  • 4256阅读
  • 5回复
Dual Band Half-Wave Flower Pot Antenna [复制链接]
离线BA2Bi
只看楼主 倒序阅读 0楼 发表于: 2011-11-11
the basic half wave version of the flower pot antenna can be readily modified to dual band the antenna for operation on a band that is the (approximate) third harmonic of the fundamental resonance.
operation on the third harmonic is achieved by using a sleeve technique so as to form quarter wave phasing sections (at the higher frequency) to end feed two half waves in phase at the third harmonic.
this arrangement provides useful gain (3dbd) on the higher band. the sleeve technique maintains the impedance matching for both bands and (probably fortunately) there is sufficient longitudinal impedance in the choke coil to provide the required isolation at the third harmonic.
the sleeve is applied after the basic antenna has been constructed.
dimensions shown are for the (basic) 2m half-wave flower pot. the modification involves placing a co-ax phasing sleeve around the outside of conduit, positioned as shown.
dimensions for a 2m half-wave flower pot
the sleeve material can be aluminium (kitchen) foil, copper foil, brass shim, roof/building alfoil sarking or salvaged co-ax braid.
before fixing the sleeve in place, check vswr on 2m the sleeve should cause little if no change to 2m vswr although it may appear to very slightly raise the resonant frequency; with the sleeve fitted, the vswr should not be greater than 1.15:1 across the fm portion of band).
then check vswr across the 70cm (430 – 450 mhz) band. expected vswr readings will be less than 1.2:1 at band edges and less than 1.1:1 in band centre.
if vswr is outside these limits, adjust position of sleeve (+/- 5mm max) and, if necessary, trim sleeve length to lower vswr. when trimming sleeve length (dimension b) adjust dimensions a and c accordingly to keep centre of sleeve adjacent to feedpoint of the inner 2m dipole. however, little, if any, adjustment to the sleeve should be necessary. when satisfied with the vswr, fix in place and protect the sleeve with uv protected pvc tape or heatshrink.
methods of dual banding the other versions are being developed and will be added to this website when available.
离线llqilong
只看该作者 1楼 发表于: 2011-11-12
等高人翻译!!!!!!!!
离线BG6AZJ
只看该作者 2楼 发表于: 2011-11-14
me too
离线BG4CTL
只看该作者 3楼 发表于: 2011-11-14
430-450mhz。为保持那根同轴位置而用渔丝来固定,效果是靠不住的, 还不如在管内加个衬片。
离线VK3ATA
只看该作者 4楼 发表于: 2011-11-15
430-450mhz。为保持那根同轴位置而用渔丝来固定,效果是靠不住的, 还不如在管内加个衬片。 [表情]
我想楼上的是想知道它的工作原理,而不是讨论制作的方法吧。
离线BG4CTL
只看该作者 5楼 发表于: 2011-11-15
該文乃講述製作及調試,我提出自己看法有何不妥?
