  • 14435阅读
  • 27回复
●●●莫尔斯码(CW)缩略码总汇●●● [复制链接]
离线BD4WM
只看楼主 倒序阅读 0楼 发表于: 2013-03-28
链接: http://www.qsl.net/w5www/abbr.html
73--Best Regards
88--Hugs and Kisses
ABT--About
AGN--Again
ANT--Antenna
ARND--Around
B4--Before
BCNU--Be Seeing You
BK--Break, Back ("I'm back now" or "Back to you")
BN--Been
BTR--Better
BUX--Dollars
CLDY--Cloudy
CLR--Clear (usually a description of the weather)
CNTCT--Contact
CONDX--Conditions
CPY,CPI--Copy
CU--See you
CUD--Could
CUL--See You Later
CUZ--Because
DR--Dear (often used by foreign/DX operators in front of the other operator's name)
ES--And
FB--Fine Business (good, excellent, OK)
FER--For
FT--Feet
GA--Good Afternoon, Go Ahead
GB--Good Bye, God Bless
GE--Good Evening
GL--Good Luck
GM--Good Morning
GUD--Good
HI--Telegraphic Laughing
HPE--Hope
HR--Here, Hear
HV--Have
HW--How (or "How copy?")
LIL--Little
MNI--Many
NR--Near, Number
NW--Now
O 0--(usually used when stating transmitter output of 100 Watts. If using a straight key it is also OK to use a very long dah to represent 0.)
OM--Old Man
OP--Operator (Sometimes used insted of "name" when introducing oneself.)
PSE--Please
PWR--Power
R--are
RCVR--Receiver
SIGS--Signals
SN--Soon
SRI--Sorry
TMW--Tomorrow
TNX, TKS--Thanks
TU--Thank You (usually used at end of contact, meaning "Thanks for the contact".)
TX--Transmit
U--You
UR--Your, You Are
URS--Yours
VY--Very
WID--With
WL--Well, will, we'll
WTS--Watts
WUD--Would
WX--Weather
XCVR--Transceiver
XMTR--Transmitter
XYL--Wife
YL--Girlfriend ("Young Lady")
YRS--(Years)
PROSIGN TIPS
Don't neglect to learn these by sound. Knowing what they look like on paper is of little value when you are mystified by the sound of long CW characters. Knowing the rules of context that govern the use of prosigns is also very helpful.
AAA is the period. Use it at the end of a sentence when the following sentence will pertain to the same subject.
AR is used at the end of a transmission when calling a specific station before the two-way contact has been established. Use it in place of K or KN when answering a CQ, or calling someone for a sked.
AS means "Please stand by for a moment", usually used to let the other guy know that you have to talk to someone else in the room, answer the telephone, or fix some technicial glitch and that the band didn't just fall out from under your QSO. You'll be back in just a mintute.
BT is kind of like the period. Use it at the end of a sentence when the next sentence will pertain to a different topic.
CL follows SK when you are also vacating the frequency just used. Note that the letters are not run together on this one.
DE From
DN is the slash (/). It is used to indicate mobile, QRP, or operation from a different call area than that indicated by your callsign.
IMI is the question mark.
K is used at the end of a transmission means you are listening for an answer from any station. Use it when calling CQ. Once you have established contact with a station and you do not want to be interupted by a third party, use KN instead.
KN is used at at the end of a transmission when only the other party already in the QSO is invited to respond.
MIM is the comma.
R means "Roger" or "Received". Use it at the beginning of a transmission ONLY if you copied 100% of what was just sent to you. Don't use it if anything was missed. Use BK instead, and something like "FB on UR QTH but missed UR name". You can also start a transmission with BK even if something was not missed. High speed operators often use this method instead of KN and R.
SK is used at the end of your final transmission of a QSO. If the other station has not yet sent his "final" you may follow SK with KN.
