  • 4681阅读
  • 1回复
N1MM 2012 01月10号上来的12.01.01升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2012-01-12
升级版本
n1mm-newexev12.01.01.exe
没装过n1mm的请先下载主程序安装後再安装上面的升级版
n1mm-fullinstaller.exe
有人建议有升级版本可以修改贴子而无须再开新的贴子
我试过了,目录的标题无法修改
所以还是开新的贴子以免很多人错过新的升级版本
离线BD8ADT
只看该作者 1楼 发表于: 2012-01-12
added more info to status message when sendtoip fails (na3m) (coded by n2ic)
fixed rtty repeat timer problem when using {ctrlfx} in message (ww3s) (coded by n2ic)
udc - added new value for pointspercontact parameter, pointspercontact=
exchange, * - use numeric value entered in exchange as points (g4ogb) (coded by na3m).
fixed cabrillo problem for rfcssb, rfccw and rfcdigi contests for received/sent numbers > 999 (r9sa) (coded by na3m)
runtime error: eliminated a multiuser runtime error. (coded by k3ct)
autosend prompt: reword the autosend prompt to include additional information. (g3yyd)(coded by k3ct)
bug: when using the {call} macro in the hiscall function key, esm resends the entered call with every tu message. (coded by k3ct)
bug: when using ctrl+u in the agcw contest, the exchange number is incremented.(dk2zo)(coded by k3ct)
digital - change scoring for the sartg rtty dx contest to reflect actual scoring used. (k2dsl)(coded by n2amg)
digital - corrects issues in multi computer network not changing station status when going to rx (coded by n2amg)
digital - adds new macro for use in rtty mode. {baud:45} will accept all normal baud rates to make quick baud changes in multi baud contests. only works with mmtty,mmvari for now (coded by n2amg)
