  • 3164阅读
  • 2回复
实况守听NA1SS [复制链接]
离线BH1IEO
只看楼主 倒序阅读 0楼 发表于: 2011-02-11
现在是实况:telebridge station w5rrr in houston, usa will call na1ss at approximately 12:48 utc.
on2dg (muted)
->ag9d john
iw2ohi (muted)
kc9eoq (muted)
n5jld (muted)
nt5sm (muted)
bh1ieo-l (muted)
*jk1zrw* (muted)
离线BH1IEO
只看该作者 1楼 发表于: 2011-02-11
守听录音:http://disk.kugou.com/player/0/5/0/1/default/200/6461ef8b76398f2b/mini.swf
lillestrøm videregående skole, lillestrøm, n-2001, norway, telebridge via w5rrr
contact is a go for: fri 2011-02-11 1226 utc 81 deg
bh1ieo-l>11 february at 12:48 utc - lillestr?m videreg?ende skole, lillestr?m, norway?
bh1ieo-l>telebridge station w5rrr in houston, usa will call na1ss at approximately 12:48 utc.
ag9d>the contact is in norwegian
bh1ieo-l>thank you
nt5sm>good visual from dallas
ag9d>must be some obscuration from the structure of iss
ag9d>or los
ag9d>i know where rrr is i shouldn't think it was ground obscuration
ag9d>sometimes the station blocks the signal
bh1ieo-l> 73
ag9d>there is one more contact this wee
ag9d>tommor at 1507 utc
ag9d>with the astronomical observatory in bologna italy
ag9d>audio will be here starting about 20 minutes before aos
bh1ieo-l>ok
ag9d>i will return the server to regular use momentairly
nt5sm>73 and tnx
bh1ieo-l>goodbye 73!
kc9eoq>see you at 1pm john, 73
iw2ohi>73 from italy, ciao
离线BH1IEO
只看该作者 2楼 发表于: 2011-02-11
看来是意大利的天地通联,继续溜达过去。
12 february at 15:07 utc - national institute for astrophysics – astronomical observatory of bologna, bologna, italy
