  • 4408阅读
  • 0回复
土耳其地震应急频率7092KHZ USB [复制链接]
离线BA1RB
只看楼主 倒序阅读 0楼 发表于: 2011-10-25
请大家避让7092khz usb,谢谢
turkey earthquake emergency communications
the call is out to 7.092 mhz usb that is being used for emergency communications
following the 7.2 magnitude earthquake in the van region of eastern turkey
with a great loss of life and hundreds of casualties.
radio amateurs from the turkish iaru member trac are responding to assist
with communications in the area after the 'quake hit on october 23 at 10.41
utc. the death toll has been put at up to 1,000.
there are some frequencies in use on hf, currently used to link with government
resources and this is meaning that some frequencies outside the amateur bandplan
and normal usage are being used until more equipment gets to the region.
when this happens, more traffic should move to the normal emergency communications
centre of activity frequencies.
please avoid causing qrm to emergency traffic on 7.092 mhz usb. usb is being
used to allow communications with a government station.
more information will be posted on this website when it is available from
trac.
iaru region 1
http://www.iaru-r1.org/
