  • 5990阅读
  • 18回复
有谁用OPEN APRS的没有?我的iphone,ipadmini使用的时候,发现无法后台运行。 [复制链接]
离线BG4EBC
只看楼主 倒序阅读 0楼 发表于: 2013-03-11
— 本帖被 BA7CK 从 火腿神聊 移动到本区(2013-03-15) —
有谁用OPEN APRS的没有?
只有点击一次,上传一个点的数据。。。。。。
呜呜。昨晚注册的时候还花我4美刀。。。上当的感觉不好。
移动电话:要上酒要吃肉酒肉酒上酒!
离线bg6art
只看该作者 1楼 发表于: 2013-03-11
我在用,感觉巨费电
离线bg6art
只看该作者 2楼 发表于: 2013-03-11
目前主要在用ham tracker
离线BG4EBC
只看该作者 3楼 发表于: 2013-03-11
Re:有谁用OPEN APRS的没有?我的iphone,ipadmini使用的时候,发现无法后台运 ..
OpenAPRS iPhone Edition has been released!
OpenAPRS iPhone Edition Details:
OpenAPRS iPhone Edition brings the world of APRS right to your iPhone. Paired with iPhone's built in map engine, Internet connection and GPS, OpenAPRS gives you access to check your APRS messages, beacon your position and view other Amateur Radio operators anywhere in the world.
Send your position with any model iPhone by assisted GPS, cell phone triangulation or manual coordinate entry. Share your trip with your friends as they view you on their iPhones, APRS software connected to APRS-IS or on the OpenAPRS website.
第一版本说的是可以使用,自动信标的。。。。。。
再看看最新版本。。。。。
移动电话:要上酒要吃肉酒肉酒上酒!
离线BG4EBC
只看该作者 4楼 发表于: 2013-03-11
Q: Will iAPRS update my location automatically while I am moving?
A: NO. iAPRS is NOT meant to replace your mobile APRS transceiver. The intent is to provide a means of display (and location updating) for use when you reach a destination and wish to either post your location so other interested parties can see where you are, or for you to see who is nearby.
If iAPRS was used in a manner to duplicate the typical mobile APRS transceiver it would surely run the battery down in the iPhone, causing not only the iAPRS app to cease functioning in a relatively short period of time, but more importantly, it would cause the telephone functionality to no longer work sooner than you might like. The iPhone is, in reality, intended to be primarily a telephone.
This function will be available in a future release for those who don't worry about battery life.
Q: Can iAPRS post my location automatically on launch?
A: NO. You need to hit the 'LOCATE' button once iAPRS is ready in order to post your location.
The automatic posting on application startup was not included in order to give the user the ability to determine what location accuracy they wanted to send their location with. On initial startup the GPS takes a few seconds to lock onto the satellites, and this varies from location to location. If iAPRS posted it's location right away on startup it would often post a very poor location compared to the location that would be posted if there was a suitable delay for the GPS or cellphone triangulation to have it's time to work (and this time varies).
移动电话:要上酒要吃肉酒肉酒上酒!
离线BG4EBC
只看该作者 5楼 发表于: 2013-03-11
哎,说多了都是泪。。。。。。
移动电话:要上酒要吃肉酒肉酒上酒!
在线BG4UVR
只看该作者 6楼 发表于: 2013-03-11
iOS本身就不支持常规程序后台运行
离线BG4EBC
只看该作者 7楼 发表于: 2013-03-11
回 bg6art 的帖子
bg6art:目前主要在用ham tracker (2013-03-11 20:54)
这个软件我看了一下,主要发表的地方实在几个社交网站,也不是特别好吧?
移动电话:要上酒要吃肉酒肉酒上酒!
离线BG4EBC
只看该作者 8楼 发表于: 2013-03-13
不错。今天又花了25元买open aprs,满亏的。
如果有谷歌全开放,省事多了。
移动电话:要上酒要吃肉酒肉酒上酒!
离线BA1FB
只看该作者 9楼 发表于: 2013-03-13
回 BG4EBC 的帖子
BG4EBC:不错。今天又花了25元买open aprs,满亏的。
如果有谷歌全开放,省事多了。
 (2013-03-13 23:03)
下载安装了安桌上流行的纵横啊, MAPS, EARTH, TALK等爱疯版的软体, 谷歌纵横爱疯版好久谷歌都没更新了, 昨天刚安装时经常要重新输入谷歌账号, 今天好像不用了
73 de ba1fb
离线BG4EBC
只看该作者 10楼 发表于: 2013-03-13
回 BA1FB 的帖子
BA1FB:下载安装了安桌上流行的纵横啊, MAPS, EARTH, TALK等爱疯版的软体, 谷歌纵横爱疯版好久谷歌都没更新了, 昨天刚安装时经常要重新输入谷歌账号, 今天好像不用了 (2013-03-13 23:14)
根本收不到啊!谷歌系列。
移动电话:要上酒要吃肉酒肉酒上酒!
离线BA1FB
只看该作者 11楼 发表于: 2013-03-13
回 BG4EBC 的帖子
BG4EBC:根本收不到啊!谷歌系列。 (2013-03-13 23:25)
你要在手机上注册一个美国APPLE ID, 地址选美国就好,这样就可以安装谷歌系列的东东了
73 de ba1fb
离线BA1FB
只看该作者 12楼 发表于: 2013-03-13
注册APPLE ID的时候信用卡项选NONE, 这样就可免去信用卡资料并得到一个美国的APPLE ID
73 de ba1fb
离线BI7JTA
只看该作者 13楼 发表于: 2013-03-14
内容 用谷歌纵横吧,不过iphone纪录轨迹,纯粹蛋疼,apple不支持后台任务,地图类支持,但巨耗电,不多久电池发烫,不怕电池寿命变短,就玩吧
微信HAM友圈 38091476
离线BG4EBC
只看该作者 14楼 发表于: 2013-03-14
回 BI7JTA 的帖子
BI7JTA:内容 用谷歌纵横吧,不过iphone纪录轨迹,纯粹蛋疼,apple不支持后台任务,地图类支持,但巨耗电,不多久电池发烫,不怕电池寿命变短,就玩吧 (2013-03-14 00:43)
后台应该支持的。
我现在用的乐疯跑,联想出品的,就支持ios后台。。。。。。
移动电话:要上酒要吃肉酒肉酒上酒!
离线BG4EBC
只看该作者 15楼 发表于: 2013-03-14
强烈建议,那个免费的iaprs别用。便宜没有好货。
免费之后,需要验证呼号,三美刀。
功能受到限制,重新购买正版的付费的open aprs,再来25元钱。不如一步到位,只要25元钱!
移动电话:要上酒要吃肉酒肉酒上酒!
只看该作者 16楼 发表于: 2013-03-15
悲催的烂苹果
离线bg1lnv
只看该作者 17楼 发表于: 2013-03-31
4ebc,苹果设备想让程序真正后台运行,就要下载Backgrounder这个插件,地球人都知道
开车时想起一句话:北京的交通饿死过人。
离线BG6IVC
只看该作者 18楼 发表于: 2013-04-05
回 BG4EBC 的帖子
兄台,ios和乐phone是两回事
bg6ivc/1
最近想玩短波……
