 / 123
not tested
97 / 95
+16 / +4
+63 / +63
-118 2A
TS-930See Note 1
-139 not tested noise limited not tested 86.5 -7.75 not tested not tested 110V supply
Ten Tec Argo VModel 516
See Note 1
-132 67 118 62 85 -3.4 +47 -108 1A
Ten-Tec Jupiter
See Note 1
-135
not tested
123(nl)
not tested
85(nl)
+7.3
+53.6
-115 1.5A
Ten-Tec Scout See Note 1
-125
not tested
119
not tested
87
+5.5
not tested -95 600 mA
Ten Tec Pegasus
See Note 1
-132
not tested
110 (nl)
not tested
77
+7.2
+44.3
-104 1A
TS-50
-132/-139
not tested
113 / 109
not tested
90 / 88
+3 / -7
not tested -115 800 mA
FT-100
See Note 3
-133/-137 ~100 +130/+125 ~70 94/91 +10/+4.2 +51.7/+52.8 -118 1.5A
FT-817
-126/-134
not tested
106/104
not tested
87/84
+5/-5.6
+84/+88.4
-103 450 mA
FT-897 -133/-137 96 (nl) 109/106 67 89/86 -1.3/-6.7 +67/+62 -102 900 mA
IC-703 -131/-141 95 121(nl)/122(nl) 76 89/91 +11/+1.9 +56/+47 -118 320-580 mA
IC-706MKIIG
-136/-142
86
122(nl) / 120(nl)
74
89 / 86
-1.3 / -11
+36.4 / +38.5
-118 2A
Kachina 505DSP
-133 / -142
not tested
103 / 103
not tested
99 / 97
+15.5 / +3.5
+49 / +30
-117 2A
Note 1: Only one set of numbers is listed because these radios use a fixed gain front end which is not switchable. Compare their dynamic range and IP3 numbers to other rig's by using similar MDS figures to determine which set of numbers to use (pre-on / pre-off) for comparison.
Note 2:  The IC-7800, IC-756PRO & PROII  and IC-746PRO have two different gain preamps. Numbers are for Pre-Off / Pre #1 / Pre #2.  Pre #2 adds more RX gain than Pre #1 at the expense of  dynamic range. Higher preamp gain reduces strong signal dynamic range. For comparison, Pre-Off and Pre #1 most closely match the K2's and other radio's settings and are the most commonly used positions.
Note 3: FT-100 5 kHz dynamic range numbers taken from swept dynamic range graphs in ARRL expanded test report.
ARRL Results are from QST rig reviews (K2, 2/04 (K2/100) and  3/00  (K2) reviews);  IC756 PRO, 6/00; Omni6+, 11/97; FT1000MP, 4/96; Scout, 12/93; TS-50, 9/93; SGC-2020, 10/98; IC706MKII, 7/99; Ten Tec Pegasus, 2/00; Ten Tec Jupiter, 6/01; TS-930, 1/84; Kachina 505DSP, 5/98; Patcom PC-1600A, 12/00; FT817, 4/01; FT-100, 6/99, Argo V 4/2003; FT-897, 5/2003; IC-703, 7/2003; Orion II 9/06; IC-7800, 8/04; 756PRO-III, 3/05; FTdx9000D,  8/05; SDR-3000, 10/09; IC-7600, 11/09). Sherwood Engineering results are from their receiver test results page. K3 (QST, 4/08) (Sherwood Engineering, 2/08); SDR-5000 (Sherwood Engineering, 2/08); OMNI VII, 7/2007
5 kHz Signal Spacing (ARRL Lab Results & Comments)
Rig Minimum Supply Voltage and Current Requirements
RIG Min. RX Current Drain Min. Supply Voltage Notes
K2
150 mA to 200 mA
9V Note 1A, 1B
FT-1000MP
2.8A
13.5 V
IC-756 PRO*
3A 11.7 V
IC-756 PRO II* 3.5A 11.7 V
Ten-Tec Omni6+
2A 12.0 V
Ten-Tec Orion 3.1A
Ten Tec Argo V
Model 516
1A
IC-703 320 mA to 580 mA
FT-897 900 mA
TS-870
2A 11.7V Note 3
TS-930 110 V supply 110 V supply
Kachina 505DSP
2A unknown
Pegasus 550DSP
1A 12V
Ten-Tec Jupiter
1.5A 12 V
Patcom PC-1600A
3.3A unknown Note 4
FT-817
450mA 8 V
FT-100 1.6 A unknown
IC-706MKIIG
2A 11.7 V
TS-50
800mA 11.7 V Note 4
Ten-Tec Scout
600mA 12 V
SGC-2020
430mA 10.5 V Note 2
Note 1A (K2 supply voltage): The table below shows the recommended maximum power output setting vs. supply voltage. Supply voltage was measured at K2 DC input jack in transmit mode. (The reverse-polarity protection diode, D10 on the K2 RF board, was a 95SQ015. This diode is supplied with all K2s with s/n 3000 or higher. Older K2s used an SB530 diode; add 0.3 V to the DC voltages in the table in this case. Upgrading to the 95SQ015 diode is recommended for use at low  supply voltages.)
