  • 3374阅读
  • 8回复
G4KKI的20米到10米波段的新磁环天线 [复制链接]
离线BD7IWW
只看楼主 倒序阅读 0楼 发表于: 2011-10-19
特点是又大又粗。75mm直径铝管,正八边形边长900mm。
这还是个baby!
见:
www.g4kkibill.blogspot.com
进入主页后点击“new magloop babyzilla”即可。
离线bg3qai
只看该作者 1楼 发表于: 2011-10-19
在那看不到
离线bd4jk
只看该作者 2楼 发表于: 2011-10-19
不能访问
请贴图吧
离线BD7IWW
只看该作者 3楼 发表于: 2011-10-19
截图也不行,文件大于800x800
访问他的主页试试。
www.homepage.ntlworld.com/g4kki.willian/
离线BD7IWW
只看该作者 4楼 发表于: 2011-10-19
这个也不行
访问他的主页试试。
直接用"g4kki"搜索吧。
离线bd5ham
只看该作者 5楼 发表于: 2011-10-19
baby zilla completed and operational.
i have now finished building baby zilla, the magnetic loop is working just fine. the feed loop is a simple wire loop instead of the half faraday loop i have used in the past. much easier to set up and results seem the same.
the loop is approx 1/5th the size of the main loop and the shape can be altered to get the required swr. the finished loop has an swr of 1:1 on 20,17 and 15mtrs, on 12 and 10mtrs it is a little higher but still less than1.4:1.
here it is in the radio club shack hanging from one of the wooden roof beams. this weekend i will be installing the magnetic loop in my roofspace at home. it will replace the old capco magloop that i re-built last year. that will probably be sold to the highest bidder :-)
all credit for the construction of baby zilla must go to gary 2e0tig who made the loop and cut out all the bits for the butterfly capacitor, i had the easy job of just assembling
文章的主人的这副天线是安装在室内的屋顶使用的
离线bd5ir
只看该作者 6楼 发表于: 2011-10-19
看来王老师也对环天线动心了.
只看该作者 7楼 发表于: 2011-10-19
这么粗的铝管不好找,铜管估计更够呛。
离线BD7IWW
只看该作者 8楼 发表于: 2011-10-19
yes!
看来王老师也对环天线动心了.
想做一个1米3的试试。