B G 4 - 3 - 9 8 5 5 (since 1995)
离线BH4rrg
只看该作者 1楼 发表于: 2013-03-28
这个好,收藏学习。
BH4RRG       CSKC#219
常用DX信息网站:
http://new.dxsummit.fi/
http://www.425dxn.org/
http://dx-world.net/
离线bg4wen
只看该作者 2楼 发表于: 2013-03-28
学习,楼主好人,好人一生平安
离线bg2wvk
只看该作者 3楼 发表于: 2013-03-28
学习了!收藏了
CS:bg2wvk/qrp
QQ:376903921
ML:wybkaiyuan@163.com
QTH:辽宁省开原市
离线bd3mv
只看该作者 4楼 发表于: 2013-03-28
今晚楼主在7023只呼叫了很短的时间,回答没有听到回应。
离线BD6MM
只看该作者 5楼 发表于: 2013-03-28
学习了,楼主辛苦!
离线BG1TRP
只看该作者 6楼 发表于: 2013-03-29
认真记一下,楼主辛苦!
三合一台咪套件
天线切换器套件
离线BD4WM
只看该作者 7楼 发表于: 2013-03-29
回 bd3mv 的帖子
bd3mv:今晚楼主在7023只呼叫了很短的时间,回答没有听到回应。 (2013-03-28 23:00)
不是我在呼叫
是南京的另一位新CWer BD4WN在呼叫
离线bg3dbu
只看该作者 8楼 发表于: 2013-03-29
楼主好人,好人一生平安!
CSKC   0008
呼号:BD3DBU
姓名:0491 1696 0948
邮编:300180
电话:AWAWUATGBSG
一名刚加入HAM队伍的新兵。
离线BD8ADT
只看该作者 9楼 发表于: 2013-03-29
借博士的贴子说一下
现在大家应该知到男HAM和男HAM之间不宜用88的原因了吧
除非是 GAY HAM
[ 此帖被BD8ADT在2013-03-29 15:33重新编辑 ]
QQ:....- 232.....68----.
QQ群号(Elecraft & MR) 113481874
E-Mail:bd8adt@qq.com
RIG:K three,FT-817,
FTM350R,FT-8900,FT1D,DJ-G7
离线BG7MVM
只看该作者 10楼 发表于: 2013-03-29
莫尔斯码(CW)缩略码总汇
    B  LEVEL
vy 73and88 ! de bg7mvm - Ham Radio Desperado
Other Interests:Radio controlled planes, helicopters and boats. Model trains
离线ayf
只看该作者 11楼 发表于: 2013-03-30
学习了,很好的,lz辛苦了,谢谢你啊。
车速一慢,路就宽了,看到的风景也多了。
BG9LL
离线BD7pzl
只看该作者 12楼 发表于: 2013-04-02
关键:学习
为了学生。为自己。学习
离线BA4II
只看该作者 13楼 发表于: 2013-04-02
更全的资料看这里:
q语言和英文短语
qra 电台何台
qrb 电台间之距离
qrg 告之正确频率
qrh 频率是否变动
qri 发送音调
qrj 能否收到
qrk 信号之可解度
qrl 电台忙碌/工作中 *
qrm 电台受他台干扰 *
qrn 电台受天电干扰 *
qro 增加发射功率 *
qrp 减低发射功率 *
qrq 请发快点 *
qrs 请发慢点 *
qrt 电台关机 *
qru 电台已无事可再谈 *
qrv 电台已准备工作
qrw 利用频率呼叫或通知
qrx 约会下次 *
qry 通信轮流号码
qrz 是谁呼叫 *
qsa 信号强度如何 *
qsb 信号衰退 *
qsd 敲键有缺陷
qsi 无法在发射中切入
qsk 在发射中切入
qsl 确认通信/电报抄收收据/交换通联卡 *
qsn 在频率上收听到
qso 无线电通信/直接联络 *
