  • 3387阅读
  • 2回复
Kenwood TH-K20AT [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2012-01-02
type:      amateur vhf transceiver
frequency range:      tx: 144-148 mhz
rx: 136-174 mhz
mode:      fm/nfm
(+/-5 khz and +/-2.5 khz deviation)
rf power output:      hi: 5.5 w
mid: ? w
lo: ? mw
receiver system:      n/a
sensitivity:      n/a
selectivity:      n/a
image rejection:      n/a
voltage:      ? vdc (1130 mah li-ion pack)
current drain:      rx: ? ma
tx: max ? a
impedance:      50 ohms, sma
dimensions (w*h*d):      ? mm
weight:      ? gr (with knb-63l)
manufactured:      2011-20xx
other:      200 memories. ctcss/dcs. vox.
backlit dtmf keyboard. weather alert
related documents:
modifications:
options/accessories:            bt-16
khs-22
khs-26
knb-63l
pg-4y
smc-32
smc-33
smc-34      battery case for 6*r03/aaa
headset with boom mike ptt
clip mike with earphone
1130 mah li-ion battery pack
pc serial programming cable
speaker microphone
speaker microphone with remote
speaker microphpne with remote and volume control
只看该作者 1楼 发表于: 2012-01-02
似乎k的k2和k4在国内都没什么太多用户,低端的机器只有再之前的g71口碑比较好。毕竟这类机器国产自有品牌也有不少了,价格国内的有优势。
倒是感觉k2,k4什么的在软件上是亮点,k家几代机器的设置频道文件都能不同机芯乃至不同年代的机器互转,这有点意思。
离线bh1nxf
只看该作者 2楼 发表于: 2013-06-03
学习了
