  • 4074阅读
  • 1回复
N1MM 2012 02月07号上来的12.02.00升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2012-02-09
没装过n1mm的请先下载主程序安装後再安装下面的升级版
n1mm-fullinstaller.exe
升级版本
n1mm-newexev12.02.00.exe
离线BD8ADT
只看该作者 1楼 发表于: 2012-02-09
make # a comment when at the beginning of a function key label. this is to support in-line comments in function key files. (coded by n1mm)
add filter blacklisted packet spots back to packet filter menu (n4zr) (coded by n1mm)
digital - when pressing clearrx or using {clearrx} macro the rx window buffer is no longer cleared.(coded by n2amg)
digital - adds a new menu selection when right clicking in the rx window to empty the rx windows buffer.(coded by n2amg)
digital - when searching for calls in garbage and using highlight background of calls , calls found will have their foreground text colored but not the background highlighted as a work around for an issue in the api call(coded by n2amg)
digital - reworks macro load routines to allow for # comments not to be loaded into the macro buttons. (coded by n2amg)
nh qso party: rules change. added two callsigns to the special qso points list. (n1ix)(coded by k3ct)
mcc qso party: rules change. bonus points calculation, changed start & stop times, removed band change timer in multi-one. (ve1nb)(coded by k3ct)
arrl rtty: the call history state field information is stored in the contest log sect field instead of the qso exchange information. (ww3s)(coded by k3ct)
az, co, mn qso party: the cabrillo output, sent name column isn't wide enough for long station operator names. (k0rc)(coded by k3ct)
bug fix: xertty contest, column names corrected in the score summary window (ja7zp) (coded by na3m)
udc, “/qrp” can be used in the bonuspoints parameter (g4ogb) (coded by na3m)
