  • 3090阅读
  • 1回复
2YF看过来:多个OT2m中继的冲突避免讨论 [复制链接]
离线BD6CR
只看楼主 倒序阅读 0楼 发表于: 2012-02-07
the quiet time setting does apply before digipeating. bob bruninga's concept actually depends on fratricide between digipeaters and the fm capture effect, but there's some debate as to how effective that is.
scott
on 2/5/2012 11:11 pm, adam rong wrote:
> thanks. another thought, can we set quiet time between digi rx and tx? i
> mean, even there is csma/ca, it is still possible to have conflict. if i
> can set quiet time between rx and tx, we can set a fast digi and a slow
> digi, so there is little chance to conflict.
> 2012/2/5 scott miller <scott@argentdata.com <mailto:scott@argentdata.com>>
>   you can use the alias wide1 if you just want it to be a fill-in.
>   otherwise use wide and set the hop limit to what you want.
>   on 2/3/2012 3:32 am, adam rong wrote:
>     > scott,
>     > since most of the users will set path as wide1-1,wide2-1 or wide2-2,
>     > what is your recommendation to set fill-in digi and wide digi if both
>     > are in one area?
>     > thanks,
>     > adam
离线BG2YF
只看该作者 1楼 发表于: 2012-02-07
谢谢分享!
