  • 8878阅读
  • 7回复
alpha和acom [复制链接]
离线关则勇
只看楼主 倒序阅读 0楼 发表于: 2013-03-22
The ACOM 2000 is basically an upgraded copy of the Alpha 87A but with tetrodes. Alpha had ACOM building their manual tune amplifier in 1991 using a pair of 4CX800A7’s. Then ACOM looked at building the Alpha 87A. Build quality suffered with the 91B and Alpha brought the production back to the US. Because of the Alpha 87A product, ACOM was able to design their current 2000A which copied the basic design of the 87A. You will note the similarities in layout.
Alpha has stopped using the 4CX800A7 tubes in their manual tune amplifiers with the Alpha 8100. This was due to tube scarcity.  In 2009 Alpha started to producing the 8410 manual tune amplifier which uses a pair of massive 4CX1000A’s. ACOM, which still uses the 4CX800A7, has put on a good face saying there is no problems getting the tubes but that just is not the case. TenTec, Alpha and other have stopped using the tube along with most other manufactures. I have no idea where Brian at QRO is getting tubes. All the tubes that are available are NOS (New Old Stock) from the 1990’s and are floating around in various locations in Russia someplace.
The Alpha 9500 uses the 3CX1500B/8877 triode and is very linear. These tubes are made by no less than 5 manufactures and will be around long after amateur radio has left the planet. No problem with tube availability.
I have watched the Alpha 9500 amplifier putting out 3000 watts plus sending CQ Dayton into a dummy load at the ham convention for three days straight. The amplifier design, quality control and component selection is very high with no compromises. In addition Alpha still supports older designs going back to 1977. When running the amplifier at 1500 watts you have a lot of head room. The amplifier uses a 3.5 KVA transformer with a full wave bridge.
On item always to consider is where the factory service is located. Alpha is in the US. ACOM has a service location in Massachusetts, but the manufacturing is in Bulgaria.
It should be noted that only the Alpha 9500 is type accepted (Parts 97.317) by the FCC for 12 and 10 meter operation. None of the other amplifier manufactures have FCC type acceptance for operation above 21.450 MHz. What has been done is the past is to make modifications available for the ham to do and place ten meter operation into the design and that is fine if you feel competent modifying you new amplifier. That is no longer allowed by the FCC. 1500 watt amplifiers must now have a gain of less than 15dB at legal output and they must have zero gain from 26-28 MHz.
Both amplifiers have a 4 year warranty. The Alpha uses the original factory tube warranty which is 1 year. I don’t know what the tube warranty is for the ACOM tubes.
When receiving an amplifier quote also get a quote for spare matched tubes (same manafacturing date) ask what the amplifier manufacture will sell you a spare set of tubes for. I would make that a condition of the sale.
With a single tube that problem goes away.
BG7JAA
电邮:bg7jaa@126.com
网站:www.amp.co.nf
也是他们愿意用一生去专注做一件事的信念和情怀。
手艺人往往意味着固执,缓慢,少量,劳作。
手把青秧插满田,
低头便见水中天。
心底清净方为道,
退步原来是向前。
离线王雷生
只看该作者 1楼 发表于: 2013-03-22
虽然看不懂 但是得顶老大下
呼号:BG6OJX
QQ:68330835
电话:19939000388
地址:河南 济源 沁园 南夫 胜利街北六巷四十六号
离线关则勇
只看该作者 2楼 发表于: 2013-03-22
回 王雷生 的帖子
王雷生:虽然看不懂 但是得顶老大下 (2013-03-22 20:23)
什么老大啊,就一微不足道的小HAM
BG7JAA
电邮:bg7jaa@126.com
网站:www.amp.co.nf
手把青秧插满田,
低头便见水中天。
心底清净方为道,
退步原来是向前。
离线BH4SQE
只看该作者 3楼 发表于: 2013-03-22
顶一下,走向世界,修成正果
这是对楼正多年付出的认可
[ 此帖被BH4SQE在2013-03-22 23:00重新编辑 ]
~~~~~~~~~广告位招租~~~~~~~~~
离线bl7ia
只看该作者 4楼 发表于: 2013-03-23
看来老外是想选 9500 了 ?
一胆好过两只胆
不知价格分别大不
K.C Yeung
只看该作者 5楼 发表于: 2013-03-24
87是一台值得崇拜的功放!
BD4AQR KF5GSV
离线BA5AC
只看该作者 6楼 发表于: 2013-03-24
貌似老关的选择非常明智,做单管2000W功放,不过 ........那个新版功放,也是两个FU250的呢?
[ 此帖被BA5AC在2013-03-24 08:59重新编辑 ]
浙江省杭州市临平区
吆三五88098920
古董ICOM IC-725 +C3S ANT ON AIR
只看该作者 7楼 发表于: 2013-03-24
一只管子的优势是不用选配。哪怕选配的两管并联的功放也需要2路分别的负栅压调定静态。我们的优势就是国产库存或者2手的管子,其实再要选配其实很麻烦,余地不大。
比如3个728并联做6KW的功放肯定比一只FU101做6KW的功放要难于处理自激等问题。
BD4AQR KF5GSV
