  • 4885阅读
  • 7回复
APRS4R求助。。。问题解决。。。是我坐标设置反了呵呵 [复制链接]
离线BD1BSH
只看楼主 倒序阅读 0楼 发表于: 2011-06-18
[error] 2009-12-29 1503 kissserialconnection:: error reading configuration: undefined method `to_i' for true:trueclass
          [error] 2009-12-29 1503 kissserialconnection:: error setting up serial port: no such file or directory - /dev/usb/tts/0
          [error] 2009-12-29 1503 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [error] 2009-12-29 1504 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [warn] 2009-12-29 1504 kissserialconnection:: readframe: ex: private method `getc' called for nil:nilclass
          [log] 2009-12-29 1505 beaconplugin:: sending beacon on device is0: bh1bsh-10 -> ap4r10 via []: (3954.26e/11637.53n&beijing 144.640mhz)
          [log] 2009-12-29 1506 socketsendthread:: message send on is0: bh1bsh-10 -> ap4r10 via []: (3954.26e/11637.53n&beijing 144.640mhz)
          [error] 2009-12-29 1506 aprscall:: empty call
          [error] 2009-12-29 1509 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [warn] 2009-12-29 1510 kissserialconnection:: readframe: ex: private method `getc' called for nil:nilclass
          [error] 2009-12-29 1515 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [warn] 2009-12-29 1516 kissserialconnection:: readframe: ex: private method `getc' called for nil:nilclass
          [error] 2009-12-29 1521 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [warn] 2009-12-29 1522 kissserialconnection:: readframe: ex: private method `getc' called for nil:nilclass
          [error] 2009-12-29 1527 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
我没有接ot盒子。。。。这个就算启动正常了么、为什么在网络上找不到我呢。。。求解。
离线BG6JJI
只看该作者 1楼 发表于: 2011-06-18
这个是没接tnc的错误
网络上找不到需要检查:
1,服务器设定
2,转发设定
上述设定可参考8te老师的视频,或者我的视频
离线BD1BSH
只看该作者 2楼 发表于: 2011-06-18
[error] 2009-12-29 1509 kissserialconnection:: error reading configuration: undefined method `to_i' for true:trueclass
          [error] 2009-12-29 1509 kissserialconnection:: error setting up serial port: no such file or directory - /dev/ttyusb0
          [error] 2009-12-29 1510 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [log] 2009-12-29 1511 beaconplugin:: sending beacon on device is0: bh1bsh-10 -> apavt2 via [wide1-1]: (3954.26e/11637.53n&beijing 144.640mhz)
          [log] 2009-12-29 1511 socketsendthread:: message send on is0: bh1bsh-10 -> apavt2 via [wide1-1]: (3954.26e/11637.53n&beijing 144.640mhz)
          [log] 2009-12-29 1512 beaconplugin:: sending beacon on device rf0: bh1bsh-10 -> apavt2 via [wide1-2]: (3954.26e/11637.53n&beijing 144.640mhz)
          [log] 2009-12-29 1512 socketsendthread:: message send on rf0: bh1bsh-10 -> apavt2 via [wide1-2]: (3954.26e/11637.53n&beijing 144.640mhz)
          [error] 2009-12-29 1512 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [warn] 2009-12-29 1528 kissserialconnection:: readframe: ex: private method `getc' called for nil:nilclass
离线BD1BSH
只看该作者 3楼 发表于: 2011-06-18
我设置的图片。。麻烦老大们看看有什么问题。
小图 | 大图 图片
  • 哈罗CQ火腿社区 - APRS专题 - APRS4R求助。。。问题解决。。。是我坐标设置反了呵呵
离线BD1BSH
只看该作者 4楼 发表于: 2011-06-18
这个是最新启动日志。。。[error] 2009-12-29 1530 kissserialconnection:: error reading configuration: undefined method `to_i' for true:trueclass
          [error] 2009-12-29 1530 kissserialconnection:: error setting up serial port: no such file or directory - /dev/ttyusb0
