  • 4656阅读
  • 5回复
N1MM 12月06号上来的11.12.00升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2011-12-08
升级版本
n1mm-newexev11.12.00.exe
没装过n1mm的请先下载主程序安装後再安装上面的升级版
n1mm-fullinstaller.exe
离线BD8ADT
只看该作者 1楼 发表于: 2011-12-08
added networked computer number for future improvements (no visible changes (coded by n2ic)
bug fix: lzdx and yudx, entering callsign with a slash was causing run-time error (ws4t) (coded by na3m)
new contest nrrlfylke (for norway stations only) added (la6fja) (coded by na3m)
bug fix: arrl10m contest - 10 min band change timer was showing up in the info window for multi op stations (cx6vm) (coded by na3m)
udc feature bug fix: multsqlstring3 was not working (g4ogb) (coded by na3m)
multiplier window, epc-ukr-dx contest, not enough space for section names (ra3tt) (coded by na3m)
bc qso party: rules update. (va7bec) (coded by k3ct)
arrl 10m: several state multipliers colored with no qso's logged. qso points now are zero if qso is on the wrong band. removed the old novice point scoring. changed pe mult to pei per the arrl rules. added r1, r2, and r3 mults to the multiplier window. added populating of ve exchange. users should import the exchange in the call history state field. the exch field will work but the log won't be checked first. tnx ve3ki for help with testing. (coded by k3ct)
edit ssb function key: improve the operation when using the set button. ignore {log} macros, convert the {operator} macro, and add the program path when a fully qualified path isn't used. (coded by k3ct)
entry window help: improve the help menu and add a tools option to download the latest *pdf manual. users should store the manual in the program directory so it can be used by the new help menu item. (coded by k3ct)
ssb message recording: when recording a ssb message ignore the {log} macros. (coded by k3ct)
离线BG1TXU
只看该作者 2楼 发表于: 2011-12-08
刚升完又来新的了,不知何时把我们by正在设计的比赛加上?
离线BG4LJW
只看该作者 3楼 发表于: 2011-12-08
支持升级 ~~~ 另 接口问题 有没有攻略
离线BD8ADT
只看该作者 4楼 发表于: 2011-12-08
离线BA8AT
只看该作者 5楼 发表于: 2011-12-08
生命在于折腾,升
