  • 6099阅读
  • 21回复
aprs4r 设置完后 有一个错误 请教 [复制链接]
离线bg9cjh
只看楼主 倒序阅读 0楼 发表于: 2012-03-12
如题 (设备h618b to++小板 857)
头大了 咋都整不好
[error] 2009-12-29 2314 kissserialconnection:: error reading configuration: undefined method `to_i' for true:trueclass
          [warn] 2009-12-29 2314 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [log] 2009-12-29 2317 beaconplugin:: sending beacon on device is0: bd9cjh-10 -> ap4r10 via [wide1-1]: (!3414.14n/10858.99e#phg5438aprs4r@igate 144.460mhz)
          [log] 2009-12-29 2318 beaconplugin:: sending beacon on device rf0: bd9cjh-10 -> ap4r10 via [wide1-2]: (!3414.14n/10858.99e#phg5438aprs4r@igate 144.460mhz)
          [log] 2009-12-29 2318 socketsendthread:: message send on rf0: bd9cjh-10 -> ap4r10 via [wide1-2]: (!3414.14n/10858.99e#phg5438aprs4r@igate 144.460mhz)
          [warn] 2009-12-29 2319 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [warn] 2009-12-29 2324 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [warn] 2009-12-29 2329 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [warn] 2009-12-29 2334 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [warn] 2009-12-29 2339 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [warn] 2009-12-29 2344 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [log] 2009-12-29 2348 beaconplugin:: sending beacon on device rf0: bd9cjh-10 -> ap4r10 via [wide1-2]: (!3414.14n/10858.99e#phg5438aprs4r@igate 144.460mhz)
          [log] 2009-12-29 2348 socketsendthread:: message send on rf0: bd9cjh-10 -> ap4r10 via [wide1-2]: (!3414.14n/10858.99e#phg5438aprs4r@igate 144.460mhz)
          [warn] 2009-12-29 2349 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [warn] 2009-12-29 2354 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [warn] 2009-12-29 2359 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [warn] 2009-12-29 2304 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [warn] 2009-12-29 2309 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [warn] 2009-12-29 2335 issocket:: initclientsocket::ex: getaddrinfo: unknown error
          [warn] 2009-12-29 2340 issocket:: initclientsocket::ex: getaddrinfo: unknown error
离线BG6JJI
只看该作者 1楼 发表于: 2012-03-12
是取得不了服务器地址,请将你服务器设置部分贴上来。谢谢
离线BG4BWP
只看该作者 2楼 发表于: 2012-03-12
igate 144.460mhz,频率部分是否笔误了?
离线bg9cjh
只看该作者 3楼 发表于: 2012-03-12
[warn] 2009-12-29 23[表情]19 issocket:: initclientsocket::ex: getaddrinfo: unknown error
谢谢6jji,一会下班回去贴上来
离线bg9cjh
只看该作者 4楼 发表于: 2012-03-12
哈哈 的确。折腾几遍都快弄糊涂了,谢谢提醒
离线bg9cjh
只看该作者 5楼 发表于: 2012-03-12
全部贴上来 还有哪不合适, 请6jji指导,
谢谢
离线BG6JJI
只看该作者 6楼 发表于: 2012-03-12
只要is0的设置,别的不要,另外你确定路由能上网吗?
is0的设置看不清,您可以改一下服务器试试。
离线bg9cjh
只看该作者 7楼 发表于: 2012-03-13
6jji,首先感谢你的热情答复 呵呵
618b应该是可以上网的。我采用二级路由结构,618blan口连接一级路由,在lan口同时连接的电脑是可以上网的(618b相当于交换机使用)。
is0
服务器:china.aprs2.net, hangzhou.aprs2.net
端口:14580
离线BG6JJI
只看该作者 8楼 发表于: 2012-03-13
6jji,首先感谢你的热情答复 呵呵
is0
端口:14580
这个结构不对啊,618b的lan口连上级,把它当交换机用是可以,但是618b就不能上网了啊。所以它连不上服务器。
离线bg9cjh
只看该作者 9楼 发表于: 2012-03-13
呵呵 那回去接wan。另外您看看别的设置有没问题啊
另外,618bwifi是打开的,可就是搜不到信号,是不是也是这个原因造成的?或者缺什么驱动软件?请教
离线BG6JJI
只看该作者 10楼 发表于: 2012-03-13
wifi打开,还有其他一些相关设置需要设置。跟wan口没什么关系。
目前看没有什么问题。就是交换模块把路由器撇开了。所以路由器自己上不了网
离线BG4BWP
只看该作者 11楼 发表于: 2012-03-13
好了吗? 还没好我把我的配置导出给你,你导入即可,自己修改呼号和坐标
附件: gateway.zip (0 K) 下载次数:20
离线BG4BWP
只看该作者 12楼 发表于: 2012-03-13
接口不一样,我是usb的,你去掉端口中的usb,保持你现在的/dev/tts/0
离线bg9cjh
只看该作者 13楼 发表于: 2012-03-14
非常感谢4bwp 导入文件ok了,谢谢 谢谢。现在就是解决二级路由上网的问题ing......