          [error] 2009-12-29 1530 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [error] 2009-12-29 1531 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [warn] 2009-12-29 1531 kissserialconnection:: readframe: ex: private method `getc' called for nil:nilclass
          [log] 2009-12-29 1532 beaconplugin:: sending beacon on device is0: bh1bsh-10 -> apavt2 via [wide1-1]: (3954.26e/11637.53n&beijing 144.640mhz)
          [log] 2009-12-29 1532 socketsendthread:: message send on is0: bh1bsh-10 -> apavt2 via [wide1-1]: (3954.26e/11637.53n&beijing 144.640mhz)
          [log] 2009-12-29 1533 beaconplugin:: sending beacon on device rf0: bh1bsh-10 -> apavt2 via [wide1-2]: (3954.26e/11637.53n&beijing 144.640mhz)
          [log] 2009-12-29 1533 socketsendthread:: message send on rf0: bh1bsh-10 -> apavt2 via [wide1-2]: (3954.26e/11637.53n&beijing 144.640mhz)
          [error] 2009-12-29 1533 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [error] 2009-12-29 1536 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [warn] 2009-12-29 1537 kissserialconnection:: readframe: ex: private method `getc' called for nil:nilclass
          [error] 2009-12-29 1542 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [warn] 2009-12-29 1543 kissserialconnection:: readframe: ex: private method `getc' called for nil:nilclass
          [error] 2009-12-29 1548 kissserialconnection:: error writing to serial port: private method `puts' called for nil:nilclass
          [warn] 2009-12-29 1549 kissserialconnection:: readframe: ex: private method `getc' called for nil:nilclass
注明下。。我没有连接ot++硬件。。。。
离线BD1BSH
只看该作者 5楼 发表于: 2011-06-18
就是在aprs.fi上显示不出我的位置。。郁闷了
离线BD1BSH
只看该作者 6楼 发表于: 2011-06-18
问题解决了。。是我坐标设置反了。。呵呵
离线BG6QAM
只看该作者 7楼 发表于: 2012-02-19
bd1bsh      2011年6月18日17:40
aprs4r求助。问题解决。是我坐标设定反了呵呵
[error] 2009-12-29 15时37分03秒kissserialconnection ::读取错误配置:未定义的方法`to_i:trueclass
[错误] 2009-12-29 15时37分03秒kissserialconnection ::设立串口的错误:没有那个文件或目录- / dev/usb/tts/0
[错误] 2009-12-29 15时37分03秒kissserialconnection ::错误写入串口:私有方法提出“无偿称为:nilclass的
[错误] 2009-12-29 15时37分04秒kissserialconnection ::错误写入串口:私有方法提出'零呼吁:nilclass
[警告] 2009-12-29 15时37分04秒kissserialconnection :: readframe:ex:私人方法`getc无偿调用:nilclass
[错误] 2009-12-29 15时37分04秒kissserialconnection ::错误写入串行端口:私有方法`看跌“无偿调用:nilclass
[error] 2009-12-29 15 37:04 kissserialconnection ::错误写入串口:私有方法'看跌'零称为:nilclass
[日志] 2009-12-29 15时37分05秒beaconplugin ::发送设备is0灯塔:bh1bsh-10 - > ap4r10通过[]:(3954.26e/11637.53n北京144.640mhz)
[日志] 2009-12-29 15时37分06秒socketsendthread ::消息发送is0:bh1bsh-10 - > ap4r10通过[]:(3954.26e/11637.53 n及北京144.640mhz)
[错误] 2009-12-29 15时37分06秒aprscall ::空调用
[错误] 2009-12-29 15时37分09秒kissserialconnection ::错误写入串口:私有方法`了'无偿:nilclass
[警告] 2009-12-29十五点37分10秒kissserialconnection :: readframe:前:私有方法getc无偿调用:nilclass
[错误] 2009-12-29 15时37分15秒kissserialconnection ::错误写入到串口:私有方法`看跌“要求:无nilclass
[警告] 2009-12-29 15时37分16秒kissserialconnection :::前readframe:私有方法getc无偿调用:nilclass
[错误] 2009年-12-29 15时37分21秒kissserialconnection ::错误写入串口:私有方法提出'零呼吁:nilclass
[警告] 2009-12-29 15点37分22秒kissserialconnection :: readframe:前:私人的方法`getc“零称为:nilclass
[错误] 2009-12-29十五点37分27秒kissserialconnection ::错误写入串口:私有方法提出的要求
bg6jji      2011年6月18日19:34
[error] 2009-12-29 15时37分03秒kissserialconnection ::设立串口:没有这样的文件或目录- / dev/usb/tts/0错误
[error] 2009-12-29 15时37分03秒kissserialconnection ::错误写入串口:私有方法`提出要求
bd1bsh      2011年6月18日22:36
