  • 5473阅读
  • 12回复
2010 WPX CW报告来了.这次糗大了啊,居然错这么多 [复制链接]
离线BD4SQ
只看楼主 倒序阅读 0楼 发表于: 2011-03-07
contest:   wpxcw10
call:     bd4sq
category: single operator assisted low power all band
thank you for submitting a log in the 2010 cq wpx cw contest.
your log checking report is below. we believe it is helpful for participants
to receive information on the errors found in their log. we hope you use
this opportunity to look for ways to improve. remember, a big part of
contesting is the goal of perfect information exchange.
explanation of the report sections:
summary - a summary of the log checking results and final score for your
entry.
results by band - a band-by-band breakdown of the qsos and points for your
entry.
not in log - these contacts were not found in the other station's log. the qso
was removed with additional penalty.
incorrect call - the call logged for these contacts was determined to be
incorrect. the qso was removed with additional penalty.
incorrect exchange information - the exchange information you copied does
not match what was in the other station's log. the qso was removed.
time violations - single operator only. shows all qsos made after the 36 hour
operating time limit. the qso was removed.
unique calls worked - these calls were not found in any other log. they
have not been removed, but our experience indicates they are often the result
of copying errors.
band change violations - multi-single and multi-two only. shows all qsos where
a band change did not meet the rules. the qso was removed.
lost multipliers - this section lists the multipliers that were lost in your
log due to callsign or exchange copying errors.
multipliers - this section lists all prefixes that were counted as
multipliers in your log.
stations copying your exchange incorrectly - this is a list of contacts
where the station you worked copied your exchange incorrectly. you do not
lose credit for these contacts. they are only provided for your information.
stations copying call incorrectly - this is a list of all contacts we
could identify where the station you worked copied your call incorrectly.
you do not lose credit for these contacts. they are only provided for your
information. if you have a lot of similar errors, you should concentrate on
ways to send your call differently that may be easier for others to correctly
copy.
all logs are checked using custom software. if you believe an error was
made, please provide us with more information. it may help us do a better job
in the future. do not expect us to engage in a debate about whether a
particular qso was valid or not. the decisions of the cq wpx committee are
final.
73,
randy thompson, k5zd
director, cq wpx contest
email: k5zd@cqwpx.com
web: www.cqwpx.com
************************** summary ***************************
  474 claimed qso before checking (does not include duplicates)
  440 final   qso after checking reductions
  803 claimed qso points
  691 final   qso points
  198 claimed mults
  185 final   mults
158994 claimed score
127835 final   score
-19.6% score reduction
    2 (0.4%) duplicates (without penalty)
    12 (2.5%) calls copied incorrectly
    19 (4.0%) exchanges copied incorrectly
    3 (0.6%) not in log
    2 (0.4%) calls unique to this log only (not removed)
********************** results by band ***********************
          band   qso qpts mult
  claimed   160m   0   0   0
  final     160m   0   0   0
  claimed     80m   4   7   0
  final     80m   3   5   0
  claimed     40m   94   260   0
  final     40m   83   216   0
  claimed     20m   188   250   0
  final     20m   175   213   0
  claimed     15m   176   274   0
  final     15m   167   245   0
  claimed     10m   12   12   0
  final     10m   12   12   0
