  • 6199阅读
  • 13回复
2014 WRTC 正式规则和台站设置草案发布 [复制链接]
离线BA5CW
只看楼主 倒序阅读 0楼 发表于: 2012-07-09
— 本帖被 BA7IO 设置为精华(2013-05-02) —
文件内容有o n s被过滤,我只好发个附件了,是英文的。 WRTC-2014-Rules-Final.pdf (57 K) 下载次数:11
离线BA5CW
只看该作者 1楼 发表于: 2012-07-09
Station Description
DRAFT DOCUMENT – NOT FINAL
This document describes the equipment that will be provided to teams for WRTC2014.
All competitors will be located in the same geographical region with similar topography. Competitor location-s will be separated by a minimum of 500 meters.
WRTC2014 will be a Field Day style competition. Equipment that will be installed by the organizers at each site:
•*42-foot tower with an antenna rotator and control unit.
•* 20/15/10 m Cycle 24 TX38 tri-bander with one feed line and PL-259 male connector. Antenna manual: http://www.cycle-24.com/tx38.html
•* 40 m Inverted-V dipole with feed line and PL-259 male connector.
•* 80 m Inverted-V dipole with feed line and PL-259 male connector.
•* 2 x 100 watt peak power monitors
Peak power monitors act on forward power only, which is greater than transmitted power when SWR > 1. In order to transmit 100 W to a mismatched antenna, an external tuner may be needed to bring the SWR down, thus avoiding premature triggering of the power monitor.
•* 2 PL259-PL259 jumpers for connecting peak power monitors.
•* 9’x 13′ Tent
•* 2 KW Power Generator with power cable going to the tent.
No Uninterruptable Power Supplies, 12 V accumulator batteries or similar power sources are allowed for power backup. Exception: built-in batteries in portable computers, audio recorder, or other peripherals. CMOS memory backup batteries are allowed.
•* 8 gallon-s of gasoline for generator
•1 ground rod driven nearby and connected to the generator and 1 ground rod with grounding strip driven nearby tent for inside connection.
•3 x 5-outlet 110VAC strips
•*2 electric lamps
•* 1 Electric Fan
•* 3 portable tables
•* 3 plastic chairs
•WC cabin with hand wash facilities
•8 gallon-s of drinking water
•Food and snacks
Competitors are not allowed to substitute equipment marked with an asterisk (*) with any other equipment unless permission is given by the organizing committee.
Since this is a field day style operation each team will have a generator which has to be filled with gasoline. To avoid team members spending their time re-filling the generator, the organizers will provide dedicated volunteers at every location to ensure the generator is kept running during the contest period.
Triplexer
It is highly recommended, but not required, that each team provide a “triplexer” device for the triband antenna. The function of the triplexer is to provide discreet band ouputs using one coaxial feed. This allows operation of the tri-band antenna on two bands simultaneously.
It is up to the team to provide such a device, but it must not amplify the signal in any way.
Example of triplexers for purchase can be found here:
http://www.inrad.net/files/Pubs/HF-Triplexer-Instruction-Manual.pdf
or
http://www.dunestar.com/dunestar-M333a1-manual.pdf
For details on building your own triplexer, refer to June 2010 QST “HF Yagi Triplexer Especially for ARRL Field Day”. By K6KV
Typical SWR vs. frequency curves for TX-38 tri-band antenna
TX-38 SWR 20 meters
TX-38 SWR 15 meters
TX-38 SWR 10 meters
离线BA5CW
只看该作者 2楼 发表于: 2012-07-09
天线版前几天有人问三工器哪里能卖,这里找到答案了
325美刀
195美刀
这个混合版的399美元,还是这个最实惠,因为单靠三工器隔离度是不够用的。
离线BA4TB
只看该作者 3楼 发表于: 2012-07-09
WRTC无兴趣,O.N.S可以有
离线bg5dml
只看该作者 4楼 发表于: 2012-07-09
O.N.S是什么?
BD5DML         ex: BG5DML
:132: CQ...CQ...
再CQ...
我爱CQ...
离线BG4HRM
只看该作者 5楼 发表于: 2012-07-09
回 bg5dml 的帖子
bg5dml:O.N.S是什么?[表情]  (2012-07-09 10:41)
“奥特曼(OUT MAN)”助我成长!
KX3  KXPA100  一根电线
HF第一射20110904
离线BG7BDB
只看该作者 6楼 发表于: 2012-07-09
这个真好。
姓名:刘德威 协会编号:71-57338 呼号:BG7BDB
手机:18673020005  QQ:505317999
收邮件地址:湖南省临湘市五新不锈钢制品有限公司
离线BA1RB
只看该作者 7楼 发表于: 2012-07-10
"Field Day style competition"....  下次主办一个“QRP style competition”,每人一块太阳能电池板。
离线BA5CW
只看该作者 8楼 发表于: 2012-07-13
今年IARU HF 有13支队伍参加WRTC测试赛
The callsigns to be used by the WRTC test sites are:
K1GQ
K1RQ
K1ZD
N2KW
N9NB
NI1L
W1HH
W1MA
W1MJ
W1SJ
W1UE
W1UJ
WB1Z
北美洲以外的通到最多的参赛队波段/模式的前3名,奖励一件WRTC-T恤
任何人通到4个以上的波段/模式有鼠标垫和帽子奖励(抽奖?)我理解得不太确切,请英文好的帮忙看看:
具体可以访问http://www.wrtc2014.org/wrtc2014-station-test-in-iaru-hf-championship/
离线BA5CW
只看该作者 9楼 发表于: 2012-07-13
•A WRTC T-shirt will be awarded to the 5 callsigns (outside W1) that work the WRTC test stations on the most band-modes.
•A WRTC T-shirt will be awarded to the 3 callsigns outside North America that work the WRTC test stations on the most band-modes.
•Everyone who works the WRTC test stations on 4 or more band-modes will be entered into a drawing to win a WRTC mouse pad or hat. Ten winners will be drawn.
离线BG4ACE
只看该作者 10楼 发表于: 2012-07-13
通4个以上的可以有资格抽奖,奖品有WRTC鼠标垫或者帽子,共10名
离线BA5CW
只看该作者 11楼 发表于: 2012-07-13
回 BG4ACE 的帖子
BG4ACE:通4个以上的可以有资格抽奖,奖品有WRTC鼠标垫或者帽子,共10名 (2012-07-13 01:38)
谢谢,今早起来一看,这两句话写得很清楚,昨天睡觉前脑子确实浆糊,读了两边愣是没看懂
离线vr2ung
只看该作者 12楼 发表于: 2012-07-13
感謝分享...
73
VR2UNG M0UNG XX9TUN
居安思危, 熱心ARES, 做個開心真火腿^_^^_^^_^
离线BG2ITG
只看该作者 13楼 发表于: 2012-07-14
散播毒品
害死人不偿命
