  • 3661阅读
  • 4回复
来自AO-51的消息 [复制链接]
离线BH1IEO
只看楼主 倒序阅读 0楼 发表于: 2011-05-02
ao-51 will be off for 24 hours or more beginning may 1 to attempt to recondition a failing battery cell. ao-51 isn't going to last forever, so please consider using the above widget and help us out with ao-51's replacement, fox.
73, drew ko4ma
离线浦东星
只看该作者 1楼 发表于: 2011-05-02
ao- 51将关闭24小时,5月1日开始尝试整修一个失败的电池或更多。敖- 51是不会永远持续下去,所以请考虑使用上述部件,帮助采用ao - 51的替代品,福克斯我们。
离线CQforever
只看该作者 2楼 发表于: 2011-05-02
啊。。。。。。。。。。。。。。。。。。
离线BH1IEO
只看该作者 3楼 发表于: 2011-05-08
终于挂了!!
all,
we are having a difficult time trying to restore ao-51 to operation. currently, the satellite will not retain the upload of the flight software across eclipse. the batteries are in very poor condition. we have a few more things to try, but with eclipses peaking around july at ~27 minutes, the long term situation is grim. there is a brief period around november where eclipses are as short as 16 minutes, but past that it is a long climb to 30 minutes or longer eclipses for many years. we have no expected "return to service" date. if you have 9k6 digital capability, you can listen in on our attempts at recovery on 435.150 on many passes over the us.
please support amsat-na and the other amsat groups around the world, and help us get new satellites into orbit. projects like fox, funcube, p3e, and kiwisat need your financial support to keep our amateur satellite fleet flying.
73, drew ko4ma
amsat-na vp operations
离线胡线电
只看该作者 4楼 发表于: 2011-05-08
沉痛哀悼,,,,、