  claimed     all   474   803   198 score   158994
  final     all   440   691   185 score   127835
************************* not in log *************************
21045 cw 2010-05-29 0633 bd4sq       124 yl6w       564
21029 cw 2010-05-30 0342 bd4sq       365 it9blb       626
14003 cw 2010-05-30 1055 bd4sq       418 ja1kev       197
*********************** incorrect call ***********************
14018 cw 2010-05-29 0017 bd4sq       10 xv1v         4 correct   xv1x
14018 cw 2010-05-29 0031 bd4sq       24 ba1hn         7 correct   ba1sn
14018 cw 2010-05-29 0036 bd4sq       27 je7kgh/7     16 correct   je8kgh
7016 cw 2010-05-29 1057 bd4sq       213 7j7sk       25 correct   8j7sk
14028 cw 2010-05-29 1439 bd4sq       270 yt0a       1082 correct   yt9a
14036 cw 2010-05-29 1510 bd4sq       276 uw5w       983 correct   uw5m
14016 cw 2010-05-29 2239 bd4sq       294 7j7sk       149 correct   8j7sk
21020 cw 2010-05-30 0021 bd4sq       320 7j7sk       71 correct   8j7sk
21020 cw 2010-05-30 0044 bd4sq       337 by5ham       478 correct   by4ham
14003 cw 2010-05-30 1105 bd4sq       420 ja8apn/1     41 correct   ja8apb
7031 cw 2010-05-30 1341 bd4sq       450 ra0ll       499 correct   ru0ll
7033 cw 2010-05-30 1359 bd4sq       454 jg3kqj       216 correct   jg3cqj
*************** incorrect exchange information ***************
21041 cw 2010-05-29 0658 bd4sq       132 s50a       766 correct 776
14032 cw 2010-05-29 0829 bd4sq       154 wc6h         27 correct 427
14003 cw 2010-05-29 0903 bd4sq       174 ja5apu       16 correct 145
7031 cw 2010-05-29 1221 bd4sq       241 ja1bji       287 correct 297
3506 cw 2010-05-29 1228 bd4sq       244 jf3lop       40 correct   48
7034 cw 2010-05-29 1400 bd4sq       256 jg3wdn       92 correct 192
7034 cw 2010-05-29 1403 bd4sq       259 w1cu       514 correct 623
7034 cw 2010-05-29 1417 bd4sq       267 ja5atn       16 correct   61
21026 cw 2010-05-30 0122 bd4sq       341 b5a         921 correct 931
21029 cw 2010-05-30 0328 bd4sq       360 yc1bjx       370 correct 380
14026 cw 2010-05-30 0729 bd4sq       377 kh6lc       123 correct 1239
21033 cw 2010-05-30 0942 bd4sq       399 uw3u       291 correct 2592
21033 cw 2010-05-30 0944 bd4sq       401 yb3boa       83 correct 283
14004 cw 2010-05-30 1223 bd4sq       434 yl3ft       1389 correct 1380
14032 cw 2010-05-30 1250 bd4sq       440 yl6w       2147 correct 2157
7033 cw 2010-05-30 1355 bd4sq       452 ja7ftr       268 correct 278
7033 cw 2010-05-30 1357 bd4sq       453 ak6m       705 correct 805
7033 cw 2010-05-30 1406 bd4sq       458 ky0w       139 correct 1319
7034 cw 2010-05-30 1643 bd4sq       472 ra1agl     1273 correct 1373
************* unique calls worked (not removed) **************
7016 cw 2010-05-29 1049 bd4sq       206 jf2xqc       2
14022 cw 2010-05-30 0908 bd4sq       391 jh2kck       28
********************** lost multipliers **********************
7016 cw 2010-05-29 1057 bd4sq       213 7j7sk       25 incorrect call
7033 cw 2010-05-30 1357 bd4sq       453 ak6m       705 incorrect exchange
21026 cw 2010-05-30 0122 bd4sq       341 b5a         921 incorrect exchange
21020 cw 2010-05-30 0044 bd4sq       337 by5ham       478 incorrect call
7033 cw 2010-05-30 1406 bd4sq       458 ky0w       139 incorrect exchange
7034 cw 2010-05-30 1643 bd4sq       472 ra1agl     1273 incorrect exchange
21033 cw 2010-05-30 0942 bd4sq       399 uw3u       291 incorrect exchange
14036 cw 2010-05-29 1510 bd4sq       276 uw5w       983 incorrect call
7034 cw 2010-05-29 1403 bd4sq       259 w1cu       514 incorrect exchange
21029 cw 2010-05-30 0328 bd4sq       360 yc1bjx       370 incorrect exchange
14004 cw 2010-05-30 1223 bd4sq       434 yl3ft       1389 incorrect exchange
21045 cw 2010-05-29 0633 bd4sq       124 yl6w       564 not in log
