  • 4307阅读
  • 4回复
N1MM 2012 02月28号上来的12.02.03升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2012-02-29
没装过n1mm的请先下载主程序安装後再安装下面的升级版
n1mm-fullinstaller.exe
升级版本
n1mm-newexev12.02.03.exe
离线BD8ADT
只看该作者 1楼 发表于: 2012-02-29
arrl160 contest: correction when determining the us multiplier, populate the ve exchange, and correct a call history bug. (coded by k3ct)
cqww160 contests: correct color errors. (n4zr) (coded by k3ct)
pass macro bug: the pass macros using band do not work ( example: {pass 7000} ). allow mixed case macro name {pass} for all pass macros. (n3rd)(coded by k3ct)
digital - when aborting xmit when using mmtty, tells mmtty to flush the buffer when going back to rx. (coded by n2amg)
uksmg contest: changed to cabrillo 3.0 by sponsor request. (g8fxm) (coded by na3m)
nc qso party: calls ending with /4, /qrp, /nc scored with zero points. (n4cw)(coded by k3ct)
离线BG1TXU
只看该作者 2楼 发表于: 2012-03-01
升级真够频繁地
离线bg4wen
只看该作者 3楼 发表于: 2012-03-01
不知道何时才能升级到控制ts-590 cw部分,唉,漫长的等待~
离线BA8AT
只看该作者 4楼 发表于: 2012-03-08
升哦。。。。。。。