[error] 2009-12-29 15时44分09秒kissserialconnection ::读取错误配置:未定义的方法`to_i:trueclass
[错误] 2009-12-29 15时44分09秒kissserialconnection ::设立串口的错误:没有那个文件或目录- / dev/ttyusb0
[错误] 2009-12-29 15时44分09秒kissserialconnection ::错误写入串口:私有方法提出'零称为:nilclass
[error] 2009-12 - 29 15时44分10秒kissserialconnection ::错误写入串口:私有方法提出'零呼吁:nilclass
[警告] 2009-12-29 15点44分10秒kissserialconnection :: readframe:ex:私有方法getc“无偿调用:nilclass
[错误] 2009-12-29 15时44分10秒kissserialconnection ::错误书面串口:私有方法`看跌“要求:无nilclass
[error] 2009-12-29 15点44分10秒kissserialconnection ::错误写入串口:`了'私有方法称为零:nilclass
[日志] 2009-12-29 15时44分11秒beaconplugin :: is0设备上发送的灯塔:bh1bsh-10 - > apavt2通过[wide1 -1]:(3954.26e/11637.53n北京144.640mhz)
[日志] 2009-12-29 15时44分11秒socketsendthread ::消息发送上is0:bh1bsh-10 - > apavt2通过[wide1-1]:(3954.26e / 11637.53n北京144.640mhz)
[日志] 2009-12-29 15时44分12秒beaconplugin ::发送设备rf0灯塔:bh1bsh 10 - > apavt2通过[wide1-2]:(3954.26e/11637.53n北京144.640mhz)
[日志] 2009-12-29 15时44分12秒socketsendthread ::消息发送rf0:bh1bsh-10 - > apavt2通过[wide1-2]:(3954.26e/11637.53n北京144.640mhz)
[error] 2009-12 - 29 15时44分12秒kissserialconnection ::错误写入串口:私有方法'看跌'零称为:nilclass
[错误] 2009-12-29 15时44分15秒kissserialconnection ::错误写入串口:私有方法`看跌“要求:无nilclass
[警告] 2009-12-29 15时44分十六秒kissserialconnection :: readframe:ex:私有方法getc无偿调用:nilclass
[错误] 2009-12-29 15时44分21秒kissserialconnection ::错误写入串口:私有方法`看跌“要求:无nilclass
[警告] 2009-12-29 15点44分22秒kissserialconnection :: readframe:ex:私有方法getc“零称为:nilclass
[错误] 2009-12-29 15时44分27秒kissserialconnection ::错误写入串口:私有方法'看跌'零称为:nilclass
[警告] 2009-12-29 15时44分28秒kissserialconnection :: readframe:前:私有方法`getc“零称为:nilclass
bd1bsh      2011年6月18日22:50
5个附件
我设置的图片。麻烦老大们看看有什么的问题。
bd1bsh      2011年6月18日22:54
这个是最新启动日志[错误] 2009-12-29十五点28分30秒kissserialconnection ::读取错误的配置。未定义的方法`to_i“真正的trueclass
[错误] 2009-12-29 15点28分30秒::错误kissserialconnection设立串口:没有这样的文件或目录- / dev/ttyusb0
[错误] 2009-12-29 15点28分30秒kissserialconnection ::错误写入串行端口:私有方法`了'零称为: nilclass
[错误] 2009-12-29 15时28分31秒kissserialconnection ::错误写入串口:私有方法看跌“要求:无nilclass
[警告] 2009-12-29 15点28分31秒kissserialconnection :: readframe :ex:私有方法`getc“零称为:nilclass
[错误] 2009-12-29 15时28分31秒kissserialconnection ::错误写入串口:私有方法提出“呼吁无偿nilclass
[错误] 2009 - 12-29 15时28分31秒kissserialconnection ::错误写入串口:私有方法`看跌“要求:无nilclass
[日志] 2009-12-29 15点28分32秒beaconplugin ::发送设备is0灯塔:bh1bsh -10 - > apavt2通过[wide1-1]:(3954.26e/11637.53n北京144.640mhz)
[日志] 2009-12-29 15点28分32秒socketsendthread ::消息发送上is0:bh1bsh-10 - > apavt2通过wide1-1]:(3954.26e/11637.53n和北京144.640mhz)
[日志] 2009-12-29 15时28分33 ​​秒beaconplugin ::发送rf0设备上的灯塔:bh1bsh-10 - > apavt2通过wide1-2]:( 3954.26e/11637.53n北京144.640mhz)
[日志] 2009-12-29十五点28分33 ​​秒socketsendthread ::消息上rf0发送:bh1bsh-10 - > apavt2通过[wide1-2]:(3954.26e/11637.53n北京144.640mhz )
[error] 2009-12-29 15时28分33 ​​秒kissserialconnection ::错误写入串口:私有方法'看跌'零称为:nilclass
[错误] 2009-12-29 15点28分36秒kissserialconnection ::错误书面串口:私有方法提出'零呼吁:nilclass
[警告] 2009-12-29 15时28分37秒kissserialconnection :: readframe:ex:私有方法getc“零称为:nilclass
[错误] 2009 - 12-29十五时28分42秒kissserialconnection ::错误写入串口:私有方法`看跌“要求:无nilclass
[警告] 2009-12-29 15点28分43秒kissserialconnection :: readframe:前:私有方法` getc零呼吁:nilclass
[错误] 2009-12-29十五时28分48秒kissserialconnection ::错误写入串口:私有方法`看跌“无偿调用:nilclass
[警告] 2009-12-29 15时28分:49 kissserialconnection :: readframe:例如:私有方法getc“零称为:nilclass 注明下号我没有连接处加时赛+硬件。。
bd1bsh      2011年6月18日22:56
就是在aprs.fi上显示不出我的位置。郁闷了
bd1bsh      2011年6月18日23:25
的问题解决了。是我坐标设定反了。呵呵