qsp 转告、转报 *
qsr 频率上重复呼叫
qss 工作频率
qsu 在此频率发送回答
qsv 某频率发送一系列v
qsx 在某频率发送、收听
qsy 更改频率 *
qsz 重复发送每字及词
qth 所在地 *
qtq 以国际简码通信
qtr 正确时间
qts 以呼号发送进行调整
qtv 在某频率占住
qtx 维持通信到通知止
qua 有关某电台消息
qum 重新开始正常工作
后面带*的要熟记,属于常用q语言
a:
aa:×××以后
ab:×××以前
abt:关于、大约 *
ac:交流电 *
add:增加 *
adr、ads:地址 *
aft(after):以后 *
af:非洲
af:音频
aftrnn:下午
age:年龄 *
agn:又、从新、再来一次 *
ahd:向前、继续下去
ahr:另外的、其他的 *
al(all):完全、全部 *
also:同样的、也是
aly:经常
am:调幅 *
am:上午 *
ans:回答 *
ant:天线 *
apr:四月
ar:电报结束符号(两码之间无间隔)
ar:业余无线电
as:亚洲
as:等待 *
as_m:稍等、等一会儿(或m之前加分钟数字)
at:在 *
aug:八月
atv:业余电视
atonce:立即、马上
auto:自动
b:
bad:不好
balun:平衡—不平衡转换
bc:广播
bci:广播干扰
bck:回、背
bcuz、bec:因为
bda:生日
best:最好的 *
bf:以前
bfo:差拍
bgn:开始
bjt:北京时间
bk:打断、插入 *
bkg:打断、插入
blw:在下面、向听不到下
bn:是
boz:对方
bs:盲发、(听不清或听不到对方时) *
btn:之间
btr:好一些
bug:半自动键
buk:书
buro:管理局、卡片管理局
c:
c:对、是的
c:看到
can:能够
cant:不能
cb:民用波段
cdnt:不能
cfm:确认、认为 *
ch:频道
chf:报务主任、领班
cherrio:再会、祝贺
chg:换 *
ck:检查、组数、字数 *
cl:呼叫(call) *
cld:呼叫过
clg:正在呼叫
clr:清楚
cloudy:阴天 *
cls:等级 *
city:市
cn:能够
cndx:情况
cnt:不能
cnty:国家
cnu:你能否
coax:连接电缆
comm:联络 *
cq:通播、普遍呼叫 *
crd:卡片 *
crt:更正、改正 *
cs:呼号
cuagn:再次见到你、再见 *
cul:再见
cw:等幅、等幅电报 *
cy:抄、抄收、复印件 *
d:
da:白天、一天
date:日期 *
dash:划
dbl:双重的、加倍的
dc:直流电 *
dct:直接的、直接寄卡
de:从……..来 *
dec:十二月
deg:度数
dif:不同、差别
dn:向下、往下
dnt:不
dp:偶极天线 *
dots:点
dr:亲爱的 *
dx:远距离
dxpdn:远征
e:
e:东
el、ele、els:天线单元 *
end:末尾
eng:英文
err:错误 *
es:和、与 *
eu:欧洲
f:
fax:传真
fb:很好的、太好了 *
feb:二月
fer:为了
fig: 码
fine(fig):晴天、好天气 *
fm:调频 *
fm:从…来(从…开始) *
for:代词的前置(相当于对我的) *
forget:忘记
fnd:找到、建立
fq:频率 *
fsk:移频键控
fwd:发出
g:
ga:发过来 *
ga:下午好 *
gain:增益
gb:再见 *
gd、gud:好的、好 *
gd:日安 *
ge:晚安、晚上好 *
gg:去、离去
ghz:吉赫(kmhz) *
gl:幸运、好运气
gld:高兴 *
gm:早安、早上好 *
gmt:格林威治时间
gp:直立+地网天线 *
gv:给
h:
ham radio:业余爱好者 无线电
hard:困难
hd:手 *
he:他
hed:他将
hf:高频、短波 *
hi:笑
hm:他的
hlo:喂、你好
hpe:希望 *
