  • 6145阅读
  • 10回复
有没有HAM使用计算机软件来解码和编码发送CW呢? [复制链接]
离线tanguanzhong
只看楼主 倒序阅读 0楼 发表于: 2012-11-10
  96年还是在大学时,使用过计算机发送CW。现在看见有可以解码的CW软件,有没有HAM使用计算机软件来解码和编码发送CW呢?
找到一款CW Decoder软件,不知道解码效果如何:
Introduction
Welcome to the CW DecoderXP program. This software was designed to allow CW operators to see, hear, and display as text CW signals from their receivers and to transmit CW using the serial port of the computer. This is accomplished by routing the audio from the receiver output to the audio (MIC In) input of the sound port of the computer.
Interface to the computer
Connecting the computer to the Receiver:
Connect the audio output of the radio (either the speaker or phones) to the microphone input on the computer. Some receivers have a separate line output on the back that can be used. Commercial interfaces are also available to connect your radio to the comptuer.
If you use the speaker output you then have the problem that the computer can receive the audio but you cannot hear the output. To solve this problem select from the file menu (of the CW Decoder program) the volume control option. If the volume control does not display the microphone slider section, select Option, then Properties. In the box that show the volume controls make sure that the microphone has been checked. Close the properties window. On the Master Volume window the microphone slider should now be visible. Un-mute the microphone and adjust the slider to maximum (later you may want to turn it back down). Close the Master Volume window. You should now be able to hear the audio from the radio through the computer speakers. Adjust the volume to a comfortable level.
Connecting the computer to the Transmitter:
If you are using Windows95, Windows98, and WindowsME, the printer port may be used to control the keying of a transmitter. Bit 0 (pin 2) or bit 1 (pin 3) can be used for control where a HIGH (voltage high) turns the transmitter on and a LOW (voltage low) unkeys the transmitter. The default printer address is 3BC hex, use the option function on the menu bar to change the address that corresponds to LP1 on the computer. Input the new LPT address in Hex format. It is recommended that optical isolation is used when interfacing to the transmitter to prevent RF feedback from entering the computer.
One of the serial communications ports COM1 through COM6 (serial ports 1 through 6 on the setup menu) may also be used to key the transmitter. These are the only modes available for WindowsXP, Windows2000, and WindowNT. Either the DTR (pin-4) or the RTS (pin-7) control line may be used, both are keyed at the same time. Pin 5 is ground (GND). Be sure to include a reverse diode on the input to the transistor (if used to enable a relay) to prevent reverse voltage breakdown of the device.
Commercial Products:
There are several commercial products that can be purchased to interface your radio to your computer. They provide an interface (including cables) for both the receive audio and the keying of the transmitter within the unit. Two popular products are the MFJ-1275 and the RIGblaster series. If you only have USB ports on your computer you will also need to buy a USB to Serial Port adapter ($35-$40) between the computer and the commercial product.
Other References:
There are also many articles in QST and QEX on interfacing your computer to your radio. Please use them as a resource.
BH7PRM  数据通信爱好者
QTH:广东深圳南山
YAESU450AT+WINDOM(40m/20m/10m/6m)+MOXON(6m)
email:tanguanzhong@gmail.com
中文地址:WWW.QRZ.CN
address:WWW.QRZ.COM
http://blog.sina.com.cn/bh7prm
只看该作者 1楼 发表于: 2012-11-11
人脑。。。。。。最好
离线bg2wvk
只看该作者 2楼 发表于: 2012-11-11
人脑总不用会锈豆的!支持人脑
CS:bg2wvk/qrp
QQ:376903921
ML:wybkaiyuan@163.com
QTH:辽宁省开原市
离线BD7IWW
只看该作者 3楼 发表于: 2012-11-11
楼主新来的。
本坛讨论n次啦。硬软都有,发还行,抄收没戏。
离线BD8ADT
只看该作者 4楼 发表于: 2012-11-11
收和发都用电脑永远也体会不到CW的乐趣
QQ:....- 232.....68----.
QQ群号(Elecraft & MR) 113481874
E-Mail:bd8adt@qq.com
RIG:K three,FT-817,
FTM350R,FT-8900,FT1D,DJ-G7
离线迷思
只看该作者 5楼 发表于: 2012-11-11
电脑发CW是没问题的,比赛的时候,很多人都是用电脑发的,但接收就不行了,信噪比比较低、或者发报的人手法不好的时候,电脑就没办法了。
曾用呼号:BG7KFZ
离线wd3010
只看该作者 6楼 发表于: 2012-11-11
电脑软件抄收自动键和电脑报不错
但是信号弱的时候以及手键发报就不沾了
DE BA3OT
离线BD2SHV
只看该作者 7楼 发表于: 2012-11-11
其实SDR的软件已经很强大了
Email:bg2shv@163.com
INFO: www.QRZ.com
QQ: 737O2636O
离线BH4BFS
只看该作者 8楼 发表于: 2012-11-11
最原始的通讯还是用最原始的大脑吧。这样下去我们也不用架天线玩短波了,直接电脑上互联网语音聊天得了。
离线迷思
只看该作者 9楼 发表于: 2012-11-12
如果想用电脑收发的话,完全可以用RTTY或者PSK31这类数据模式,没必要跟CW较劲,想用CW还是要练耳听、手发(比赛除外),这才是CW的强项和乐趣!
曾用呼号:BG7KFZ
离线BD5UYW
只看该作者 10楼 发表于: 2012-11-28
回 BH8ADT 的帖子
BH8ADT:收和发都用电脑永远也体会不到CW的乐趣 (2012-11-11 09:29)
是,CW的乐趣要动手!
现在电能解CW很容易实现,而且可以自动追码,自动适应,但这有意思?
绕这么大圈,如果用电脑,还不如用网络发个信息。
BD5UYW@厦门
