  • 3088阅读
  • 1回复
学生们在训练和NA1SS通联中 [复制链接]
离线BH1IEO
只看楼主 倒序阅读 0楼 发表于: 2011-02-17
http://www.livestream.com/iz2shs/video?clipid=pla_a3165df1-59a3-4884-b311-9ff7a86fd533&utm_source=lslibrary&utm_medium=ui-thumb
istituto di istruzione superiore “claudio varalli,” milano, italy - paolo nespoli, izØjpa
thursday, february 17, 2011
telebridge station w5rrr in houston, texas, usa will call na1ss at approximately 10:33 utc.
离线BH1IEO
只看该作者 1楼 发表于: 2011-02-17
这是准备的问题,当然是用意大利语对话的。
1. what’s your typical day on the iss?
2. what’s the temperature range in space and which insulating materials are needed by the iss?
3. according to your personal experience, how does human body reacts to life in space?
4. what’s your main task on this mission?
5. what kind of experiments are you carrying on? concerning medicine, biology, mechanics or else?
6. which path led you to become an astronaut?
7. which physical requirements are neede to become an astronaut?
8. is there an experiment among those you have carried out which has particularly interested you and which you can tell us about?
9. considering how important communication is on the iss, has being a radio amateur helped you in your career as an astronaut?
10. do you have a special diet while on orbit?
11. which is the primary source of energy on the iss?
12. which systems are adopted ro reduce consumption of energy on the iss?
13. is it possible to see from space the most polluted areas of the earth?
14. did you find it easy to interact with astronauts of different countries?
15. is it possible to see any human buildings on the earth from the iss?
16. if you fall ill, do you have any special treatment?
17. can you tell us something about the new comunication satellite arissat-1/radioskaf v?
18. can communication with the earth be disturbed by magnetic storms or other phenomena?
19. how do you perform daily activities in a state of zero gravity?
20. how long do day and night last on the iss and how do you get used to it?
21. how do meteors and bolids appear to you in space and how is the iss protected from them?
22. are you carrying on studies on the atmosphere which can be useful for meteorology?
