  • 3424阅读
  • 1回复
N1MM 2012 01月24号上来的12.01.03升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2012-01-26
没装过n1mm的请先下载主程序安装後再安装下面的升级版
n1mm-fullinstaller.exe
升级版本
n1mm-newexev12.01.03.exe
离线BD8ADT
只看该作者 1楼 发表于: 2012-01-26
available window: fix a warc band filter bug and reduce spot processing time. program change to not load packetwindow to determine warc filter status. (coded by k3ct)
ha dx contest: remove the sent field from the log window for ha users. (ha2vr) (coded by k3ct)
so2v dual rx: save the dual rx setting modified with ctrl+alt+d or the ~ key. (coded by k3ct)
udc feature, changes to parameter /qsoerrorstring/ to make it more flexible (see help.txt). some existing udc contests may require corrections. (g4ogb) (coded by na3m)
