  • 4060阅读
  • 10回复
AO-51怎么了 电量不足吗?? [复制链接]
离线BG2TOS
只看楼主 倒序阅读 0楼 发表于: 2011-04-21
今天两次过顶7.16--7.30   9.00--9.15 (utc)
前半段下行信号一点没有 后半段突然出现
两次都是这样   .......
只看该作者 1楼 发表于: 2011-04-21
你的频率校正正确吗。
离线BH1IEO
只看该作者 2楼 发表于: 2011-04-21
基本每天都打打,就是这两天感觉不正常了。
离线BH1IEO
只看该作者 3楼 发表于: 2011-04-21
http://forums.qrz.com/showthread.php?293108-ao51-possibly-down
we are receiving reports that ao-51 appears to be down. hopefully one
of us can get it going again this afternoon/evening.
eclipses are still getting longer, and the sun angle is getting worse,
too. it probably has experienced a low battery trip (least we hope
it's that simple...)
离线BG2TOS
只看该作者 4楼 发表于: 2011-04-22
ao-51 schedule - until further notice
mode v/u fm voice repeater (**67 hz pl tone required**)
uplink: 145.880 mhz fm (temporarily from 145.920)
downlink 435.300 mhz fm
as always, command stations may need to reconfigure modes in order to collect telemetry as needed.
remember that power management is running, and the transmitter(s) will shut off during periods of eclipse and/or low battery voltage.
73,
mark n8mh
ao-51 command team
updated: 21 apr, 11
最后一句话 道出原因
离线BH1IEO
只看该作者 5楼 发表于: 2011-04-22
今天也不太妙,但稍后喊喊看。
hello ao-51 users,
as you have noticed, ao-51 has recently experienced a few shutdowns
due to a low battery voltage trip. this is because of increasing
eclipses (now at 20 mins per orbit and increasing), poor sun angles
(still getting worse), and a "weak" battery.
we are now using the 67 hz pl tone required mode in order to turn the
transmitter(s) off when not in use. the transmitter power is down to
about 550 mw. we will continue adjusting various parameters,
including transmitter power, trigger voltages, etc. in order to keep
the battery temperatures reasonable. keep in mind that the power
management feature keeps the transmitter(s) off during eclipses, so
you can't bring it up even with a pl tone while the satellite is in
eclipse.
here is our current schedule, which will continue until further notice:
ao-51 schedule
the ao-51 command team can use your help!
离线BH1IEO
只看该作者 6楼 发表于: 2011-04-22
看来ao-51被楼主玩挂了。
离线BG2TOS
只看该作者 7楼 发表于: 2011-04-22
呵呵
今天一点儿信号都没有了....
离线BG2TOS
只看该作者 8楼 发表于: 2011-04-22
世界各地火腿也关注着ao-51
离线bg6ahu
只看该作者 9楼 发表于: 2011-04-23
挂了在发个上去
离线BG2TOS
只看该作者 10楼 发表于: 2011-04-28
今天
两次过顶 都无信号
