  • 4101阅读
  • 3回复
N1MM 11月29号上来的11.11.04升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2011-12-05
升级版本
n1mm-newexev11.11.04.exe
没装过n1mm的请先下载主程序安装後再安装上面的升级版
n1mm-fullinstaller.exe
离线BD8ADT
只看该作者 1楼 发表于: 2011-12-05
set ssb messages dialog: fix runtime error when path is blank and set is pressed (n4zr) (coded by n1mm)
networked computer mode (multiop) - ctl-n (note) was updating the last qso not the last qso by the editing station. corrects runtime errors on the other networked computers (k3ct) (coded by n1mm)
the sequence of the score summary listing for cqww swapped, it is now pts, zn, cty. this applies to all cqww (cw, ssb, rtty) and gacw (wwsa) contests (kr2q). (coded by na3m)
bug: eliminate a runtime error when view, off time is used with some logs. (coded by k3ct)
cpu threshold: reduction of the cpu load threshold level to reduce the initial cw hesitation when an idle computer receiving a high telnet spot flow is used to send cw. (coded by k3ct)
离线BA8AT
只看该作者 2楼 发表于: 2011-12-05
已经搞定,谢谢
离线BG1TXU
只看该作者 3楼 发表于: 2011-12-07
三天两头的不断推出,升级成功,谢楼主!