hpi:愉快、幸福
hr:这里、小时 *
hrd:听到
hum:交流声
hv:有、已经
hvnt:没有
hw:怎么样?、如何? *
i:
i:我 *
iaru:国际业余无线电联盟
ic:集成电路
if:中频、中间频率
impt:重要的
info:消息、资料 *
inpt:输入 *
inv:无效 *
irc:国际邮资换劵
itu:国际电信联盟
is:是 *
j:
jan:一月
jm:连码
jul:七月
jun:六月
just:刚才 *
k:
k:发过来、请回答、千 *
key:电键 *
khz:千赫 *
kn:请回答(只限被呼叫的台) *
knw:知道
kp:收听、保持 *
kpz:×××正呼叫你
l:
lg:长、低(指频率) *
lgr:长一点(指频率) *
lil:小
lis:执照
lkg:看、寻找
loc:网格坐标地址
log:记录电台日记 *
lsb:下边带 *
lsn:听
ltr:信、字母
luk:看
lv:离开
lw:长波 *
m:
m:分钟、米 *
ma:毫安 *
mag:杂志
many(may):许多 *
mar:三月
max:最大的、顶点 *
may:五月
mgr:管理人、经理
mhz:兆赫 *
mi、my:我的 *
mist:雾
mic:话筒 *
min:最小的、最低
minus:零下(气温) *
ml:邮件、邮寄
mni:许多
mnl:手工、手册
mod:调制器
mode:方式 *
modem:调制/解调器
mr:先生 *
mri:愉快
mrc:太太
msg:电报、消息 *
ms:小姐
mt:会见
mtg:会议
my:我的 *
n:
n:北
na:北美洲
ncs:网路控制台
nd:没事
new:新 *
next:下次 *
nice:好的
nil:和你没事了
ng:不好
nite:晚上
nn:中午
no:不、不对、不同意 *
none: 没有人
not:没有 *
note:注意
nov:十一月
nr:序号、数字 *
nr:近、近的
nw:现在 *
ny:纽约
o:
ob:老朋友
oc:大洋洲、老朋友
oct:十月
ok:可以、好的、对了、完全正确 *
old:老、原来的 *
om:老朋友、老兄 *
on key:上机 *
op、opr:报务员、操作者 *
or: 或者 *
osc:振荡器
ot:老手
owcomm:单向通信
over:请回答
p:
pa:功率放大器 *
pbl:可能的、问题
phone:电话 *
pls、pse:请
pm:下午
p.o.box:邮政信箱
psbl:可能的
ptt:收、发信转换控制
pwr:电源、功率 *
r:
r:明白、收到了、电阻 *
rain:雨 *
rdi:准备好了
rd:路
rdo:无线电台
recd:已收到
rf:射频(高频)
rfc:高频扼流圈
rig:电台设备 *
rit:收信频率微调
rmks:备注、附注
rpt:重复 *
rprg:修理
rprt:报告 *
rptrl: 中继台
rtty:无线电传打字 *
rcvr、rx:收信机、接收机
s:
s:南
sa:南美洲
sae:写好回信地址的信封
sase:写好回信地址并贴好邮票的信封
sat:卫星
sd:送寄、发的
see:看 *
sep:九月
shp:尖
sht:短、高(指频率) *
shtr:短、高一点(指频率)
shack:电台室、机房
sk:结束联络、再见 *
sked:预约日期
sn:快、立即 *
snow:下雪 *
sos:呼救、呼救信号 *
spc:间隔
split:异频
sri:对不起 *
ssb:单边带 *
sstv:慢扫描电视 *
stl:仍旧
stn:电台(站)
stp:停止
sum:一些
svc:业务
sw:短波(日波)开关 *
swl:收听台、短波收听者 *
swr:驻波比 *
sx:单工
t:
t:零(0)
tbl:问题麻烦
tc:校对、校准 *
temp:温度 *
test:竞赛
thr:他们的
tll:告诉
time:时间 *
tks、tnx:谢谢(多谢)
tmw:明天
to:到(至)给 *
t/r:发/收
trans:翻译
