  • 12077阅读
  • 10回复
SWR Bridge 1 to 1000 Mhz [复制链接]
离线BA2Bi
只看楼主 倒序阅读 0楼 发表于: 2011-12-23
http://www.webx.dk/oz2cpu/radios/swr-bridge.htm
this swr bridge is not my own invention, oz3sw and oz9mo has improved the design after dj7vy construction in ukw-berichte 1/83
this is a construction set made for the members of frederikssunds edr club, all i did was a bit of gluing and soldering
thanks for all the hardware help, parts help, calibrating and measuring ! you know who i mean !!
it is possible to measure return loss up to 1000 mhz, the return loss range is 0-50 to 0-40db depending on frequency.
离线BA2Bi
只看该作者 1楼 发表于: 2011-12-23
A simple but effective SWR meter for the low microwave bands
http://www.olotwireless.net/catala/medidorswr2.htm
after experimenting with the strip line based swr meter, another solution needed to be tried in order to get the losses through the swr bridge down to a resonable level.
after chatting with microwave afficionados julian - g3ygf and andy - g4jnt, this design was built. basically it consists of 2 pieces of ut141 semi rigid coax. on both pieces of semi rigid coax, a slot of around 30mm in length is filed to expose the centre conductor. the slot width is about 2mm. the two slots, one on each coaxial cable are then put together, such that the transmission lines are parallel, and soldered along the full length on both sides. make an effort to solder properly. the 30mm window in each piece of semi-rigid must be lined up so the coupling will be efficient.
this technique not only provides good coupling, but ensures that both transmission lines have a relativly constant 50 ohm impedance.
the main through rf line is terminated with good quality n type chassis sockets, whilst the coupling line has sma plugs attached to it.
the coupling line is then terminated with 50 ohm loads, made with two 100 ohm surface mounted resistors. these resistors are mounted on the back of an sma socket (see circuit diagram below).the centre pin of the sma socket also has a mixer diode from an old marconi lnb connected to it. ideally, a good quality microwave diode would be used instead of the mixer diode from the lnb. the other pins of the mixer are supported on 1n and 10k chip components, with the dc output being taken from the top of each 10k resistor.
the picture below shows the sma circuitry in a little more detail. in addition to the detector circuit, a simple op-amp voltage amplifier circuit is required as the output from the mixer-diode-detectors are small. a switch and pot are required to select forward or reverse voltage. once the meter is calibrated using the pot for full scale reading on forward power, then reverse readings can be taken with relative ease.
using this swr meter for 2.4ghz wireless lan antenna testing is simple, and providing uhf construction techniques are observed, this meter will perform very well.
i'd like to thank julian - g3ygf and andy - g4jnt for their invaluable help whenever a microwave type question needs answering.
离线huizi
只看该作者 2楼 发表于: 2011-12-23
哈哈 看来您真是着急了
离线BG6KHC
只看该作者 3楼 发表于: 2011-12-24
围观 2.4g 的 做法
离线bg0cq
只看该作者 4楼 发表于: 2011-12-24
pfp-500里面就用了这个办法,只是内部是双孔磁芯,外面没有套大磁环,套不套大磁环有区别吗?
离线bg4agr
只看该作者 5楼 发表于: 2011-12-24
套不套大磁环好像影响不大,胆小磁环一定要用的多,越长越好。
呵呵,我做出来象根筷子,效果是超好
离线dtxy101
只看该作者 6楼 发表于: 2011-12-24
我现在就在库尔勒,你在哪里,本地有400m吗?
离线BA2Bi
只看该作者 7楼 发表于: 2011-12-24
哈哈 看来您真是着急了
快点。。。
我最近有点时间。。。
要快~~~
离线BG7YDO
只看该作者 8楼 发表于: 2011-12-24
大磁环是要的,不然低端不好调下来。我原来弄得,低端也只能到2-3mhz,高端在1g以上。
离线BG2BHZ
只看该作者 9楼 发表于: 2011-12-25
好东西啊,太好了.
离线bg0cq
只看该作者 10楼 发表于: 2011-12-26
抱歉!今天才看到,请见悄悄话。
