  • 3955阅读
  • 2回复
N1MM 12月13号上来的11.12.01升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2011-12-15
升级版本
n1mm-newexev11.12.01.exe
没装过n1mm的请先下载主程序安装後再安装上面的升级版
n1mm-fullinstaller.exe
离线BD8ADT
只看该作者 1楼 发表于: 2011-12-15
arrl 10m: populate the exchange with kh6, kl7, and color the incoming spots based on the prefix for ve, kl7, and kh6. do not populate the exchange box with a serial number from a logged contact. change the summary window multiplier column title. change the multiplier window, section view, /mm column title. (coded by k3ct)
call history import: add the import directive !!validate50state!!. when this import directive is inserted in the call history file, only valid state abbreviations will be populated in the state field. (coded by k3ct)
bug: corrected the spot all s&p qso's feature and added a new method to specify the comment for all spots which includes fields from the qso data. this option is listed in the telnet window right-click menu. these options are not saved on program exit. (coded by k3ct)
entrywindow: turn off the esm button color when quick editing a qso. (w2id) (coded by k3ct)
离线BA8AT
只看该作者 2楼 发表于: 2011-12-17
继续折腾尝鲜