一级路由192.168.0.1 一级lan网线连接二级wan口。二级路由wan、lan咋设置?试了若干次重刷了若干次还是没得法
还是前辈们厉害 呵呵。直接给我说哪个空填多少吧 谢谢啦
今天没连接电台,在单位一级路由上网:
          [log] 2009-12-29 2336 beaconplugin:: sending beacon on device is0: bd9cjh-10 -> ap4r10 via []: (!3413.78n/10859.14e#aprs igate @ 144.640 1200bps)
          [log] 2009-12-29 2336 socketsendthread:: message send on is0: bd9cjh-10 -> ap4r10 via []: (!3413.78n/10859.14e#aprs igate @ 144.640 1200bps)
          [log] 2009-12-29 2305 socketrecvthread:: message recv on is0: bg0ge-10 -> ap4r10 via [tcpip*, qac, t2fz]: (!3417.66n/10853.52e&phg5390xi'an aprs@igate 144.640mhz)
          [log] 2009-12-30 0005 socketrecvthread:: message recv on is0: bg0ge-10 -> ap4r10 via [tcpip*, qac, t2fz]: (!3417.66n/10853.52e&phg5390xi'an aprs@igate 144.640mhz)
          [log] 2009-12-30 0032 socketrecvthread:: message recv on is0: bg0ge-12 -> apot21 via [wide1-1, wide2-1, qas, bg0ge-10]: (!3417.66n/10853.52e_)
          [warn] 2009-12-30 0033 kissserialconnection:: readframe: ex: execution expired
          [log] 2009-12-30 0036 beaconplugin:: sending beacon on device is0: bd9cjh-10 -> ap4r10 via []: (!3413.78n/10859.14e#aprs igate @ 144.640 1200bps)
          [log] 2009-12-30 0036 socketsendthread:: message send on is0: bd9cjh-10 -> ap4r10 via []: (!3413.78n/10859.14e#aprs igate @ 144.640 1200bps)
          [log] 2009-12-30 0029 socketrecvthread:: message recv on is0: bg0ge-12 -> apot21 via [wide1-1, wide2-1, qas, bg0ge-10]: (!3417.66n/10853.52e_)
          [log] 2009-12-30 0056 beaconplugin:: sending beacon on device rf0: bd9cjh-10 -> ap4r10 via [wide2-2]: (!3413.78n/10859.14e#aprs igate @ 144.640 1200bps)
          [log] 2009-12-30 0056 socketsendthread:: message send on rf0: bd9cjh-10 -> ap4r10 via [wide2-2]: (!3413.78n/10859.14e#aprs igate @ 144.640 1200bps)
          [warn] 2009-12-30 0039 kissserialconnection:: readframe: ex: execution expired
离线BG6JJI
只看该作者 14楼 发表于: 2012-03-14
二级路由wan口选dhcp,lan确认一下不在192.168.0.x   设置为192.168.1.x即可。其他不变
离线BG4BWP
只看该作者 15楼 发表于: 2012-03-14
我和你一样二级,wan口联一级路由。ip选自动,dhcp开启,没啥特别设置,如还不行我把路由设置也导出给你导入
离线bg9cjh
只看该作者 16楼 发表于: 2012-03-16
618b工作正常了!感谢bg0ge bg4bwp bg6jji(排名不分先后)的热情指导!真是听君一句话,少读几本书啊
下一步工作:
1、857或手台连接线(目前用的鼠标线剪断 好像和857接口不配,只有到电子市场去淘了)
2、设置8gr测试
再次感谢老大们的热情指导!谢谢
离线bg5cdi
只看该作者 17楼 发表于: 2012-03-16
857不是很合适,建议别折腾了
离线bg9cjh
只看该作者 18楼 发表于: 2012-03-16
857不是很合适,建议别折腾了
谢谢 。临时用857测试的 上v段车台必须的
这会好像又问题了 ,回家再看看吧 呵呵
离线BH1DDU
只看该作者 19楼 发表于: 2012-03-30
我也遇到了相同的问题,经过修改配置文件内容(根据bg4bwp上传的我文件),貌似我的igate可以工作了。
目前问题就是需要知道我igate的坐标,现在虽然我身在帝都,但是地图上我是在魔都。。。
有啥方法能取到这些数据?我用的是马工的51tnc,没有gps。。。