14028 cw 2010-05-29 1439 bd4sq       270 yt0a       1082 incorrect call
************************ multipliers *************************
  4f1   4l8   4o3   6k2   6l0
  7j1   7k1   7k3   7m2   9a5
  9m6   9v1   af6   ah0   ah2
    b1     b4     b7   ba1   ba4
  ba5   ba6   ba7   bd1   bd2
  bd5   bd7   bg3   bg6   bh1
  bt4   bv3   bv4   bw0   bw4
  bx0   bx3   by4   by8   df1
  dl7   dm9   ds0   ds1   ds3
  ds5   dt0   du1   du3   e21
  e24   e73   em7   er0   es9
  ha3   hg1   hl1   hl2   hl5
  hs0   it9   ja0   ja1   ja2
  ja3   ja4   ja5   ja6   ja7
  ja8   ja9   je1   je3   je4
  je6   je7   jf1   jf2   jf3
  jg1   jg3   jg5   jh0   jh1
  jh2   jh3   jh4   jh6   jh7
  jh8   ji1   ji4   jj1   jj6
  jk1   jk2   jk3   jl1   jl3
  jm1   jm4   jn3   jo1   jo3
  jp1   jq1   jr1   jr2   jr3
  jr4   jr5   jr6   jr9   js1
  js6   jt1   kg6   kh2   kh6
  kh7   kr7   kx7   lp2     n6
  nd2   nx6   og0   ol1   om0
  om7     r7   ra0   ra9   rg3
  rk8   rk9   rt3   rt4   ru0
  ru1   rv9   rw2   rw3   rw9
  rx9   rz9   s50   s52   s53
  sn9   tm33   ua0   ua3   ua5
  ua6   ua9   ui9   un4   un9
  up0   up2   uu1   uu2   uw1
  uw2   vk2   vk4   vk6   vr2
    w6   wc6   xu7   xv1   xv2
  yb3   yb4   ye1   yo7   yo9
  yt1   yt9   yu1   zm1   zx5
********* stations copying your exchange incorrectly *********
14039 cw 2010-05-29 0101 xu7acy       67 bd4sq       004 should be   41
14038 cw 2010-05-29 0117 hl5yi       35 bd4sq       055 should be   52
14000 cw 2010-05-29 0132 hs0ac       18 bd4sq       0064 should be   61
21023 cw 2010-05-29 0224 hl5yi       48 bd4sq       081 should be   98
21053 cw 2010-05-29 0654 s52zw       98 bd4sq       0033 should be 130
14000 cw 2010-05-29 0910 ja1bfn       41 bd4sq       0278 should be 178
14003 cw 2010-05-29 0927 vr2iz       104 bd4sq       0182 should be 186
14000 cw 2010-05-29 1109 je1reu       204 bd4sq       226 should be 216
7000 cw 2010-05-29 1340 kh6lc       528 bd4sq       0150 should be 250
21020 cw 2010-05-30 0004 vr2iz       160 bd4sq       0320 should be 310
21020 cw 2010-05-30 0027 jh7rtq       135 bd4sq       236 should be 326
21019 cw 2010-05-30 0723 yb4ir       438 bd4sq       0372 should be 376
************* stations copying bd4sq incorrectly *************
21000 cw 2010-05-29 0629 ji4whs       27 bd3sq       123
14000 cw 2010-05-29 0858 jo3evm       14 bd4sy       169
7029 cw 2010-05-29 1114 wc6h       506 6d4sq       218
7000 cw 2010-05-29 1126 jf2rcx       62 bd4hq       225
3514 cw 2010-05-29 1200 jh1eaq       272 bd4eq       0237
7031 cw 2010-05-29 1220 ja1xms       124 bz4sq       0240
7034 cw 2010-05-29 1406 af6t       280 bd4hq       0261
14036 cw 2010-05-29 2132 it9muo       945 bd4hq       179
7008 cw 2010-05-29 2151 s53m       930 bd4rq       0082
21000 cw 2010-05-30 0002 ja7ftr       157 bd4iq       303
21000 cw 2010-05-30 0038 jr4pdp       197 bd4sd       333
21026 cw 2010-05-30 0122 b5a         931 bd4hq       0341
21000 cw 2010-05-30 0944 yb3boa       283 bd14sq       401
14031 cw 2010-05-30 1250 yl6w       2157 6d4sq       440
太惨了,要回炉了.
离线BA1RB
只看该作者 1楼 发表于: 2011-03-07
这个正常,要抄数字,容易抄错。
你这个属于自然成绩,不象版主,还要check check搞点名堂...
离线BG4AHF
只看该作者 2楼 发表于: 2011-03-07
严重投诉b1z, 我居然not in log
离线BD4QK
只看该作者 3楼 发表于: 2011-03-07
19.6%, 我们已决定先向您学习了,我们这里经常是20朝外的
离线kentwu
只看该作者 4楼 发表于: 2011-03-08
别着急,加油。哈哈
离线BA4TB
只看该作者 5楼 发表于: 2011-03-08
还好,比较正常,wpx是要抄数字的。
离线BD4SQ
只看该作者 6楼 发表于: 2011-03-08
谢谢各位鼓励
现在比赛软件已经转到wintest了,下次比赛全程录音.检查一遍再交,应该好很多.
离线ba6iv
只看该作者 7楼 发表于: 2011-03-08
我的也被扣了7000多分,郁闷!
离线bg4ffm
只看该作者 8楼 发表于: 2011-03-08
我本身qso数量少,被扣了15%
离线BA1RB
只看该作者 9楼 发表于: 2011-03-08
啊?哈哈,有这事?
离线BD4SP
只看该作者 10楼 发表于: 2011-03-08
以后比赛少弄些qso,搞个几千个,检查要弄死人的。
离线BD4QK
只看该作者 11楼 发表于: 2011-03-08
俺已死过几次了,但估计还得再死几年
离线BD4SP
只看该作者 12楼 发表于: 2011-03-12
俺已死过几次了,但估计还得再死几年
我专业check,要代工么
