  • 11347阅读
  • 72回复
ARISSat1测试中即将释放到空中 [复制链接]
离线bd5rv
只看楼主 倒序阅读 0楼 发表于: 2011-02-11
根据arissat-1 twitter的消息,今天宇航员将arissat-1的收发机接到了iss外部天线上,进行发射测试。目前,南美、北美、新西兰均有收听报告。
http://twitter.com/arissat1
离线i86net
只看该作者 1楼 发表于: 2011-02-11
坐坐沙发。。。。。。。。。。。。。。。。
离线bd5rv
只看该作者 2楼 发表于: 2011-02-11
ARISSat1计划6天以后通过太空行走释放到空中
countdown to arissat-1 deployment - 6 days
gould smith, amsat's arissat-1 project manager is pleased to report that the progress cargo mission carrying arissat-1 has arrived and docked at the iss.the next tasks are for the crew members to re-attach the handles, install the battery, replace the dummy loads with the real antennas. they will replace the lexan solar panel covers with hook and loop quilted covers before the eva on 16 february. the eva will be broadcast live on the nasa tv channel. the crew will connect the arissat-1 transmitter to an iss external antenna and perform a short test of the satellite transmissions thursday 10 feb. we expect to release the free arissattlm software next week. this will demodulate, decode and display the bpsk-1000 telemetry and experiment data as well as the cw signal.
离线bd5rv
只看该作者 3楼 发表于: 2011-02-11
arissat-1
name: arissat-1   alternate names: radioskaf-v, kedr
satellite type: microsatellite
launch date to iss: 28 january 2011
launch location: baikonur
dimensions: 55 cm x 55 cm x 40 cm
weight: 30.0 kg
organization: amsat, nasa, rsc energia and ariss
frequency information
mode v fm (voices messages and telemetry): non-operational
downlink 145.9500 mhz fm
mode v fm imaging (robot-36 sstv from onboard cameras): non-operational
mode v ssb telemetry (bpsk-1000 bps): non-operational
downlink 145.9200 mhz bpsk
mode v ssb tlm beacon (cw-2, active with bpsk-1000): non-operational
downlink 145.9190 mhz cw
mode u/v (b) linear transponder (inverting): non-operational
uplink: 435.7580 - 435.7420 mhz ssb/cw
downlink 145.9220 - 145.9380 mhz ssb/cw
callsign: rs01s (is the transmitted callsign)
          radioskaf-v is a russian designation
          kedr is another designation to honor yuri gagarin's pilot callsign
          during the first manned spaceflight 50 years ago
detailed description
arissat-1 is a microsat developed as a follow-on to the suitsat-1 project. the satellite was launched to the iss on january 28th, 2011, with deployment into space during an eva (spacewalk) on february 16, 2011.
the satellite will downlink live sstv images from four onboard cameras as well as 24 greetings in 15 languages on the fm voice frequency 145.95 mhz. the bpsk-1000 sig downlinks as ssb on 145.920 mhz, with the cw signal below the bpsk signal to be used as a tuning indicator for the bpsk signal. telemetry and amateur radio callsigns of those instrumental in amatuer radio in space will be transmitted at 145.919 mhz. for the amateur radio operators there is a 16khz wide transponder for two-way contacts. all of the transmissions and receicvers use newly created software defined radio technology.
the bpsk-1000 signal will include alternating telemetry and experiment data packets. telemetry data will include spacecraft subsystem information such as temperature, voltage and current measurements. the kursk state university experiment will be sent as 5 packets for a total of 2k of data. the data is collected for 90 each day. this experiment will sample the change in vacuum as the satellite slowly re-enters the atmosphere.
离线BH1IEO
只看该作者 4楼 发表于: 2011-02-11
orbitron上能跟上否?
这颗小卫星携带有sdr控制的fm转发器和线性转发器。带有不同角度的摄像头可以拍摄太空相片并用sstv发回地球,还携有15种语言的问候语。
http://www.amsat.org/amsat-new/satellites/satinfo.php?satid=136&returl=/satellites/status.php
离线BH1IEO
只看该作者 5楼 发表于: 2011-02-11
ho-68怎么打上问号了??
离线bd5rv
只看该作者 6楼 发表于: 2011-02-11
orbitron上能跟上否?
现在跟ariss就是跟它了。
离线bd5rv
只看该作者 7楼 发表于: 2011-02-11
ho-68怎么打上问号了??
目前ho68转发器关闭,只开信标,大家要过年嘛。
离线bd4reb
只看该作者 8楼 发表于: 2011-02-11
已有ja0caw收到sstv图像
离线bd4reb
只看该作者 9楼 发表于: 2011-02-11
想第一时间收听ARISSat1的语音信号吗?
后半段是流利的外国口音中文,我是没完全听明白, 文件来自ja0caw。
附件: Arissat1-2011-02-10-utc1956.part1.rar (0 K) 下载次数:120
附件: Arissat1-2011-02-10-utc1956.part2.rar (0 K) 下载次数:81
附件: Arissat1-2011-02-10-utc1956.part3.rar (0 K) 下载次数:77
附件: Arissat1-2011-02-10-utc1956.part4.rar (0 K) 下载次数:73
离线BH1IEO
只看该作者 10楼 发表于: 2011-02-11
arissat-1 spacewalk from international space station will air on nasa tv
two russian cosmonauts will step outside the iss on wednesday, feb. 16. they will install and retrieve experiments on the russian segment of the complex and deploy the arissat-1 ham radio satellite. live nasa television coverage of the spacewalk will begin at 6:45 a.m. cst (utc-6 hours).
离线bd4rs
只看该作者 11楼 发表于: 2011-02-11
今晚听听看,还有20分钟到达南京上空。
离线bd4rs
只看该作者 12楼 发表于: 2011-02-11
145.950mhz fm没听到,很值得关注的又一颗业余卫星,应当是宇航员用手来抛出去的吧。不知出手的时候是让它左旋还是右旋,还是随意翻滚。有意思!
http://www.amsat.org/amsat-new/index.php
离线BH1IEO
只看该作者 13楼 发表于: 2011-02-11
哈哈 那要看是左手还是右手扔了。 我这里也没有听到,郁闷中。
离线bd4rs
只看该作者 14楼 发表于: 2011-02-11
哈哈 那要看是左手还是右手扔了。 [表情] 我这里也没有听到,郁闷中。
可能空间站上的宇航员睡觉关了吧,不过这颗卫星是有的玩了。
离线bd4rs
只看该作者 15楼 发表于: 2011-02-11
这老兄玩的挺爽,在“中继台”边上直接玩起来了。
好像是打包了的arissat1,边上还有个包裹好像是电池吧。
根据介绍好像扔到太空之前,宇航员还有不少活要干,装天线,装电池......
照片来源:http://www.energia.ru/en/news/news-2010/news_12-31.html
离线bd4rs
只看该作者 16楼 发表于: 2011-02-11
“太空快递”有意思,好像外包装也不厚实。
照片来源:http://www.flickr.com/photos/valkyries1/5406687782/in/photostream/
离线bv2ac
只看该作者 17楼 发表于: 2011-02-11
amsat-bb 上討論的話題是, 該往前扔, 後扔, 還是側扔...... 扔錯方向, 將來有很大機會撞上 iss, 毀了花費幾百億的太空站......
离线bd4rs
只看该作者 18楼 发表于: 2011-02-11
应可参照suitsat的抛出方式
离线BH1IEO
只看该作者 19楼 发表于: 2011-02-11
快飘过来了,再整一把。
