  • 9268阅读
  • 41回复
这里人多,转个邮件,有奖品 [复制链接]
离线BA5FB
只看楼主 倒序阅读 0楼 发表于: 2011-08-30
来自oh7wv esa的邮件
hello fellow contesters in china.
in the upcoming scandinavian activity contest there will be a special awards program. it will include trophies that are sponsored by individuals, who have wanted to award something that is important to them.
i will be sponsoring two trophies:
china single operator activity in sac 2011 – cw
china single operator activity in sac 2011 – ssb
the trophies will not go to the highest scores. instead, it encourages all single-op stations in china to make as many qso’s with scandinavian stations as possible. so here is how this thing works:
work 50 qso’s in the contest and you get 1 raffle ticket. work 100 q’s and you get 2 tickets. 150 q’s will give you 3 tickets and so on. after the results have been published, we will perform a raffle for cw and another for ssb for callsigns who will receive the trophies. the more your work, the better chances you have to win the trophy. the trophies will look something like in the attached picture, these are examples from an earlier case; for this contest a new set of trophies will be made and may look different depending on which tubes we choose to use.
the required qso numbers have been set low enough to have a chance even with a small station. so, everybody, get active on sac, it is only a 24 hour contest!
the important dates are:
sept 17-18, 2011, 12-12 utc, cw
oct 8-9, 2011, 12-12 utc, ssb
the rules can be found at http://www.sactest.net/ , look at the “rules”-tab which is 5th from the left.
please forward this message to as many by-hams as you know. thanks.
73, esa oh7wv
离线BG2XJK
只看该作者 1楼 发表于: 2011-08-30
看看是什么奖品的路过
离线BA5FB
只看该作者 2楼 发表于: 2011-08-30
奖品硬道理
离线BD7IHN
只看该作者 3楼 发表于: 2011-08-30
包邮吗?看着象是易碎品耶。不是很清楚奖品是什么,现在要24小时内做50个北欧电台,对我还是有点难度的。看cw有没机会了。
离线BA5FB
只看该作者 4楼 发表于: 2011-08-30
国内不是头一回了,大佬们今年就干过两场了。国外,有听说过么?
离线BD7OZG
只看该作者 5楼 发表于: 2011-08-30
这个奖品很可爱
oct 8-9, 2011留意一下
离线fuyunfan
只看该作者 6楼 发表于: 2011-08-30
3-500的管子很好呀~!今年关注下~!
离线BA5FB
只看该作者 7楼 发表于: 2011-08-30
这个奖品很可爱
oct 8-9, 2011留意一下
还有9月的ssb,机会总是有的
离线BA4MY
只看该作者 8楼 发表于: 2011-08-30
50个台应该不困难,21兆cw,可以试试
离线曾经拥有
只看该作者 9楼 发表于: 2011-08-31
谁给翻译翻译?
离线赵宇宁
只看该作者 10楼 发表于: 2011-08-31
连东欧的电台都没有通到过。。。
离线BH4SHG
只看该作者 11楼 发表于: 2011-08-31
50个问题不大,可以试试!!!
只会ssb!!!
离线bg2aue
只看该作者 12楼 发表于: 2011-09-01
50个问题不大,可以试试!!!
只会ssb!!!
北欧20米这个数难度不大。
离线BD7IHN
只看该作者 13楼 发表于: 2011-09-01
[quote=曾经拥有]谁给翻译翻译?[/quote]
如果只是想参与一下,不追求比分和名次的话,也就不需要弄清很多事情,记住3件事,就能玩了:
1、在3.5 - 7 - 14 - 21 - 28 mhz五个波段操作;
2、和斯堪地纳地区的业余电台通联(地区和字首如下);
svalbard and bear island jw
jan mayen jx
norway la - lb - lg - lj - ln
finland of - og - oh - oi
aland islands ofØ - ogØ - ohØ
market reef ojØ
greenland ox - xp
faroe islands ow - oy
denmark 5p - 5q - ou - ov - oz
sweden 7s - 8s - sa - sb - sc - sd - se - sf - sg - sh - si - sj - sk - sl - sm
iceland tf
3、通联中交换信号报告包括“rst+通联流水号”。
当然了,比赛时间不要错过,否则频率上可能很安静。
cw比赛: 每年九月第三个完整的周末
ssb比赛:每年十月第二个完整的周末
邮件里说,奖杯最终是通过抽奖决定归属的,所以要得奖,运气也很重要。
离线曾经拥有
只看该作者 14楼 发表于: 2011-09-01
谢谢楼上7ihn赵兄
离线BD1FBV
只看该作者 15楼 发表于: 2011-09-02
09年的sac墙纸,大约50多个qsos.
离线BD7IHN
只看该作者 16楼 发表于: 2011-09-02
[quote=曾经拥有]谢谢楼上7ihn赵兄[/quote]
不客气。其实很多比赛都是大同小异的了,很容易习惯的。
离线BD5XX
只看该作者 17楼 发表于: 2011-09-03
参与一下,争取弄到50个。
离线bg5cdi
只看该作者 18楼 发表于: 2011-09-04
呵呵,esa要急眼了
离线BA1AK
只看该作者 19楼 发表于: 2011-09-04
这个可以有。
