  • 4246阅读
  • 6回复
daiwa 也出新表了!3KW [复制链接]
离线BA1IO
只看楼主 倒序阅读 0楼 发表于: 2011-02-22
product description
professional series bench meter
3kw version of the cn-801hp
frequency: 1.8-200mhz
3000w forward power
true pep reading
cross needle design
led lighting, with on/off switch
anti-slip corner guards
只看该作者 1楼 发表于: 2011-02-22
801新的系列产品?以前的cn801hp的评价不错.
附件: wattpaddle.pdf (0 K) 下载次数:60
离线BA1IO
只看该作者 2楼 发表于: 2011-02-22
[quote=老干部]801新的系列产品?以前的cn801hp的评价不错.[/quote]
恩恩!新产品!hp3么!老frank昨晚发来的邮件!
美国比较贵!1k5左右到手!等等国内大大吧!
离线BA1IO
只看该作者 3楼 发表于: 2011-02-22
只看该作者 4楼 发表于: 2011-03-22
新的801hp3好像程都是3,如30w,300w和3kw满刻度。另外是n头的。
附件是801hp原版本的图纸,大量程有额外的二极管校正刻度,以便公用一条小功率的刻度。
在eham上对这个表的电路有以下几点zl3ag认为要改:
when i investigated the circuit, found that the peak hold timing was acheived with a 220uf electrolytic with 2k ohms accross it. considering the limited current delivery of a 358 op-amp, the 220uf was never going to charge successfully with syllabic-rate dc drive. i replaced the 220uf with a low leakage 0.47uf capacitor and the 2k with 3megohm. recalibrated and now marvellous. nothing wrong with my linear.
附件: CN-801HP Schematic.pdf (0 K) 下载次数:43
离线BH3PYF
只看该作者 5楼 发表于: 2011-03-22
你们都是大大 尤其是还没见到就提出改正建议的 是 大大大大
离线bg3qjf
只看该作者 6楼 发表于: 2011-03-22
楼上夜猫子
