  • 2495阅读
  • 1回复
设备欣赏:Ten-Tec Model 539 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2011-11-20
type:      amateur hf transceiver
frequency range:      10-80 m + warc
mode:      am/ssb/cw
rf power output:      10 w
receiver system:      n/a
sensitivity:      n/a
selectivity:      n/a
image rejection:      n/a
voltage:      12-14 vdc
current drain:      rx: max 250 ma
tx: max ? a
impedance:      50 ohms, so-239
dimensions (w*h*d):      ? mm
weight:      ? kg
manufactured:      2011-201x
other:      100 memories. tricolor backlight. dsp
离线BD4EQ
只看该作者 1楼 发表于: 2011-11-21
应该是垃圾。。。。。
