  • 5865阅读
  • 3回复
你会调天调吗?先试试这个天调模拟软件吧。 [复制链接]
离线net2000
只看楼主 倒序阅读 0楼 发表于: 2012-01-31
天调模拟软件,T形网络,调电容和电感试试,看看你能不能把驻波调到1,同时天调插入损耗最小。
http://fermi.la.asu.edu/w9cf/tuner/tuner.html
proper way to adjust a t-network tuner
there is little change in efficiency or performance over a wide range of q's. this is because loss is very low, so even doubling loss makes very little difference in power. doubling loss will of course double heat, but the larger problem is the increase in capacitor voltages. arcing can cause a tuner to fail even while loss in signal level is totally undetectable at the other end of a qso. arcing is a fast failure and very destructive, because it produces localized heating. besides increasing voltages and heat, increasing q also decreases bandwidth. this means a tuner requires more frequent retuning when operating frequency is changed within a band.
in order to minimize the need to retune and maximize the power rating of a tuner, it is necessary to tune or match with the minimum possible operating q. in a t-network, we want minimum inductance and somewhere around the maximum possible capacitance that allows a good match. the quickest way to damage a switch or capacitor in a tuner is to adjust the tuner with too much inductance.
the worse advice, when tuning a t network tuner, is to start with the capacitor mid-way and adjust the inductor for maximum noise or minimum swr. on lower bands the capacitors should be set to maximum capacitance as a starting point. normally halfway open is a good place for the higher bands, typically 15 meters and higher in a 160-10 meter tuner.
the best starting places for capacitors would be:
160-80 meters=fully meshed
60-20 meters=3/4 meshed
20-10 meters=1/2 meshed
离线cnnets
只看该作者 1楼 发表于: 2012-02-01
做这个天调也不错。
离线BG9OF
只看该作者 2楼 发表于: 2012-02-02
首先输入输出电容都最大,然后调整电感寻找驻波低点,找到后减小输入电容增大电感,直到驻波1.0调谐完成。
离线黄小江
只看该作者 3楼 发表于: 2015-02-13
以前用过,现在貌似过期用不了了 。。。
