  • 6724阅读
  • 2回复
MMSSTV113A Repeater Mode 简介 [复制链接]
离线BD4DLN
只看楼主 倒序阅读 0楼 发表于: 2011-03-03
mmsstv113a repeater mode 简介
头一次干这个事
欢迎提意见,翻得不好,将就看,有意见您提
多谢
附件: Repeater Mode.pdf (0 K) 下载次数:157
离线BD4DLN
只看该作者 1楼 发表于: 2011-03-03
mmsstv113a.exe 转发模式介绍及设置
repeater mode
转发模式
running mmsstv as a repeater
以转发模式运行mmsstv
to run mmsstv in the repeater mode, add "-r" option:
要以转发模式运行mmsstv,需要在程序的运行设置上加上”-r”的属性
mmsstv.exe -r what that means is right click on the mmsstv icon on your desktop. choose properties, then put the -r after the " . make sure there is one space after the " then put -r. see the picture.
mmsstv.exe –r 意思是,你用鼠标右键点击mmsstv的桌面快捷方式,在出来的如下的对话框里,加上’-r’ 字符,记得在冒号后面加上一个空格.
while mmsstv is running in the repeater mode, all the standard functions are still operational. enjoy sstv as you usually do.
当mmsstv以转发器模式运行的时候,所有标准的功能都正常运行,你可以像平时一样享受你的sstv操作.
if you want to add your call sign and/or the time stamp to the beacon or replay pictures, use templates. you can specify various templates for these purposes.
如果你想添加你的呼号和(或者)时间到信标或者
you can change the transmission mode of the replay picture in accordance with the mode of the received picture. uncheck "fixed mode" in the tx tab of the mmsstv setup option. mmsstv uses the same mode as the received picture.
为了使回复的图片模式与接收到的照片模式一致,你可以修改发送模式.在mmsstv 设置选项里的tx选项卡上取消选择”修改模式”
it is recommended to use hilbert transform for the fm demodulator for better image quality. turn on or off "auto stop," "auto restart," and "auto resync" options as you prefer.
离线bg7nfm
只看该作者 2楼 发表于: 2011-03-10
这个功能开发的好
