  • 4504阅读
  • 2回复
N1MM 2012 01月17号上来的12.01.02升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2012-01-19
升级版本
n1mm-newexev12.01.02.exe
没装过n1mm的请先下载主程序安装後再安装上面的升级版
n1mm-fullinstaller.exe
离线BD8ADT
只看该作者 1楼 发表于: 2012-01-19
improve cw so2r radio switching time (coded by n2ic)
digital - corrects clear grab window on cq from not functioning in di2. (coded by n2amg)
available window: allow the selection of one or more bands and radio/vfo with the right click menu. the warc bands are grayed and unselected when the telnet warc band filter is active. eliminate a runtime error and improve the code efficiency. thanks to the users that helped with testing. (coded by k3ct)
esm: when using esm in run mode, do not send the tu message again if the user sends the tu message manually with the tu function key. (k8ut)(coded by k3ct)
bandmap window: change the width of the frequency bar to display the entire frequency when operating the uhf & microwave bands. (coded by k3ct)
auto threshold: check mark the config, auto threshold option when the feature is enabled. (coded by k3ct)
spots: re-enable the suppression of duplicate skimmer spots option when the spot table is trimmed due to loading. (coded by k3ct)
darc10m contest: rules url changed. (dk9tn) (coded by k3ct)
ukdx contests: summary window titles reversed. (w6wrt) (coded by k3ct)
sartgnyrty contest: change the contest to use the misctext field and not interfere with the user note (ctrl+n) operation. use a previous program version to submit the jan 2012 log. (coded by k3ct)
when turning networked computer mode off there was no way to abandon taking a workstation offline from the prompt. now there is. (k0rc) (coded by na3m)
udc feature bug fixes, logging qso with empty exch field was allowed, prefilling of numeric exchange was not working (ra3tt, uf8t) (coded by na3m)
离线BD8ASG
只看该作者 2楼 发表于: 2012-01-19
收到。谢谢。。。。。。。。。。。
