  • 4162阅读
  • 2回复
N1MM 2012 05月08号上来的12.05.01升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2012-05-14
没装过n1mm的请先下载主程序安装後再安装下面的升级版
N1MM-FullInstaller.exe
升级版本
N1MM-newexeV12.05.01.exe
QQ:....- 232.....68----.
QQ群号(Elecraft & MR) 113481874
E-Mail:bd8adt@qq.com
RIG:K three,FT-817,
FTM350R,FT-8900,FT1D,DJ-G7
离线BD8ADT
只看该作者 1楼 发表于: 2012-05-14
Force Mults window to stay closed. (Attempt #2) (W1RM) (Coded by N1MM)
New contest UA2 Qso Party (UA2QP) added (R1DX, UA2FB). (coded by NA3M)
UA1DZ Cup: corrections to score calculation (RA3FD). (coded by NA3M)
ARIDX contest: multiplier names were swapped in Score window (DXC, Pro), the Received number column was not present in the LOG window (IN3VVK). (coded by NA3M)
Digital - Corrects issue of wrong serial number being sent when using SO2R and switching focus back to second radio and sending exchange. (Coded by N2AMG)
When exting config or resetting radio's supresses Port already open msgbox when MMTTY or MMVARI engines are loaded. (Coded by N2AMG)
QSO Party: Contacts made on AM are not scored properly. (AJ4LN)(coded by K3CT)
QSO Party Enhancement: If the callsign ends with /county and the exchange box is empty, validate the county and populate the exchange box with the county when the cursor leaves the callsign field. (coded by K3CT)
RIG:K three,FT-817,
离线BG8BSX
只看该作者 2楼 发表于: 2012-05-17
LZ是位好同志啊!
