  • 4132阅读
  • 1回复
N1MM 2012 02月21号上来的12.02.02升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2012-02-22
没装过n1mm的请先下载主程序安装後再安装下面的升级版
n1mm-fullinstaller.exe
升级版本
n1mm-newexev12.02.02.exe
离线BD8ADT
只看该作者 1楼 发表于: 2012-02-22
hide off times button in contest selection dialog until some contest requires it in cabrillo 3.0 (n4zr) (coded by n1mm)
digital - digital call stacking-corrects grabbing calls not on the stack frequency when popping calls off stack.(coded by n2amg)
digital - corrects rt91 error seen occasionally when having calls on the stack.(coded by n2amg)
digital - corrects rt error if mmtty is not found in directory shown in setup. (coded by n2amg)
digital - corrects stuttering of rtty and dropping of ptt when using multiple f-key presses. (coded by n2amg)
general - corrects export of macros to include the comments stored in them. (coded by n2amg)
digital - adds new method of popping calls off call stack called "fifo mults first" when selected multipliers will be taken off stack first by their mult status and in first in first out order. higher number of mults comes off first. (coded by n2amg)
bug: problem with station classification (multi-op, multi-two, multi-multi) when cqcontest.ru on-line contest score server is used (w1uj, rw4wm) (coded by na3m)
bug: ref contest, column names corrected in the score summary window (coded by na3m)
link to the rules updated for ref and uba contests (coded by na3m