trx:收发信机(电台) *
trub:故障 *
try:试(测试)
tu:谢谢你 *
tune:调整 *
tv:电视 *
tvi:电视干扰
tx:发信机 *
u:
u:你 *
uhf:特高频(30—300兆赫) *
untrans:译不出
up:调高频率 *
ur、urs:你的、你们的 *
usb:上边带 *
use:用 *
utc:世界协调时间
v:
v:伏特?(电压)、呼叫区分符号、调机符号 *
vco:压控振荡器
vert:垂直的、垂直天线 *
vfb:非常好 *
vfo:可变频率振荡器
vhf:甚高频 *
via:经、由
vxo:声控开关
vy:很 *
w:
w:西、瓦特
wats:你说什么
wk:工作、星期 *
wkd:工作过 *
wkg:正在工作
wl、wud:将、愿
wx:天气 *
x:
xcus:原谅
xcvr:收发信机
xmas:圣诞节
xmtr:发信机 *
xyl:妻子、夫人 *
y:
yagi:八木天线 *
yd、yda、dy:昨天
yf:妻子
yl:小姐、女士 *
yr:你的 *
yr:年
yes:是 *
z:
z:零时区的标志及即世界协调时
55:祝您马到成功
72:祝愿你良好的qrp通信 *
73:致敬、问候 *
88:爱、吻(异性之间使用) *
happy chinese new year! 春节快乐
happy new year ! 元旦快乐
happy may day! 五一节快乐
happy 55 day! “55”节快乐!
jan 一月
feb 二月
mar 三月
apr 四月
may 五月
jun 六月
jul 七月
aug 八月
sep 九月
oct 十月
nov 十一月
dec 十二月
mon 周一
tue 周二
wed 周三
thu 周四
fri 周五
sat 周六
sun 周日
常用天气简语
fine:晴 *
cloudy:阴 *
rain:雨 *
mind:雾 *
snow:雪 *
wind:风 *
minus:零下 *
后面带*的为常用。要熟记!
山东老鱼/BA4II(CSKC NR 001)
地址:山东省济南市燕子山路41号
邮编:250014
姓名:余宁生
E-mail:ba4ii@163.com
个人网站:http://www.ba4ii.com
离线BA4MY
只看该作者 14楼 发表于: 2013-04-02
不可缺少的资料
日志查询(每月初更新)
离线bg3upa
只看该作者 15楼 发表于: 2013-04-03
回 BA4II 的帖子
BA4II:更全的资料看这里:
q语言和英文短语
qra 电台何台
qrb 电台间之距离
....... (2013-04-02 11:08)
下载打印贴到墙上
QQ:1124652397
山西省太原市万柏林区
设备: TS-590S
天线:80米倒V+18E。
离线bg6iw
只看该作者 16楼 发表于: 2013-04-03
回 BA4II 的帖子
BA4II:更全的资料看这里:
q语言和英文短语
qra 电台何台
qrb 电台间之距离
学习了,BA4II和BD4WM两位先生的帖子,很值得收藏并努力学习。
感谢你们!
离线bg3dbu
只看该作者 17楼 发表于: 2013-04-03
感谢四区的二位,辛苦了!
CSKC   0008
呼号:BD3DBU
姓名:0491 1696 0948
邮编:300180
电话:AWAWUATGBSG
一名刚加入HAM队伍的新兵。
离线BH1NYT
只看该作者 18楼 发表于: 2013-04-03
楼主好人,好人一生平安!
电话 18601005427
办公室  010-81055333
小企鹅(qq)603254598
E-mail:BH1NYT@163.COM
围脖:http://weibo.com/johnnyxu27
微信订阅号:BY1WXDCQ
地址 北京市东城区成寿寺路11号 邮电出版大厦
邮编 100164
离线大改锥
只看该作者 19楼 发表于: 2013-04-05
这个很有用
山西长治BG3SFW
