  • 3905阅读
  • 1回复
N1MM 11月8号上来的11.11.01升级版 [复制链接]
离线BD8ADT
只看楼主 倒序阅读 0楼 发表于: 2011-11-14
升级版本
n1mm-newexev11.11.01.exe
没装过n1mm的请先下载主程序安装後再安装上面的升级版
n1mm-fullinstaller.exe
离线wd3010
只看该作者 1楼 发表于: 2011-11-14
new feature: (user text display) add a usertext field to the call history database, file import, and call history file export. the usertext appears below the bearing when the entry window height is large enough. call history does not need to be enabled for the user text to be displayed. the feature is disabled automatically when the height of the entry window is made smaller and the usertext line disappears. the usertext length is limited to 60 characters. naturally, commas cannot be used in the user text data. if usertext data is repeated in the import file, the duplicate text is not appended. added additional user comments to the call history export file. comments do not need to be removed for file import. added new import directive commands. a summary of all import directive commands is added to the call history export file comment text. corrections made to the call history import routine. (coded by k3ct)
rsgb club: late change requests. change the contest to use the misctext database field for the club name allowing call history to be used for this field. since the exchange data is stored in a different field starting with this version, users will not be able to revert to an older program version without exporting adif, changing the field name, and importing. tnx to g4lmw for testing. (g4lmw) (coded by k3ct)
rsgb club: contacts with non-rsgb stations are allowed and score three qso points. (g4ogb) (coded by k3ct)
suspect zone check: the ve5 default zone used for the zone check is incorrect. (w4ft) (coded by k3ct)
recording wav file: when a directory had to be created, the software did not create the directory. this could also fix the reports that the qso recording does not work. please test for both, report any issues. (k1mk)(coded by k3ct)
telnet window title: the timeout value listed in the title of the telnet window does not update when the setting is changed. (k0rc) (coded by k3ct)
help links: fix several url's for window help selection. add a help button to the multiplier and visual dupe sheet because the right click help menu only appears in a limited area or not at all. (g4lmw) (coded by k3ct)
import transaction log: fixed a runtime error that prevented transaction imports when multi-user was not enabled. (kk7x) (coded by k3ct)
recording wav file: when a directory had to be added, the software did not create the directory. this could also fix some errors with the qso recording. please test this change. (coded by k3ct)
digital: corrects not being able to stack macro buttons in both digital windows. (coded by n2amg)
digital: corrects ctrl-save in wae contest from not wrking in di2. (coded by n2amg)
digital: corrects an issue in wae contest where macro substitutions would not work when sending qtc macros (coded by n2amg)
enhancement: wae rtty, new color scheme for band map adopted from wae cw and wae ssb to allow better qtc exchange. see reflector message no. 78889 for details. **note: versions from 11.9.01 to 11.11.00 do not work correctly for wae rtty (in terms of colors in the band map).** (coded by na3m)
bug fix: zones and countries placed into the wrong columns in score summary window. (coded by na3m)
bug fix: beam heading for ra0uf (and other stations located in zk) was missing in the entry window (k1ko). (coded by na3m)
