  • 4880阅读
  • 8回复
N1MM 12月27号上来的11.12.03升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2011-12-28
升级版本
n1mm-newexev11.12.03.exe
没装过n1mm的请先下载主程序安装後再安装上面的升级版
n1mm-fullinstaller.exe
离线BD8ADT
只看该作者 1楼 发表于: 2011-12-28
multi-op: stations worked would be spotted on partner's bandmap. fixed by no longer spotting calls from other networked users that are on a run frequncy. (k3ct) (coded by n1mm)
changes to reduce program start-up time, or inform the user why start-up is slow. (coded by n2ic)
for networked computers, reduce the duration of active connection attempts (i.e. "red dot"). this will reduce the occurrence of slow performance when some computers on the network are not reachable. (coded by n2ic)
bug: user note entered before qso is logged is not saved. all contests effected except cqsassb, uksmg, ropoco, sartgnyrty have been fixed. these four will be corrected later. (ly4k)(coded by k3ct)
voiced serial numbers: new feature. the code will automatically use advanced phrasing of serial numbers if the necessary *wav files exist. the first time a number is voiced, the file check is performed and the result is shown in the info window. the file check is repeated when the operator changes. benchmark data: time to parse up the wav files to speak "twenty nine thousand nine hundred ninety nine" and start the audio ocx - 5ms (i5 3.6ghz, win7). (n4zr)(coded by k3ct)
available window: change to the shift+click on spot operation. current so2r operation: send the spot to the radio that is on the spot band, if none, use the in-active radio. if both radios are on the same band, send the spot to the in-active radio. shift+click on a spot: determine the radio with the above rules and then send the spot to the opposite radio. there is an existing right-click menu option for so2r to change the radio focus with the spot, "so2r focus follows spot". (coded by k3ct)
operator callsign: save operator callsign (ctrl+o) and start the program with the last operator entered. (many)(coded by k3ct)
letters file path: improved error checking for the user programmable letters file path. (coded by k3ct)
ssb function key: improve the ssb function key browse file (set) button. (coded by k3ct)
离线bg7nfm
只看该作者 2楼 发表于: 2011-12-28
其实你可以在原有的帖子上更新的
离线ba6iv
只看该作者 3楼 发表于: 2011-12-29
升级够快的。
离线BD4EP
只看该作者 4楼 发表于: 2011-12-31
更新快,这是n1mm的风格。早习惯了。要用n1mm打比赛,先上网站看看有没有升级包再说!呵呵,都成习惯了。
离线BD8ADT
只看该作者 5楼 发表于: 2012-01-05
N1MM2012 01月03号上来的12.01.00升级版
升级版本
n1mm-newexev12.01.00.exe
bug: the initial operator callsign is not populated from the station callsign correctly. (n4zr)(coded by k3ct)
copy contest to another database: added a file check for the target database. (coded by k3ct)
runtime error: eliminated a multiuser runtime error. (coded by k3ct)
icom radio: for some icom radios, change to how often the digital mode and af gain settings are polled. for these icom radios, this will cause the bandmap to update twice as fast when the radio vfo is turned. (coded by k3ct)
cq sa ssb contest: eliminate the conflict with user qso note. changed to use the misctext database field instead of comment field. (coded by k3ct)
don't raisegmttimer event for each entry window. (internal change, no visible effect) (k3ct)
fix crash when null entries in networked computer table (w2bsn) (coded by n2ic, thanks to k3ct)
离线bd4jk
只看该作者 6楼 发表于: 2012-01-06
谢谢
已经下载
离线BG1TXU
只看该作者 7楼 发表于: 2012-01-06
已更新,谢谢!
离线BD8ADT
只看该作者 8楼 发表于: 2012-01-06
其实你可以在原有的帖子上更新的
谢谢您的建议
但是标题改不动
所以下次还是开新贴通知