DC VOLTAGE POWER OUTPUT
9.0 V2.0 W
9.5 V 5.0 W
10.0 V 7.0 W
10.5 V 10.0 W
Note 1B (K2 current drain): 0.15-A minimum receive current is with receiver in OPT BATT (battery save) mode. In OPT PERF (performance) mode, minimum receiver current is approx. 0.2 A. All K2 receiver performance measurements were made using OPT PERF mode (see "ARRL Lab Receiver Test Data Comparisons" table, above).
Note 2 (SG2020): Different user's manual editions claim 11 V or 9 V minimum. SGC tech support says the 9 V claim is incorrect, and that the actual minimum is
10.5 V. This is consistent with the LM2940-10 voltage regulator used. Max power output at reduced voltages not specified.
Note 3 (TS870): Standby current drain shown. Active current drain not specified.
Note 4 (Patcomm, TS-50): Current drain not specified. Used ARRL test data.
Definitions of Receiver Comparison Test Results
nl = test was noise limited (noise floor rose 1db before 1db of blocking desense occurred)
MDS = Minimum Discernible Signal (3db increase above noise floor). Larger negative numbers are generally better, but too much sensitivity can reduce strong signal dynamic range and Ip3. Pre-Amp On MDS numbers of -130 dBm or more are more than adequate for most HF band operating, since band noise is typically above this number. (Lower frequencies need less MDS (more +number) due to an increase in atmospheric noise.)
IMDDR3 = 2 tone (20 kHz spacing) 3rd order Two tone IMD Dynamic Range. This test shows how the RX performs in the presence of multiple strong nearby signals in relation to its sensitivity (MDS). Higher is better. Pre-Amp Off  IMDDR3 numbers of +95dB (20 kHz spacing) and +90 dB (5 kHz spacing) or more are considered good.
Ip3 = 2 tone (20 kHz spacing) 3rd order Intercept Point. This test also shows how the RX performs in the presence of multiple strong nearby signals. Higher is better. Pre-Amp OFF IP3 numbers of +15dBm are good, and +20dBm or more is excellent. Note: Low RX sensitivity artificially increases the measured Ip3.
Ip2 = 2 tone (8.020MHz, 6.000MHz) 2nd order Intercept Point This test shows how the RX performs in the presence of multiple strong out of band signals (such as broadcast signals on 6Mhz and 8Mhz creating birdies at 14Mhz). Higher is better. A Pre-Amp OFF IP2 of +55dBm is OK, and +70dBm or more is considered excellent.
BDR = Blocking Dynamic Range  (20 kHz spacing). This test shows when the receiver's sensitivity begins to drop in the presence of strong near by signals. (Desense). A Pre-Amp OFF BDR (20 kHz signal spacing) of greater than 120dB is good. Greater than 130dB is considered excellent. BDR decreases on most multi-conversion receivers as the interfering signal spacing from the receiver's listening frequency is reduced. Single conversion receivers like the K2 typically do not see as much of a BDR degradation as interfering signal spacing is reduced.
Phase Noise = value read from ARRL test graph at  +10 kHz from the carrier. Numbers are for the worst case band. Larger negative numbers are better. Bad phase noise contributes to poor RX Blocking Dynamic Range (desense from nearby signals) and broadband TX noise. Good values are  -130 dBc or better at +10 kHz. See the actual ARRL phase noise plots in each review for details of other spurious phase noise components.
离线杨科
只看该作者 1楼 发表于: 2013-04-07
什么情况?
离线BA7IA
只看该作者 2楼 发表于: 2013-04-09
K3胜出......
