  • 3112阅读
  • 7回复
这天线怎么样?看上去挺酷的。 [复制链接]
离线beetle
只看楼主 倒序阅读 0楼 发表于: 2011-01-10
features
- multi-polarized
- flutter reduction
- 360° azimuth beam width
- built in spatial diversity
- highly effective patterning
- elevation pattern: peak signal from the
horizon to 30° above; effective
hemispherical signal pattern.
- m-pol™ quality and performance
- rohs compliant.
applications
- commercial (truck, taxi, airport)
- government (police, fire, ems)
- military (all armed forces)
- maritime
physical specifications
- diameter: 5.25 in
- height: 6.5 in
- weight: .15 lbs
- construction: stainless steel, aluminum
- connector: 5/16"-24 thread
*with adapter to fit nmo style mount
- warranty: one year limited
typical performance
- frequency range: 400mhz - 500mhz
- gain: 4dbi*
- vswr: 1:1-1.8:1
- polarization: multi-polarized
- power: 200 watts input
- impedance: 50 ohms nominal
离线beetle
只看该作者 1楼 发表于: 2011-01-10
typical performance
- gain: 3dbi*
- vswr: 1:1-1.8:1
离线beetle
只看该作者 2楼 发表于: 2011-01-10
applications
- maritime
- ham radio
- scanner
typical performance
- frequency range: 25mhz - 6ghz (receive)
88mhz - 6ghz (transmit)
- gain: 3dbi*
- vswr: 1:1-1.9:1
- power: 200 watts input under 512mhz
100 watts input over 512mhz
离线bg6art
只看该作者 3楼 发表于: 2011-01-10
有点像把地网反过来用撒
离线ba7ib
只看该作者 4楼 发表于: 2011-01-10
围观蜘蛛天线.....
感觉就像三个频点的天线直接并在一起了....
离线mylcq
只看该作者 5楼 发表于: 2011-01-10
这是一种380mhz~500mhz变形盘锥天线,如果调整角度天线频带还会宽一些.
只看该作者 6楼 发表于: 2011-01-10
鸡爪子天线!!!
离线bg2rlv
只看该作者 7楼 发表于: 2011-01-11
6搂的是正解!
