  • 3433阅读
  • 4回复
APRSdroid 蓝牙连avrtt不能通讯,谁能帮助分析一下? [复制链接]
离线BG6JJI
只看楼主 倒序阅读 0楼 发表于: 2012-01-20
今天测试,蓝牙链接没有报错,但是不知道为何手台没反应,发射和接受都不行,我用刚发布的20120115版,请大家帮忙测试测试,谢谢了!
离线BG1EAO
只看该作者 1楼 发表于: 2012-01-20
刚又试了下,和710的牙还是接不上。很郁闷
离线bg6qbv
只看该作者 2楼 发表于: 2012-01-21
jji 不能用20120115版连接安卓,这个版本是专门连接garmin的手持机的。
离线BG6JJI
只看该作者 3楼 发表于: 2012-01-21
您在哪能看到具体介绍?我也看看
离线BG6JJI
只看该作者 4楼 发表于: 2012-01-22
我只看到这个介绍
aprsdroid is an aprs application for amateur radio (ham) operators. it allows reporting your position as well as sending and receiving messages. it also conveniently displays nearby stations as a list or on a map.
feel free to contact the author with any issues you might encounter. if you are not satisfied, you will get a refund, no questions asked.
to make full use of aprsdroid, you will need an aprs-is passcode for your callsign.
aprsdroid is open source software written in scala and licensed under the gplv2.
the aprsdroid features are:
* see what is going on on aprs with the hub view or on the map
* one-time or periodic position reporting to aprs
* aprs messaging support
* get detailed information about a station
* follow the movement of a station on the map
* support for gps and network location
* bi-directional aprs-is support via tcp
* unidirectional position reporting via udp, http or afsk (phone spekaer)
* bluetooth tnc support (beta quality)
* status bar notification when running and for incoming messages
the following features are planned for the next months:
* afsk decoding via microphone
* smart beaconing
* position reporting profiles
