  • 2874阅读
  • 0回复
aprs请教 [复制链接]
离线BG4KLA
只看楼主 倒序阅读 0楼 发表于: 2012-04-14
诸位老师这个是什么问题?
  Status - Log
APRS4R
Status
Startup
Profile
Log
Debug
Setup
Devices
Beacons
Digipeater
Weather
Misc
Admin
Password
Update
APRS4WEB
Setup
Daten-Log
                [LOG] 2012-04-14 21:48:14 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:48:14 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:48:44 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:48:44 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:49:14 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:49:14 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:49:44 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:49:44 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:50:14 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:50:14 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:50:44 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:50:44 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[WARN] 2012-04-14 21:50:50 KISSSerialConnection:: readFrame: ex: execution expired[LOG] 2012-04-14 21:51:14 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:51:14 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:51:44 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:51:44 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:52:14 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:52:14 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:52:44 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:52:44 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:53:14 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:53:14 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:53:44 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:53:44 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:54:14 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:54:14 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:54:44 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:54:44 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:55:14 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:55:14 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:55:44 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:55:44 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[WARN] 2012-04-14 21:55:56 KISSSerialConnection:: readFrame: ex: execution expired[LOG] 2012-04-14 21:56:14 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:56:14 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:56:44 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:56:44 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:57:14 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:57:14 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:57:44 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:57:44 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:58:14 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:58:14 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:58:44 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:58:44 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:59:14 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:59:14 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:59:44 BeaconPlugin:: sending beacon on device is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )[LOG] 2012-04-14 21:59:44 SocketSendThread:: message send on is0: BG4KLA-10 -> AP4R10 via []: (!3731.05N/12206.07ErWeiHai, Route IGate 144.640Mhz )
Fehler-Log
                [ERROR] 2009-02-06 10:49:29 KISSSerialConnection:: Error reading configuration: undefined method `to_i' for true:TrueClass[WARN] 2009-02-06 10:49:29 ISSocket:: initClientSocket::ex: getaddrinfo: Unknown error[ERROR] 2009-02-06 10:49:32 PluginManager:: error loading plugin: wmr plugin, ex: No such file or directory - /dev/usb/tts/1[ERROR] 2009-02-06 10:49:32 PluginManager:: (eval):3:in `create'(eval):3:in `new'/usr/lib/ruby/1.8/aprs4r/WMRWeatherPlugin.rb:55:in `setup'/usr/lib/ruby/1.8/aprs4r/PluginManager.rb:158:in `setup_plugin'/usr/lib/ruby/1.8/aprs4r/PluginManager.rb:72:in `start'/usr/lib/ruby/1.8/aprs4r/PluginManager.rb:61:in `each'/usr/lib/ruby/1.8/aprs4r/PluginManager.rb:61:in `start'/usr/lib/ruby/1.8/aprs4r.rb:140[ERROR] 2009-02-06 10:49:32 APRSCall:: empty call[WARN] 2009-02-06 10:49:34 ISSocket:: initClientSocket::ex: getaddrinfo: Unknown error[WARN] 2009-02-06 10:49:39 ISSocket:: initClientSocket::ex: getaddrinfo: Unknown error[WARN] 2009-02-06 10:49:44 ISSocket:: initClientSocket::ex: getaddrinfo: Unknown error[WARN] 2009-02-06 10:49:49 ISSocket:: initClientSocket::ex: getaddrinfo: Unknown error[WARN] 2009-02-06 10:49:55 ISSocket:: initClientSocket::ex: getaddrinfo: Unknown error[WARN] 2009-02-06 10:50:00 ISSocket:: initClientSocket::ex: getaddrinfo: Unknown error[WARN] 2009-02-06 10:50:05 ISSocket:: initClientSocket::ex: getaddrinfo: Unknown error[WARN] 2009-02-06 10:50:10 ISSocket:: initClientSocket::ex: getaddrinfo: Unknown error[WARN] 2009-02-06 10:50:15 ISSocket:: initClientSocket::ex: getaddrinfo: Unknown error[WARN] 2009-02-06 10:50:20 ISSocket:: initClientSocket::ex: getaddrinfo: Unknown error[WARN] 2012-04-14 21:45:43 KISSSerialConnection:: readFrame: ex: execution expired[WARN] 2012-04-14 21:50:50 KISSSerialConnection:: readFrame: ex: execution expired[WARN] 2012-04-14 21:55:56 KISSSerialConnection:: readFrame: ex: execution expired
谢谢!
姓名----于永伟
呼号----BG4KLA(BD4KM)
电话----要八九六三要三齐齐baba
卡片邮寄地址--威海市田村73号信箱
地址----山东省威海市渔港路38号中华保险
欢迎到威海做客
威海马可尼无线电俱乐部BY4IB
威海MRC中继台信息:
呼号:BR4IW
台标:60/120分钟发射CW
Email:呼号@chinaham.org
威海HAM基地:高区沈阳路垛山一品雅苑2号楼
