  • 5509阅读
  • 10回复
IC-756PRO 2和3有何区别 [复制链接]
离线bh1ktl
只看楼主 倒序阅读 0楼 发表于: 2011-03-22
请老师来讲讲
离线BA7IA
只看该作者 1楼 发表于: 2011-03-23
电路硬件上,接收前置放大器重新设计,动态范围更大,换用更强悍的32bitdsp,24bita/d变换器,dsp控制agc。
软件功能增加很多新功能。比如发射/接收共8段数字录音,并可以用外部开关控制重放。可以调整滤波器的带通形状,发射音频均衡调整。
离线bh1ktl
只看该作者 2楼 发表于: 2011-03-25
谢谢7ia大大
还有人补充没
只看该作者 3楼 发表于: 2012-04-05
谢谢   好贴
离线bg4agr
只看该作者 4楼 发表于: 2012-04-05
7ia, 好像以下几点不是pro2和pro3的区别吧,pro2也支持。硬件上除了rf板,后期的pro2和pr3其他主板都完全一样,除了cpu里面灌的fw不同。
离线bg4agr
只看该作者 5楼 发表于: 2012-04-05
the icom 756 pro iii was the last member of the venerable "756" family that started with the 756, 756 pro, 756 proii. this latest version offers some incremental improvements over the previous 756 pro ii:
improved third order intercept point of +30dbm
real time spectrum scope (with mini-scope)
the ic-756 pro ii spectrum scope display occupied the lower half of the screen. the ic-756pro iii provides a selectable mini-scope display mode. this allows simultaneous display of the filter, memory-keyer and other menus along with a half-size spectrum-scope display.
60 meter 5 mhz band
improved 1st filter and bpf for reduced distortion
preamp changed to a noiseless feedback type to reduce second order distortion.
new itu morse "@" symbol
the new "@" symbol is provided even with the memory keyer enabled.
programmable ssb transmit bandwidth
the ic-756 pro ii provided three selectable tobw settings: wide/mid/nar. the lower and upper -6db points of the transmitted audio-frequency response are fixed for each setting. in the ic-756pro iii, it is possible to program each of the three settings individually with the following preset cutoff frequencies: lower -6db point: 100, 300 and 500 hz., upper -6db point: 2.5, 2.7 and 2.9 khz.
this permits the operator to configure his own custom wide/mid/nar selections by mixing and matching low and high roll-off points.
clock function displays local time and utc time with time difference indication
screen saver function to prolong lcd life and reduce burn-in.
离线bg4agr
只看该作者 6楼 发表于: 2012-04-05
pro2和pro3的板子可以完全互换,其实除了显示上多了点功能,其他部分基本没有什么变化。
你把pro3的主cpu贴到pro2上也可以
离线BG9ALM
只看该作者 7楼 发表于: 2012-04-05
贴上一张曾经别人发的图希望能对你有帮助
最明显的感觉p2的nr会随着时间慢慢消失,但是通过按一下ptt可以重新激活.不知道还有没有朋友在使用p2时也有这个感觉?一直不知道为什么会这样设计.
离线bg4agr
只看该作者 8楼 发表于: 2012-04-05
老外曾经讨论过这个现象,有人认为是fw的一个bug, 有人认为是特意这样设计自适应。
不管怎么说,p3后就改了fw,去掉了这个现象 。
离线bh7ni
只看该作者 9楼 发表于: 2012-04-06
要学习一下。。。
离线bh1ktl
只看该作者 10楼 发表于: 2012-05-17
继续向各位大大学习.......
手机:13911870876
