  • 7371阅读
  • 22回复
极简易CW发射机 [复制链接]
离线BG1TRP
只看楼主 倒序阅读 0楼 发表于: 2011-08-12
在网上看到一cw发射机,电路和实物如下图。
离线BG5CEH
只看该作者 1楼 发表于: 2011-08-12
可以的呀~
离线BH7KQK
只看该作者 2楼 发表于: 2011-08-12
很好,很强大。
离线BG1TRP
只看该作者 3楼 发表于: 2011-08-12
可以的呀~
实物图如下,说明正在看。
离线BG1TRP
只看该作者 4楼 发表于: 2011-08-12
i am not an antenna fanatic and i like to work with the simple stuff, especially when it comes to working with frequencies in the 3.5 and 7 mhz range. fussing around with coax lines, swr, baluns and all that fancy stuff does not usually appeal much to me, nor have i found it at all necessary for getting a signal out. a simple random length of wire thrown into a tree works very well if you can simply adjust the transmitter to put a signal into it.
i certainly am not trying to say this is the best way to make antennas. the point that i wish to emphasize is that the simple techniques that i am describing here, do work well and make good respectable antennas. i have made many many contacts across the pacific ocean and across the united states using simple antennas as described here and just one watt of output power. i have almost always been able to make contacts with stations at least two states away from any given antenna setup using just one watt.
a simple homemade level meter can tell you when you have optimized the signal output to the antenna. the signal meter is capacitively coupled to the antenna and reads it's rf voltage level. a signal level meter can be easily made from a dc microameter and a germanium diode. connect the germanium diode across the meter with the cathode on the positive side. then connect one side of the meter to ground and the other side of the meter to a short wire (one or two feet long) that rests near the antenna wire from the transmitter. it does not matter which side of the meter goes where.
with the key down, adjust the 365 pf variable capacitor in the circuit above for a peak reading on the meter. that is all there is to it. with the circuit described above, a big antenna will tend to swamp the oscillator and prevent it from running. the variable capacitor attains the best compromise between swamping the oscillator and having too little of antenna coupling. the picture above shows a fixed capacitor feeding the antenna. a variable capacitor was first used to peak the signal meter and then an equivalent fixed value capacitor was put in it's place. a capacitor is not necessary at all sometimes with shorter antennas. in this case the antenna can be connected directly to the transistor collector.
this simple meter has worked well on numerous other transmitter projects. this meter can not tell how much power a transmitter is putting out but it is very good for indicating when the transmitter is putting the most signal into the antenna. for a given transmitter, you don't really need to know how much power it is putting out. you just need to know when the transmitter is putting what it is capable of into the antenna. this meter seems to accomplish that.
with all other conditions remaining the same, the more signal voltage there is on the antenna, the more power the antenna is radiating. it is that simple. don't worry about near field and far field theory or any of that stuff. according to theory that i have read, you can not have a near field without having the far (radiating) field.
there is a basic rule about loading an antenna with this signal level meter. the indications from the meter are valid as long as changes or adjustments are made between the meter and anywhere in the transmitter. the meter indications may not be valid for any changes made beyond the meter (farther out the antenna or ground lead).
when you want an idea of how much power the transmitter can put out, it is easy to substitute dummy load resistors at different values in place of the antenna. the peak to peak voltage across the resistor read by an oscilloscope, can then be divided by two and multiplied by .707 to get the rms value. this value when squared and divided by the resistor value will give the power being fed to the resistor according to ohms law. i am usually curious about the values obtained using 50 to 220 ohm resistors.
it appears that the simple circuit shown above can work well into a wide variety of load values without using any additional load matching components. using a 9v battery i measured the transmitter rf output power into several dummy load resistors as described in the previous paragraph. the result was in the range of about 5 to 7 milliwatts. they are listed below.
56 ohms 1.5v pp 5.02 milliwatts
150 ohms 3v pp 7.49 milliwatts
220 ohms 3.5v pp 6.96 milliwatts
510 ohms 5v pp 6.1 milliwatts
i was also able to run this transmitter on 3 volts but the power output was much lower - in the range of 300 to 400 microwatts. these microwatt levels could still be heard (not as strong) several miles away.
the circuit above is far from a representation of the amount of rf power output that can be supplied from a single transistor circuit. the main purpose of this project was to get an idea of what can be accomplished by simply coupling an antenna to a simple oscillator circuit.
it seems that the biggest disadvantage to all this simplicity is the difficulty in knowing exactly how much power is going up the antenna. getting optimum power up the antenna is not nearly as difficult and is the main concept presented here. the dummy load resistors tell how much power can be put out with different loads but the exact load these random length antennas present to the transmitter is a bit more difficult to determine. these questions can be answered by delving into more sophisticated practices.
reference url:http://www.dz3w.com/foreign/rf/7399.html
离线yyh
只看该作者 5楼 发表于: 2011-08-12
这个电路03年的时候我做过,要是把1k的电阻换成线圈的话,功率会比较大,但是电压不能加得过高,会烧管子的
离线徐徐2009
只看该作者 6楼 发表于: 2011-08-12
实际上就是一个振荡电路
离线BG1TRP
只看该作者 7楼 发表于: 2011-08-12
大概功率到了多少?
离线BH1LZE
只看该作者 8楼 发表于: 2011-08-12
这个好 回头做做看看
离线yyh
只看该作者 9楼 发表于: 2011-08-12
大概功率到了多少?
大概300mw
离线BG4ILB
只看该作者 10楼 发表于: 2011-08-12
做个记号
简单而强大
离线BH1MNM
只看该作者 11楼 发表于: 2011-08-13
顶!记号,过些天也弄一个玩玩儿!
离线BG7IRP
只看该作者 12楼 发表于: 2011-08-13
很好,很强大。
离线bd5qce/7
只看该作者 13楼 发表于: 2011-08-14
小时候做过,开始就是用一个线圈,电池在两头碰碰,收音机卡拉卡拉的响,然后慢慢升级到震荡调谐,,,,,,后来还弄上炭精话筒,,,,,,
都不记得了
离线bd8ub
只看该作者 14楼 发表于: 2011-08-14
只能做试验用。真正的要投入实用效果不大
离线BG2VXE
只看该作者 15楼 发表于: 2011-08-14
顶!记号,过些天也弄一个玩玩儿!
离线刺猬
只看该作者 16楼 发表于: 2011-08-17
cw的很好办,买个有源晶振控制其电源通断即可。
离线yyh
只看该作者 17楼 发表于: 2011-08-31
刚做了下,三极管用s8050,把其中1k的电阻改为560欧,电压在12v的时候,工作电流14毫安。
离线bh3pxn
只看该作者 18楼 发表于: 2011-08-31
频率有由哪决定?
离线BG1TRP
只看该作者 19楼 发表于: 2011-08-31
频率有由哪决定?
由石英晶体决定
