  • 3877阅读
  • 4回复
有谁有条件设置一个igate 带多个tnc接多个电台的测试 [复制链接]
离线BG6JJI
只看楼主 倒序阅读 0楼 发表于: 2011-08-23
如题,比如一个路由器或电脑接多个电台做频率间互通和转发,策略的研究上有些经验可以分享分享。
期待着有人测试,比如uv双段
离线bg6qbv
只看该作者 1楼 发表于: 2011-08-24
同时接了两条usb线,提示错误。
有没有双tnc的脚本?
[error] 2009-02-06 0226 kissserialconnection:: error reading configuration: undefined method `to_i' for true:trueclass
          [warn] 2009-02-06 0256 kissserialconnection:: readframe: ex: execution expired
离线bg6qbv
只看该作者 2楼 发表于: 2011-08-24
同时插了两条usb线的路由器dmesg显示。
usb.c: new usb bus registered, assigned bus number 3
ehci: enabling via 6212 workarounds
ehci_hcd 01:03.2: usb 2.0 enabled, ehci 1.00, driver 2003-dec-29/2.4
hub.c: usb hub found
hub.c: 4 ports detected
usb.c: registered new driver serial
usbserial.c: usb serial support registered for generic
usbserial.c: usb serial driver core v1.4
usbserial.c: usb serial support registered for ftdi sio
usbserial.c: usb serial support registered for ftdi 8u232am compatible
usbserial.c: usb serial support registered for ftdi ft232bm compatible
usbserial.c: usb serial support registered for usb-uirt infrared tranceiver
usbserial.c: usb serial support registered for home-electronics tira-1 ir trans
eiver
ftdi_sio.c: v1.3.5:usb ftdi serial converters driver
usbserial.c: usb serial support registered for pl-2303
pl2303.c: prolific pl2303 usb to serial adaptor driver v0.10.1
hub.c: connect-debounce failed, port 1 disabled
hub.c: new usb device 01:03.0-1, assigned address 2
usbserial.c: pl-2303 converter detected
usbserial.c: pl-2303 converter now attached to ttyusb0 (or usb/tts/0 for devfs)
device wl0 entered promiscuous mode
wl0: attempt to add interface with same source address.
br-lan: port 2(wl0) entering learning state
br-lan: port 2(wl0) entering forwarding state
br-lan: topology change detected, propagating
离线NEC688
只看该作者 3楼 发表于: 2011-08-24
一个igate 带一个tnc接多个电台,多个电台之间的互相转发是有电台硬件链路构成。
也就是说一个igate 只需要一个tnc接 uv机器,uv之间可以相互转发(uv机器设置成中继模式,等于两台中继和tnc构成数据通讯平台)。
移动台无论是持u段还是v段,都可以相互跨段沟通。
离线BG6JJI
只看该作者 4楼 发表于: 2011-08-24
其实这个方式主要是解决多个频率之间的互通互联问题,比如很多digi都用144.640,但是在重叠地区,增加覆盖或者不同速率模式的aprs通信,就需要这种多波段/频率的igate/digi用来互通等操作。
