  • 6460阅读
  • 18回复
大炮来了! [复制链接]
离线BD7CE
只看楼主 倒序阅读 0楼 发表于: 2003-03-17
还处于待组装状态,拍几张照片留作纪念。
所有零件:
traps:
附件:
近距离看材质:
改进后的喉箍:
离线Mac
只看该作者 1楼 发表于: 2003-03-17
这个大炮如何?
离线Mac
只看该作者 2楼 发表于: 2003-03-17
2
离线Mac
只看该作者 3楼 发表于: 2003-03-17
朋友的车载短波天线,自带天调,约3米左右,加拿大出品,联合国军使用。
离线BG1CAT
只看该作者 4楼 发表于: 2003-03-17
离线ba6ig
只看该作者 5楼 发表于: 2003-03-17
最初由 mac 发布
7000元左右的车载天线:宝丽510
在线bd8uk
只看该作者 6楼 发表于: 2003-03-17
bd7ce!向我开炮!:d :d :d
离线Mac
只看该作者 7楼 发表于: 2003-03-18
最初由 bg1cat 发布
能简单介绍一下吗?价格,指标等。谢谢
据说是 10000元左右。
codan 9350 automatic tuning whip antenna
  the 9350 antenna is constructed to withstand the severe environmental conditions usually experienced in some of the more remote areas of the world. it meets or exceeds the shock and vibration requirements for mil-std-810.
the main antenna section is constructed of fibreglass reinforced nylon. this provides a weatherproof housing for the control and tuning devices, which are fitted inside. it is mounted on an anti-vibration base that incorporates rubber mounts. these are designed to withstand the conditions likely to be met while travelling on unsealed roads or tracks. the 9350 antenna will operate in a broad range of temperatures.
typically, the 9350 takes only a few seconds to tune to any frequency. it will seek the optimum tuning point for all operating conditions-this ensures the best communications possible. the 9350 antenna has a comparably high rate of radiation efficiency. it is rated for maximum voice power of 125 watts pep. the whip antenna uses a microprocessor controlled stepper motor to provide continuous tuning to any required frequency over the transmit/receive operating range of 2-30 mhz.
two whip top sections are provided with the 9350 antenna. the standard or primary whip is a wire that is encased in a polyurethane covered fibreglass rod. it is designed to withstand substantial flexing and hard knocks and operates over the full frequency range of this antenna. the shorter, secondary whip is manufactured from stainless steel. it is designed for use as a backup in emergency situations when the standard whip has been damaged. this whip is only suitable for operation over a transmit frequency range of 2.5-30 mhz and is less efficient than the primary whip.
when in scan or free tune receiver mode, a broadband amplifier is activated. this makes the antenna sensitive to even the weakest signals over the entire frequency range.
technical specifications
  nvis kit
the near vertical incidence skywave (nvis) kit is an add-on accessory for the codan 9350 antenna. short vertical whip antennas are poor radiators at high take-off angles. this makes short distance communications difficult, especially so in hilly terrain. making the whip longer and more horizontal improves the high take-off angle radiation efficiency.
key features
improves short-range communications
transmit and receive paths over the range of 20-500 kms will be greatly improved with the addition of this kit.
easily attached to variety of vehicles
the nvis kit can be quickly and easily attached to a wide variety of vehicles. all fitting instructions are provided-no special tools are required.
additional features
rugged design
the tough design of the nvis has been proven through extensive field testing.
easy to transport
it is supplied in a canvas bag for ease of transportation.
note: the frequency range of the nvis kit is 1.6-12 mhz.
frequency range
primary whip top - transmit operation: 2-30 mhz
secondary whip top - transmit operation: 2.5-30 mhz
receive-only (scan mode/free tune receiver mode): 250 khz - 30 mhz
power rating
125 watts pep (voice)
power consumption
static: 150 ma
tuning: 1 a
(12 v dc nominal-supplied from the transceiver)
input impedance 50 ohms: vswr typically 1.5:1
temperature -40_c to +60_c
tuning speed 5.5 seconds over full range 2-30 mhz (typically 2 seconds for generally used operating range e.g. from 3-7 mhz or 7-22 mhz)
size and weight primary whip: 2.47 m, 5.8 kg
离线BD7CE
只看该作者 8楼 发表于: 2003-03-18
我的大炮只引来两门超级小钢炮?
离线Mac
只看该作者 9楼 发表于: 2003-03-18
最初由 bg1cat 发布
能简单介绍一下吗?价格,指标等。谢谢
据说是 10000元左右。
  nvis kit
key features
additional features
rugged design
easy to transport
frequency range
power rating
power consumption
static: 150 ma
tuning: 1 a
离线BD6IDC
只看该作者 10楼 发表于: 2003-03-19
Re: 大炮来了!
最初由 bd7ce 发布
还处于待组装状态,拍几张照片留作纪念。
改进后的喉箍:
bd7ce,请问你的天线是不是从ba4ed那里买来的ed5dx???架上后能不能来些照片?我对这个天线很感兴趣。
在线bd8uk
只看该作者 11楼 发表于: 2003-03-19
bd7ce的yagi就是在ba4ed那里买的!
只看该作者 12楼 发表于: 2003-03-19
好啊
总算等到了,恭喜!
离线BD7CE
只看该作者 13楼 发表于: 2003-03-19
是ba4ed生产的ed4dx,三波段4单元(14/21/28),类似 a4s 的一种天线。
装好后准备全方位拍照公布,泄漏4ed的技术秘密,哈哈。。。
不过问题是我没钱做铁塔了,只怕拍到了下面会很难看哦,还有,适合省
内通联的7mhz,还是只能用倒v,不能用大炮轰击bd7ck了。。。
在线bd8uk
只看该作者 14楼 发表于: 2003-03-19
最初由 bd7ce 发布
要想轰7ck很简单啊!嘿嘿,找4ed再订一副三单元的7mhz yagi不就行了吗?
在线BA4XA
只看该作者 15楼 发表于: 2003-03-19
Re: 大炮来了!
[quote]最初由 bd7ce 发布
还处于待组装状态,拍几张照片留作纪念。
不错不错,ed现在出的工艺及包装比我们当时的好得多了,有进步啊!!
trap有十个,是ed4dx-1吧,
8uk啊,你的7mhz的三单元天线来了吗?
在线bd8uk
只看该作者 16楼 发表于: 2003-03-19
Re: Re: 大炮来了!
最初由 bd4xa 发布
[quote]最初由 bd7ce 发布
还处于待组装状态,拍几张照片留作纪念。
trap有十个,是ed4dx-1吧,
暂时退订了,4ed太忙,等他有时间再请他给我做啦!
离线BA7EI
只看该作者 17楼 发表于: 2003-03-19
最初由 bd7ce 发布
我的大炮只引来两门超级小钢炮?
棒!
漂亮!
7mhz由于干扰大,最需要用高增益天线发射, 建议再搞个三单元7mhz原尺寸八木,加个1600w功放,但由于种种原因,导致损耗太大,传输到天线只剩余100w的发射功率,也就是说只能报发射功率100w了;如果您考取ba,水平提高,则1600w经过馈线、天调损耗后还剩1000w到天线。此时此刻,指哪儿打哪儿,那时候与你通联是一种享受,再不用担心自然的和人为的干扰。   :d :d :d :d :d
在线bd8uk
只看该作者 18楼 发表于: 2003-03-19
最初由 bd7ei 发布
棒!
漂亮!
嘿嘿,俺对此深有感触……。
