  • 4467阅读
  • 3回复
N1MM 2012 02月14号上来的12.02.01升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2012-02-16
没装过n1mm的请先下载主程序安装後再安装下面的升级版
n1mm-fullinstaller.exe
升级版本
n1mm-newexev12.02.01.exe
离线BD8ADT
只看该作者 1楼 发表于: 2012-02-16
nc qso party: changed to cabrillo 3.0 to support the expedition entry class.(w4mps)(coded by k3ct)
va qso party: changed the start / stop times and switched to cabrillo 3.0 to support the new entry class. (w4mya)(coded by k3ct)
nj qso party: many changes in the rules. same weekend as marac state party. nj users can log out-of-state qso's with the two or six character marac exchanges. out-of-state users that want to send logs to both qso parties should use the marac qso party selection. the nj qso party will accept the marac cabrillo and rescore. needs testing as in-state, out-of-state, and rover. (k2qpn)(coded by k3ct)
vt qso party: many changes in the rules. needs testing as in-state, out-of-state, and rover. (w1sj)(coded by k3ct)
rover mode: rover mode is now enabled when the station category is set to expedition.(coded by k3ct)
macro: added {longpath} which turns the rotor to the long path beam heading. (nd8l)(coded by k3ct)
bug: import of .trn files created by old versions (11.11.04 or older) does not work (ux1il) (coded by na3m).
russian psk ww contest (rusdxpsk): rules link changed. (coded by na3m)
initialize the operator correctly when the station info is changed after a new installation (n9ljx) (coded by n2ic).
available window operation now supports double-clicking on a call to populate the callsign field in the entry window. this makes the bandmap and available window operations the same - a single click places the call in the "on call" frame, and a double click places the call in the callsign field. (w5gn) (coded by n2ic).
digital - corrects error when in so2v and grabbing call while entry window b has focus.(coded by n2amg)
digital - corrects {profile0} from resetting audio freq. until mmtty stops transmitting.(coded by n2amg)
离线BG0ABL
只看该作者 2楼 发表于: 2012-02-17
提示:原安装包内有木马病毒
离线BA8AT
只看该作者 3楼 发表于: 2012-02-19
提示:原安装包内有木马病毒
我的360也有反映,不管他,添加到信任即可
