  • 3684阅读
  • 1回复
N1MM 12月20号上来的11.12.02升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2011-12-21
升级版本
n1mm-newexev11.12.02.exe
没装过n1mm的请先下载主程序安装後再安装上面的升级版
n1mm-fullinstaller.exe
离线BD8ADT
只看该作者 1楼 发表于: 2011-12-21
fixed start-up delay when networked computers table is empty, has a blank entry, or has never been edited (coded by n2ic, thanks to k3ct).
(digital) - disables change made to function key flow introdued in version 11.11.2 when in digital mode. (coded by n2amg)
bug fix, ok rtty contest, column names corrected in the score summary window (n2nf) (coded by na3m)
bug fix, reverse call history lookup code for iaru, cqwwvhf, agcw and iota contests, could cause a crash when check window is closed (coded by na3m)
cwops,cwopsopen,focbwqp: multiplier window section view display was not repeatable when switching between contests. sections are not multipliers in these contests. (w4nz) (coded by k3ct)
edit contact window: prevent users from changing the contest name when editing a qso. (ki4oyf) (coded by k3ct)
networked computer mode: speeded up processing of incoming spots from other computers. should only be noticable in very large logs. (na3m) (coded by n1mm)
