  • 7573阅读
  • 52回复
T32C DX远征追风贴 [复制链接]
离线深圳上尉
只看楼主 倒序阅读 0楼 发表于: 2011-10-10
this is the official site for the 2011 amateur radio dxpedition to kiritimati (christmas island) in the northern line islands, a part of the republic of kiribati. the dxpedition is being organised by the five star dxers association (fsdxa) and will operate using the call sign t32c between 28 september and 26 october.
why kiritimati? club log shows that east kiribati, where kiritimati is located, is the 36th most wanted dxcc entity by european operators and 61st most wanted worldwide. it is even more sought after on the lf bands.
the team will arrive on the island on the afternoon of wednesday 28th september 2011 and depart on the morning of wednesday 26th october 2011. allowing for set up and take down of the stations, operations should extend over four full weekends.
during our time on the island we want:
to operate to the highest standards - we support the dx code of conduct
to make contact with 40,000 different stations (uniques)
to give every dxer, wherever based, a chance to contact t32
to exploit all openings to europe
to contact between 1,000 and 2,000 different stations in the uk
to exceed 150,000 qsos
to win back some of the world records previously held by fsdxa
to place an emphasis on the lf bands
to have up to 15 stations on the air simultaneously
and, oh yes - to have some fun!
we will be taking over the captain cook hotel with its north facing beach which will give great over-sea take off for the short paths to europe, north america and japan. the take off in other directions is also good as the highest point on the island (joe's hill) is only 13 meters (43ft) high, and the centre of the island is mainly sea water lagoon. the dxpedition will make heavy use of vertical antennas to take advantage of the sea water.
6 october 0200 gmt
currently at 60k qsos, 56% on cw, 40% on ssb and 4% rtty. we are making a effort to increase the rtty percentage.
of the 60k qsos, 54% have been with na, 24% as, 17% eu, 3% sa & 2% oc. we have worked eu on 160m on both the sun rise and sun set paths.
more details are available in press release 7
这是2011年的业余无线电dxpedition刻里提马提(圣诞岛)在北线群岛,基里巴斯共和国的一部分的官方网站。 dxpedition是五星dxers协会(fsdxa)主办,会操作使用9月28日和10月26日的呼号t32c。
为什么要刻里提马提?俱乐部日志显示,东基里巴斯,刻里提马提是所在,是第36届最希望由欧洲运营商和第61届最希望全世界的dxcc实体。它更是追捧的lf频段。
该小组将抵达岛内日(星期三)2011年9月28日下午,2011年10月26日星期三上午离开。允许成立,并采取站,操作应延长了四个完整的周末。
在我们我们希望在岛上的时间:
工作的最高标准 - 我们支持的行为dx守则
为了使接触不同的站40,000(独有)
为了让每一个dxer,地方为主,有机会接触的t32
要利用所有的开口到欧洲
1,000至2,000种不同的站联系,在英国
要超过15万类星体
为了赢回一些以前fsdxa举行的世界纪录
要重视对lf频段的地方
要对多达15个站,同时空气
而且,哦,是的 - 有一番情趣!
我们将采取在库克船长酒店朝北的海滩,这将给大过海到欧洲,北美和日本的短路径。在其他方向也是上岛(乔山)的最高点是高仅13米(43英尺),岛的中心主要是海水泻湖。 dxpedition将大量使用垂直天线,利用海水的优势
离线深圳上尉
只看该作者 1楼 发表于: 2011-10-10
日志查询
http://www.clublog.org/charts/?c=t32c
远征台到10月26日才结束。。。
到目前by排行榜
离线bd3mv
只看该作者 2楼 发表于: 2011-10-10
已经在10米、15米完成两个cw格子(今天11号下午又拿下20米)
楼上第85号的ba3mv没有这个呼号!!(他抄错了)
离线BG4AHF
只看该作者 3楼 发表于: 2011-10-10
很显然有不少抄错的呼号
离线kentwu
只看该作者 4楼 发表于: 2011-10-11
还有时间,听听看。哈哈
离线bd3ct
只看该作者 5楼 发表于: 2011-10-11
5band qso only 3band log!!
离线浦东星
只看该作者 6楼 发表于: 2011-10-11
28470.0 t32c       5/9
离线bd4ij
只看该作者 7楼 发表于: 2011-10-11
唉,分辨他的ssb呼号太困难了,听了一个多小时,嘿嘿。然后我只报了一遍自己的呼号,听他回答我的呼号完全正确,目前只通了一个20米ssb
离线ct003
只看该作者 8楼 发表于: 2011-10-11
奇怪,我的日记通了三个波段,他只认两个!没办法。
离线BD7OZG
只看该作者 9楼 发表于: 2011-10-11
是不是碰到海盗了
他们公告也这么说
离线bg3dbu
只看该作者 10楼 发表于: 2011-10-11
刚吃完饭一开机只敲了一遍就在20米上拿下了,前几天敲一个多小时才拿下。
离线bg8srq
只看该作者 11楼 发表于: 2011-10-11
至今什么也没听到,郁闷中...
离线BA6QH/QRP
只看该作者 12楼 发表于: 2011-10-12
这个五星级dx远征团队十分了得,当初d68c 3b9c 3b7c就是他们的杰作,曾经创造过很多远征纪录,时间比较长,越到后面越容易,慢慢弄吧!
离线BD4QA2920
只看该作者 13楼 发表于: 2011-10-12
是的,昨天不经意在20米和40米通了,争取把15米搞定。
离线深圳上尉
只看该作者 14楼 发表于: 2011-10-12
是不是碰到海盗了
他们公告也这么说
注意,还是先保留日志吧,我前些天的t32c一个格没看到确认,以为没通到,就删除了日志,谁知现在确认了,我想不起来是个时间和频率了,呵呵
离线bg4ffm
只看该作者 15楼 发表于: 2011-10-12
那个40米cw对我来说是杯具啊,总是在7001
我家里7001附近一直有很强的干扰,唉~
离线CE2388
只看该作者 16楼 发表于: 2011-10-12
今天总算通了个10m波的,好不容易.
离线bg8srq
只看该作者 17楼 发表于: 2011-10-12
我今天早上28490上通到了,59的,不错哦,终于搞定,回头查查日志上去了没。
离线bg8srq
只看该作者 18楼 发表于: 2011-10-12
呵呵,by排名100
离线bg4ffm
只看该作者 19楼 发表于: 2011-10-12
今晚上把40米30米的cw搞定了,哈哈~
