  • 4232阅读
  • 18回复
CW通联中如何交换操作员的名字 [复制链接]
在线BD7IHN
只看楼主 倒序阅读 0楼 发表于: 2011-11-16
以前我是从来不主动问对方的名字的,有的时候会主动报自己的名字。而更多的时候是对方报名字了,我出于礼貌也要把自己的名字告诉对方。我原来知道有两种方式报自己的姓名:一种比较直观,“my name is zhao”;另一种比较简练,“op zhao”,这里op就是operator的简写。基本上多数人都是用这两种方式,一般对方用什么方式报过来,我就用同样的方式回报过去。
昨天,我和ea2nn通联时,遇到了第三种方式。当时是他先向我报了名字,然后我回报“op zhao”。也许他并没有抄收清楚,所以后来他发过来“qts? bd7ihn”,说实话,开始我并不理解他的意思,后来经他解释,才知道是在问我的名字。以前知道qth是表示电台所在地,现在知道qts是表示电台操作员的名字(两者就差那么一点)。
不过,也许我通联得少,在此之前还没碰到过用qts这个简语的。很多简语也是这样,没用过的,基本上就忘记了,而使用过的,就印象比较深。
离线bd2iaq
只看该作者 1楼 发表于: 2011-11-16
学习了 这个必须顶
离线kentwu
只看该作者 2楼 发表于: 2011-11-16
qts很少用到啊,以前一直以为是发呼号调整的意思,曾见过用qra的。我觉得楼主的op很简洁。哈哈
离线BA7IO
只看该作者 3楼 发表于: 2011-11-16
qta - qtz
top
qta   shall i cancel telegram number ...
qtb   do you agree with my counting of words
qtc   how many telegrams have you to send
qtd   what has the rescue vessel or rescue aircraft recovered
qte   what is my true bearing from you or from ...(callsign)
qtf   will you give me the position of my station according to the bearings
    taken by the d/f stations which you control
qtg   will you send two dashes of ten seconds each followed by your callsign
    repeated ... times on ... khz/mhz
qth   what is your position in latitude and longitude (or according to any
    other indication)
qti   what is your true track
qtj   what is your speed
qtk   what is the speed of your aircraft in relation to the earth's surface
qtl   what is you true heading
qtm   what is your magnetic heading
qtn   at what time did you depart from ...(place)
qto   are you airborne or have you left dock/port
qtp   are you going to alight/land or are you going to enter dock/port
qtq   can you communicate with my station by means of the international code
    of signals
qtr   what is the correct time
qts   will you send your callsign for tuning purposes or frequency measurementqtt   the identification signal which follows is superimposed on another
    transmission
qtu   what are the hours during which your station is open
qtv   shall i stand guard for you on the frequency of ...khz/mhz
qtw   what is the condition of survivors
qtx   will you keep your station open for further communication with me
qty   are you proceeding to the position of the incident and, if so, when do
    you expect to arrive
qtz   are you continuing the search
离线BA7IO
只看该作者 4楼 发表于: 2011-11-16
恐怕楼主理解有误,我也不太敢确定,但照字面理解,怎么也联想不到是问名字;于是请教了某位大佬,理解如下
离线bd3mv
只看该作者 5楼 发表于: 2011-11-16
今天遇到问我:ur name ? 这个很好理解的,我马上回答了。还没有遇到楼主这个问题的,经验呀!
在线BD7IHN
只看该作者 6楼 发表于: 2011-11-17
你这么说,也很有可能是我没理解他的意思,因为他后来发过来“qts is……ur name”,然后我就发“my name is zhao zhao”,然后他似乎就满意地叫我的名字、谢谢、希望再见、73……。所以我以为他问qts就是问我的名字。
呵呵,看来还是按原来的用法就好了。
离线BA5CW
只看该作者 7楼 发表于: 2011-11-17
我觉得逻辑上,这里应该是问qth,有可能是传播不好h和s分不清,有可能他本来就少发一个点
在线BD7IHN
只看该作者 8楼 发表于: 2011-11-17
这个可能性也是很大的。带着疑问,我已经给ea2nn发邮件了,看他当时想的是什么。
在等邮件的时间里,聊一下简语bk是什么意思。我看见有的人在发完所有内容后加个bk,这里的bk似乎是个句号。而有的人是在发报的开头以bk作为开始,这里的bk似乎又是起到引号的作用。
离线BA5AG
只看该作者 9楼 发表于: 2011-11-17
bk在开头和结尾的意思是不同的。
在结尾的意思是:好,就酱紫,该你了。比较随意非正式地结束拍发。
在开头则有两种意思,一种是对方发了bk,那么我们也bk地接上头:好嘞,我说啊...
另一种则是对方的信号qsb了,没听到对方的结束,猜测对方结束了,于是先来一两个bk,表示自己是非正式地回答
在线BD7IHN
只看该作者 10楼 发表于: 2011-11-17
那我可否私底下、非正式地、根据字面猜这个bk就是break的缩写。用在句末的时候,就表示:我暂时没想到什么要说的了,先停下来,让你先说。用在句首的时候,就表示:好吧,那我打断你一下,我来说。
就酱紫,bk
离线BA7IO
只看该作者 11楼 发表于: 2011-11-17
bk在开头和结尾的意思是不同的。
我觉得非常到位,跟我平时的用法一样。
最后一种情况,现在还有更简单的,就是干脆发ok ok ok 后面接来着内容;
bad 坏,不好
bc (broadcast) 广播
bd (baud) 波特
bec (because) 因为
best 最好的
bgn (beg in) 开始
bjt (beijing time) 北京时间
bk (break) 单工插入法
boz (both) 双方
br 双路
btr (better) 较好
by 被
by order 奉命
but 但是
buro (bureau) 卡片管理局,局
离线BA1GM
只看该作者 12楼 发表于: 2011-11-17
学习了
离线BG4DYH
只看该作者 13楼 发表于: 2011-11-18
看到了我想问的问题,学习一下!
离线bd3mv
只看该作者 14楼 发表于: 2011-11-18
就酱紫,bk
我也是这样子理解的!
离线BD8ADT
只看该作者 15楼 发表于: 2011-11-19
就酱紫,bk
bk就是break的意思
老外dx很习惯在每句的最後放上bk,意思就是发完了请你插入.
离线BG4XNG
只看该作者 16楼 发表于: 2011-11-19
my name is刘,文刀刘,do you 拷贝?
这是当年一些坏人教我的通联三斧子内容!!!!
离线BA1IO
只看该作者 17楼 发表于: 2011-11-19
找个skcc - straight night的视频听听就都会了!
在线BD7IHN
只看该作者 18楼 发表于: 2011-11-19
4ALC是对的
回复过来的邮件如下:
hi zhao,
excuse me becouse that qtc was to a russian friend that ask me by your qth becouse he didn´t listen you...
was pleasure our qso and i hope meet you soon...
best 73s de ea2nn...
按我的理解是,他有一个俄罗斯的ham友因为听不到我的信号(估计是在同一频率上守听着,他们两人可能通过即时聊天工具联系的),所以想知道我的位置,专门问一下。
